BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > How to: TorqByte CM5-LT Meth System Install
proTUNING Freaks
      10-02-2018, 10:19 AM   #23
harkes
harkes's Avatar
China
1076
Drives: M135i, E39 M5, NSX and AE86
Originally Posted by HKD126 View Post
I use a 20psi check valve from ProMeth. Rodney (ProMeth) recommended it over the solenoid for the simplicity of my system.
20psi? What is the purpose of such big opening pressure? Full vacuum is 14.7 and I can hardly thick that an engine can make more than 10psi vacuum.
Could you try to do a flow test with/without the valve? Or maybe just remove the spring inside it - I'll try that tomorrow.
(A Dane in China)
      10-02-2018, 10:34 AM   #24
harkes
harkes's Avatar
China
1076
I should start selling these valves haha I paid 3.6usd for this in 304 stainless steel
(A Dane in China)
      10-02-2018, 11:00 AM   #25
HKD126
Drives: 2014 335i, 2009 335xi
20psi line pressure from my pump which runs at 220psi at 100% duty. I’m not even maxing out my 5gph nozzle. I feel as though it’s plenty fine for my setup. Again, it’s what ProMeth also recommended.
      10-02-2018, 11:06 AM   #26
harkes
harkes's Avatar
China
1076
The 20psi is opening pressure right? Those psi are lost pump pressure and seems excessive when the engine cannot nearly make that much vacuum. Took mine apart. Looks great for 3.5 bucks I'd say. Think I'll try to improve the flow by making some more holes in the valve head
(A Dane in China)
      10-02-2018, 12:41 PM   #27
HKD126
Yeah, 20psi cracking pressure. I’m fine with it honestly. I’m running a small 5gph nozzle which I’m not maxing out on the stock turbo. By the time we’re done with the tune I’ll be happy with 420-440awhp/490-520awtq. That’s as much as I care to push to stock turbo anyways. If flow ever became an issue, I know Twisted Tuning offers a 14psi valve, or I could always swap to a bigger nozzle/turn up the pump pressure.
      10-12-2018, 10:14 AM   #28
Dfahmy
Egypt
140
Drives: F30 335i PWG
2013 BMW 335i  [0.00]
HKD126 harkes Hey I had a question for you both where did you tap the boost signal from, the charge pipe tmap or manifold map sensor?
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
      10-12-2018, 10:45 AM   #29
harkes
harkes's Avatar
China
1076
I use the manifold MAP as that will ready the "true" pressure.
See my video:
(A Dane in China)
Dfahmy139.50
      10-12-2018, 11:16 AM   #30
Dfahmy
Egypt
140
See my video:
Is it your stock N55 manifold sensor or did you upgrade it to the 3.5 bar N20 sensor
      10-12-2018, 11:52 AM   #31
HKD126
I used the TMAP sensor signal wire and OEM sensor as I’m not running more than 20psi.
In my first post I showed to to calculate the values for either stock sensor or 3.5 N20.
      12-01-2018, 05:18 AM   #32
harkes
harkes's Avatar
China
1076
Mike
What's up? Back from the tour? I am still struggling with my tune but had a log reviewed by Juan from Bigboost who said my WG is probably adjusted too tightly causing all that overboost I have. Might also solve the oscillation - I'll have it adjusted on of these days. Fingers crossed
(A Dane in China)
      12-02-2018, 02:48 AM   #33
HKD126
Mike
I fly home tomorrow. Unfortunately it’s now winter with a good amount of snow... Tuning will have to resume come spring...
      12-05-2018, 02:50 AM   #34
harkes
harkes's Avatar
China
1076
Right you said so - bummer!
(A Dane in China)
      01-17-2019, 12:04 AM   #35
M235SDCA
M235SDCA's Avatar
Drives: 16 M235 Vert
Awesome DIY by HKD126. Thanks also to Harkes as well. I just installed a Torqbyte controller and am punting the JB4. For the most part JB4 worked OK but there were occasional issues I got tired of.
In case anyone wants to build their own TMAP patch cable, the TMAP connectors are Hirschmann Automotive 805-122-541 (plug, on harness) and 872-617-541 (socket equivalent on TMAP sensor). A set is about $5 on AliExpress:
https://www.aliexpress.com/item/Free...757e4c4d3AFKzk
Additionally you will need a crimper. I bought an IWISS IWS-2820M:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
If you go this route make sure you get more than 1 connector or extra pins, as it is easy to screw up the crimping. In retrospect it would have been a lot easier to get a patch from BMS, but I wanted to crimp connect this directly to the TMAP sensor wire. In my installation I just connected the sensor wire and did not connect the ground wire to the CM5-LT.
Another location to mount the CM5 is above the driver kick panel. I have an F23 and tied / VHB taped it to an existing module bracket on the fender side. On the F2x there is a hole in the kick panel and I can reach in to install the USB cable when I need to. Not sure if the F30 is the same, but there are a lot of similarities on the F2x and F3x so I thought I would mention it.
16 M235 Cabrio - BM3, ER CP, Wagner DP & IC, Dinan Intake, MPE, Torqbyte CM5
18 340i F30 mostly stock
      01-17-2019, 08:54 AM   #36
HKD126
This is awesome!! Thanks for the input!
      01-18-2019, 02:29 AM   #37
harkes
harkes's Avatar
China
1076
Post some logs and let us see how you made your setup I am being custom tuned now on MHD so hopefully 20psi soon on meth and 91 AKI
(A Dane in China)
      01-18-2019, 08:19 AM   #38
HKD126
Weren’t you on BM3? Why the change?
      01-20-2019, 07:06 PM   #39
harkes
harkes's Avatar
China
1076
Mike
Indeed I were. Answer is PWG support. Few tuners on the BM3 platform have extensive experience with PWG and the one I found prefer to work with MHD.
(A Dane in China)
      01-25-2019, 11:29 PM   #40
M235SDCA
M235SDCA's Avatar
OK, finally got all the wiring squared away. Have been a bit busy and didn't get the solenoid wired to GPO1 until recently. Values in this thread for the N55 TMAP sensor were the same in my BM3 stock file.
One of the issues I had previously with my JB4 setup is sometimes the N55 would reset fuel trims to the center sometimes when meth was flowing. Not sure why it would happen, but traction control events seemed to be one of the triggers. This would result in really rich AFR and lots of misfiring, loss of power, etc. Very unsatisfying. Hoping that the TB controller will help with this, since the duty cycle is driven off the TMAP sensor. During a traction event the throttle closes, manifold boost lowers and TB lowers meth flow.
After installing the TB I still had some issues and went to a slightly smaller DO7 nozzle instead of a CM10. Currently running an Enzo BM3 map so the fuel pump can mostly keep up, but there are some points where pressure does sag quite a bit. I am thinking the meth will help with this and cooling when it gets hot in the summer (SoCal). My turbo is stock and my map doesn't depend on the meth so no need in my setup for a boost dump controlled by the TB.
Still have to get some BM3 logs along with the TB logs to really see how things are working.
harkes1075.50
      01-26-2019, 11:20 PM   #41
harkes
harkes's Avatar
China
1076
I have a problem that even with the settings calculated by TorqByte, the TB and BM3 logs does not read the same psi. How does your compare?
(A Dane in China)
      01-27-2019, 07:03 AM   #42
HKD126
I talked with TB about this and we adjusted mine slightly and they ended up being bang on.
      01-27-2019, 08:06 AM   #43
harkes
harkes's Avatar
China
1076
OK, mind sharing the values? They said they would buy one to measure it, but I never heard back. Doesn't really matter if TB read 20 or 10 - just adjust the tabels accordingly - more for the inner perfectionist
(A Dane in China)
M235SDCA105.00
      04-21-2019, 03:57 AM   #44
harkes
harkes's Avatar
China
1076
Exclamation
Hey
I ran out of meth on purpose. Check it out
(A Dane in China)
M235SDCA105.00
