01-15-2019, 01:34 PM | #177 | |
Rep 238
Hopefully been changing the fuel filters. |
01-15-2019, 01:46 PM | #178 |
Rep 42
What fuel filter? jk
Replaced the transmission pan/filter/gasket/stretch bolts with the ZF OE part and ZF fluid. One more thing. Lost like two wheel lock keys so I just put regular lugs back on. A mechanic stripped a lug so I had to extract it. The main thing though is that the car IS reliable, everything just needs to be done correctly, every time. Also on my to do list is to clean the HVAC air intake and AC evaporator core. Last edited by wicked510; 01-15-2019 at 02:00 PM.. |
01-15-2019, 08:37 PM | #179 | |
Rep 1,800
Interesting data. I don't contest it, because it's a very positive outcome. On the edc17 ecu, lambda is used solely for smoke control, to reduce fueling, so I don't see where it would 'fit in'. But nonetheless, it's a nice observation. If it holds over a few more tanks without active bias, then that's great! I got my dad's X3 28d to go up 3mpg to the average just from a tune I made for it, so that was a nice surprise. The huge lump of torque and nice hp really move that suv. BTW, ecopro setting can be tinkered with to be much better.
01-16-2019, 10:49 AM | #181 |
Rep 424
01-16-2019, 07:08 PM | #182 |
Rep 368
If the message is "drivetrain malfunction" it can be almost anything. I got it from an EGR leak and also got it just prior to the transfer case blowing up. It stores a sort of 'soft' code that doesnt set the MIL light and requires a bmw specific scanner to make sense of. Ie ISTA+ or the like. BMW did a great job keeping the diagnostics difficult for owners.
01-18-2019, 05:56 AM | #183 |
Rep 308
EGR components looked fine, however the hose that goes from the bottom air filter box to under the MAF sensor has some grease buildup at the connection point on the MAF side.
2017 F31 328d xDrive
M Sport M Performance |
01-18-2019, 07:03 AM | #185 |
Rep 1,076
01-18-2019, 08:15 AM | #186 |
Rep 308
Any codes when scanning though?
01-18-2019, 01:09 PM | #187 |
David
786
Rep 2,010
01-18-2019, 03:37 PM | #189 |
Rep 1,800
BMW tools would have shown codes.
Generic OBD (P-codes) is only for emissions regulated components.
02-21-2019, 11:47 AM | #192 |
Rep 71
Man, I thought I was deep into mine at 76K miles! You guys drive the socks off your cars!! WOW!
ENABLED....could you PM me? I have a few questions for you!
2016 Glacier Silver 328d Msport Xdrive wagon - Kerma Tune bench flashed - SOLD
2016 Alpine white 535d Msport - Kerma Tune, CF rear spoiler 1975 Corvette 496 stroker, ridetech suspension, ATSpeed R-man valve body TH400 - in progress. |
02-21-2019, 08:36 PM | #193 |
Rep 37
There is a spreadsheet with all the failures the mileage and the tires setup.
I can’t find the link I’m new on this forum. But looks like square set up has the similar failure rate. |
