BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 for BMW F series Vehicles - General Discussion
      01-15-2019, 01:49 PM   #595
Mizerka
Drives: BMW 428i MSport
Originally Posted by designatedposter View Post
yes, you can save a copy of the stock map, then edit that one to disable cold start. then flash to car.
Thanks (and others), was gonna get flash map from local shop but might just go with bootmod3 seeing that most places nearby don't offer cold boot disable, closest I've found is London, like 4 hours one way drive, f that.
Anyone knows best way to get it in UK? seen one "retailer" but not sure.
      01-15-2019, 01:50 PM   #596
M2Rush
Drives: 2014 BSM 335i x-drive
Does anybody know why there's 2, stage 2 AGG tunes? Maybe a glitch on my car/BM3 license but it has shown 2 stage 2 AGG OTS maps since I activated my licence months ago. Is there a difference?
      01-15-2019, 02:59 PM   #597
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Can you screenshot and post it? There should only be a Stage 2, and a Stage 2 AGG.
      01-15-2019, 03:05 PM   #598
M2Rush
That's weird... Sure, not a problem.
They both have the exact same info but one just has a little more info in the description.
      01-15-2019, 03:21 PM   #599
rjd_F30
rjd_F30's Avatar
Hmmm yah that's odd. I just have Stage 2 91 & 93 and Stage 2 91 & 93 AGG. Maybe just a glitch for EWG N55's, I'd be curious if other people in the same map grouping are seeing the same, or if it's just a glitch in your account.
      01-15-2019, 08:43 PM   #600
meltbox
Drives: 2014 328xi GT (F34/N20)
Huh I just realized since they sent me a revised tune I'm now stuck at 4.1
I do wonder what "load control" is. Seems like all the tunes got an upgrade. Anyone flashed yet?
      01-16-2019, 04:41 PM   #601
proTUNING Freaks
proTUNING Freaks's Avatar
4495
Drives: powered by bootmod3
UPDATE:
Apps for iOS and Android are available on their respective App Stores as well as an updated OBD Agent (0.10.046) have been released.
Updates include:
- New dashboard layout (more updates coming here soon..)
- Additional OTS map updates for S55 with OPF/PPF filters
- TCU stock reflash updates for M2C and other S55s
- Various N55 EWG/PWG and N20 updates based on end-user feedback
- Online recode button is going away soon. Version 46 of the OBD Agent is now making this seldom used option unnecessary.
meltbox43.00
Noelified228.00
      01-16-2019, 05:46 PM   #602
designatedposter
Drives: m235i
ptf has admitted this is a mistake and have said they will remove one for a while now. what they also said is that they are identical.
      01-16-2019, 05:53 PM   #603
designatedposter
Drives: m235i
Originally Posted by proTUNING Freaks View Post
UPDATE:
Updates include:
what do you mean by the various n55 ewg updates based on user feedback? are you referring to the latest 6.3 map? if not, then do you mean i need to reflash 6.3 with latest software to get these updates?
      01-18-2019, 01:38 PM   #604
M2Rush
Thanks for advising, I appreciate it!
      01-23-2019, 12:11 PM   #605
proTUNING Freaks
4495
UPDATE:
https://f30.bimmerpost.com/forums/sh....php?t=1576377
      01-23-2019, 08:28 PM   #606
matty088
Drives: 335i
I need to unstall my bm3. Unfortunately i haven’t been following developments here or in the fb group.
I know that I need to flash back to stock and lock the dme. Is there anything else? What about Java. Does that issue still exist? Do I need to make sure I am running a certain version of Java ?
Flashing the car makes me nervous. Is there anything I need to be aware of?
      01-23-2019, 09:11 PM   #607
rjd_F30
rjd_F30's Avatar
Nope, just stock and lock. Nothing to worry about, I've done it a dozen times.
      01-24-2019, 12:49 PM   #608
proTUNING Freaks
4495
Months ago we used to require people to install Java separately and you could make a mistake and pick the wrong version which caused issues at times. That was fixed back then and the right version is just bundled inside the OBD Agent so nothing to worry about there, just install and flash.
      02-08-2019, 07:42 AM   #609
proTUNING Freaks
4495
UPDATE:
V52 pushed out last night has a number of enhancement updates and fixes. We've changed some of the agent's connection handling with the car as dash starts, logs start/stop, leave/re-enter the dashboard screen, run diagnostics making things much more zippy. Sporadic issue that would cause a blank log on v50-v51 of the agent at times has also been been resolved.
On the server we managed to also significantly speed up saving of map updates (e.g. map config save, saving changes in the table editor, getting OTS maps, sending map requests, etc). There was also a fix for the web/apps to the dashboard screen that at times on re-entry to the dashboard would show all the gauges stacked on top of each other.
Web and Android updates are out already, iOS v52 should hopefully be out on the app store some time today (awaiting apple review since last night).
****NOTE: Ensure you update your OBD Agent to v52 released late last night. If using the WiFi device get the latest SD card image and restore as we've updated the agent 'updater' on it and here's a link to it:
https://bootmod3.atlassian.net/wiki/...irmware+Update
Previous versions of the agent will NOT update over the air as the location where updater gets the agent updates from changed. If using a laptop agent we suggest just downloading and reinstalling the latest from www.bootmod3.net/downloads even if you possibly got v52 earlier yesterday ****
Noelified228.00
      02-08-2019, 07:48 AM   #610
rjd_F30
rjd_F30's Avatar
UPDATE:
meltbox sounds like this one was for you
      02-11-2019, 11:41 PM   #611
ghost chili
Drives: E92 335i
Anything for the B46 engine yet? Just got a 2018 F31
      02-15-2019, 10:46 AM   #612
shadowx360
Drives: BMW 340i
Originally Posted by BunkerJ View Post
I'm running the ER DP and FMIC. For Stage 2, you will absolutely need both DP and FMIC, trust me. Don't try to get by with one or the other because your performance will drastically drop. As for spark plugs, you can definitely upgrade them but always check beforehand to see which ones you have. The plugs you should be after are NGK LI, part #: SILZKBR8D8S. Don't go M3/M4 plugs as they are a step hotter than ours. They upgrade to our plugs, not the other way around. Gap is subjective but usually lies in the .020" to .026" range. Stage 2 does cancel out the CEL for a DP. Only pro/con I can think of is:
1) More Power. Do you hate more power?
2) You're catless, which means more emissions, which means you fail smog tests (depending on your state/county)
Hey I'm looking to change my spark plugs on my 2015 328i N20. Stock is SILZKBR8D8S. I am running stage 2 93 Oct with an FMIC and downpipe. I haven't touched the gaps at all and it's been running fine for 3 months. Any advice on how I should gap the new ones? 0.022?
      02-15-2019, 11:23 AM   #613
rjd_F30
rjd_F30's Avatar
I have mine at .025" for Stage 2 93oct. Some guys go down all the way to .018". Try anywhere between there and you'll find a sweet spot.
      02-18-2019, 07:56 PM   #614
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
What’s the consensus on exhaust mods needed to run stage 2 on 320i with bm3? I have a 3 inch axle back exhaust now. Fmic on the way, already catless, eventually CP. My car has 40k miles - should I also get cooler plugs? I’ll probably run stage 1 most of the time and stage 2 when needed.
      02-18-2019, 08:14 PM   #615
rjd_F30
rjd_F30's Avatar
Just a downpipe, that's the only exhaust mod you'll need.
I'd recommend colder NGK L/I plugs, I run them myself, but it's not a must.
      02-19-2019, 04:56 PM   #616
Bmwman325
Drives: 2015 MG CR 335 XI 6SP
Hey guys, I need to flash back to stock. OBD agent with windows laptop and ethernet OBD, will not connect to car. I've downloaded the update but when it opens it still says version 0.10.054..... What am I missing?
Wagner Competition Intercooler, ER Chargepipe, Fabspeed Catted Downpipe, Bootmod3 OTS Stage 2 93 oct
bm3, bootmod3
