01-01-2019, 06:07 PM | #2 |
Rep 293
I have a 15 320i with BM3. Would really recommend it. If you have or had a JB4, its similar, but the power delivery is smoother. I'm getting a new downpipe to go Stage 2, I'm just debating on getting a highflow cat or a catless one. The highflow cats will let me pass emissions inspections, but Catless downpipes will not for where I am from (Pennsylvania).
With Bm3, your horsepower should sit around ~220 or so, and Stage 2 will probably bring you right around 250ish. |
01-02-2019, 08:26 AM | #3 |
Rep 159
I'm curious why 320i needs catless or highflow cat for stage 2 (250hp) but 328i makes that amount of power with OEM cat. Downpipe is same for both applications. I know that compression is different but that should't make any difference from a downpipe point of view, should it?
I don't understand that if you make same amount of hp, why the x20i needs aftermarket dp and x28i doesn't. I get it that if one would want to get more hp and/or use a burple map, then aftermarket dp is a must. But there is a tune potential with x28i even with stock dp so with x20i there should be plenty of head room left? I ask because I'm hesitant to get rid of my cat because then I would not pass emissions inspections. |
Fr3sh29.50 |
01-02-2019, 10:13 AM | #4 | |
Rep 3,680
01-03-2019, 01:06 AM | #5 | |
Rep 159
http://www.realoem.com/bmw/enUS/show...diagId=11_5185 - 20i http://www.realoem.com/bmw/enUS/show...diagId=11_5185 - 28i What is different is compression ratio (11:1 vs 10:1), smaller FMIC and smaller diameter midpipe (65mm vs 75mm). I'm going to upgrade my FMIC anyway so it does not matter and I'm not sure yet about midpipe. What I have read about it, it's not the limiting factor really. However, I'm planning to upgrade my muffler to 335i muffler for the looks and sound so it will also flow better than stock 320i muffler with one outlet. Are you sure about different cams? I haven't heard that earlier? According to realoem they are same for both inlet and outlet side? http://www.realoem.com/bmw/enUS/show...diagId=11_4776 http://www.realoem.com/bmw/enUS/show...diagId=11_4776 |
01-03-2019, 02:16 AM | #6 | ||
Monkey
119
Rep 241
The only difference between the two engine blocks is the piston. Otherwise, they're the same. The FMIC is shared between the two too. Shared engine components between F30 320i and 328i Cylinder head - PN 11127624778 Connecting rods - PN 11247624616 Crankshaft - PN 11212212762 Intake manifold - PN 11617588126 Air box - PN 13717597589 Air filter - PN 13718507320 Intercooler - PN 17517618809 Radiator - PN 17117600520 Throttle body - PN 13547588625 HPFP - PN 13517584461 MAF - PN 13627602038 DME/ECU - PN 12148604210 Exhaust manifold/turbo - PN 11657642469 |
CandyRedRC46242.00 Fr3sh29.50 |
01-03-2019, 03:56 AM | #7 | |
Rep 3,680
01-04-2019, 05:25 AM | #8 |
Rep 159
Thank you both cpxchewy and rjdnyy224 for the additional information and correction. But this makes me actually wonder just even more, not less, why high flow downpipe is needed for 320i. Or is it actually needed for stage 2 with mild burples? I guess I will lose ~20hp with OEM cat but does it actually hurt the engine? Let the investigation continue
01-04-2019, 09:15 AM | #9 | |
Rep 3,680
01-04-2019, 09:31 AM | #10 |
Rep 1,067
As many others have pointed out, main (really only) difference are the pistons and compression. I've really enjoyed the JB4 with Meth. Car made great power with OEM downpipe and 22lbs of boost.
I know I'm leaving a lot of power on the table with OEM downpipe, but from history of others (2-3 years ago), it appears that the DP on the N20 is the one component that can really throw things into grenading the motor, now I'm not sure why that was though. People running too high of boost? Did the turbo fail? Did they run DP without a tune? Obviously the downpipe wouldn't cause these engines to blow (I'm guessing), but was it an enabler to something else? Perhaps this has been resolved with BMW3. Does anyone know if I can run BM3 w/ Meth or what is the point of BM3 with a JB4 and such? I've read a lot of people saying BM3 power delivery is smoother, mine appears to be very smooth and linear, obviously the car just dies in power at 3500rpm (4-pot turbo), but what is so smooth about BM3? Happy to try and help answer any questions with my Meth experience too... My numbers: https://f30.bimmerpost.com/forums/sh....php?t=1508531 Personally, I enjoy seeing 320i owners on the forums, we are a small little crew, but there is tremendous value in the car, and I really enjoy driving it. |
01-04-2019, 10:35 AM | #11 | |
Rep 3,680
You can run BM3 with meth, but you'll need to keep the JB4 as a controller. I went from a piggyback to BM3, and the biggest difference was the smoothness of BM3 over the piggyback. The piggyback felt peaky and died around 4800rpm, but with BM3 the car still runs out of steam up top, but it pulls deeper into the rev range and doesn't die off as abruptly, if that makes sense. A good flash tune can kind of hide that distinct turbo-car feeling power band. It's just less peaky and well, smoother.
CandyRedRC46242.00 |
01-04-2019, 04:18 PM | #12 | |
Rep 159
Thanks also CntryClub007 for chiming in. I guess I can getaway with my stock downpipe then because I'm not going to use meth anyway. Or try to squeeze the last horsey out of the motor for that matter. It just feels that there would be some potential left but OEM software is limiting it. I also found a local tuner who actually does a dyno run before and after the re-programming and they are promising 230-250hp with stock everything, no single HW change. They have also listed the differences between 320i and 328i and pistons are pretty much the only difference. Here is a link for reference, but it's unfortunately only in Finnish so it's difficult for you to understand it (even Google has hard time to translate Finnish correctly): https://www.motorbit.fi/bmw-f3x-n20-320i-328i/ The problem with that tuner is that they are using their own tools and I kind of want BM3. But BM3 has no retailer in Finland so it's a bit of a problem. Well, I have a few months to wait anyway as it's winter time now and I couldn't use the additional power anyway. Not to mention the difficulty to test a tune when I have my winter tires on as they are the spiked ones. |
01-04-2019, 05:46 PM | #13 |
Rep 3,680
Gotcha. Well, then it must be the pistons and compression if that's the only mechanical difference lol. It can't be the software as a tune makes that completely moot.
Also, I'm sure you know but you don't need a BM3 retailer to go to BM3. You can just buy a license and do it all yourself with a laptop and cable.
01-04-2019, 05:49 PM | #14 | |
Rep 190,777
We send you the cable free of cost to use in order to load your map. Its a very simple process that can easily be done by anyone
01-05-2019, 02:38 AM | #15 |
Rep 77
I can program it for you in Tampere or Jämsä area. Send me a private msg if interested. You can also try my 320i stage2 if you like.
01-05-2019, 07:34 AM | #16 |
Rep 159
Thanks everyone for answers. What I have read some cars needs some modifications to program so that engine runs correctly. It could be also wise to request I-Step update before flashing a new map into ECU?
I PM'd you jkoljo let's see if we can arrange some meeting. |
01-05-2019, 09:28 AM | #17 | |
Rep 3,680
01-19-2019, 07:16 AM | #18 |
Rep 58
Basically different part numbers for Pistons, Transmission, Driveshaft, front muffler and Rear exhaust
Piston: 320i - http://www.realoem.com/bmw/enUS/show...diagId=11_4770 328i - http://www.realoem.com/bmw/enUS/show...diagId=11_4770 Rear Exhaust: 320i - http://www.realoem.com/bmw/enUS/show...diagId=18_1105 328i - http://www.realoem.com/bmw/enUS/show...diagId=18_0974 Transmission: 320i - http://www.realoem.com/bmw/enUS/show...diagId=24_1330 328i - http://www.realoem.com/bmw/enUS/show...diagId=24_1330 Driveshaft: 320i - http://www.realoem.com/bmw/enUS/show...diagId=26_0240 328i - http://www.realoem.com/bmw/enUS/show...diagId=26_0240 Front Muffler: 320i - http://www.realoem.com/bmw/enUS/show...diagId=18_0975 328i - http://www.realoem.com/bmw/enUS/show...diagId=18_0975 |
01-19-2019, 07:32 AM | #19 | |
Rep 58
320i - http://www.realoem.com/bmw/enUS/show...diagId=17_0632 328i - http://www.realoem.com/bmw/enUS/show...diagId=17_0632 328i is 30% heavier |
01-19-2019, 08:22 AM | #20 | |
Rep 3,680
01-19-2019, 04:52 PM | #21 |
Rep 13
I have 320i with BM3 and full Fi exhaust (3 inch pipe for N20 320i and 328i). Stage 1 would be about same power as 328i. Stage 2 you would smoke 328i. I work at BMW dealer, so I have driven both stock vehicle many times.
01-20-2019, 01:08 AM | #22 |
Rep 58
