BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Location of active DEF fill tube - 2014 328d
proTUNING Freaks
      01-21-2019, 12:14 PM   #1
scarvaines
Drives: 2014 328d X-Drive
Thank you in advance and first post to this forum.
Can someone help me locate the location of the active DEF reservoir filler tube for a 2014 328d (2.0L diesel)? Seems our passive tank is full of frozen fluid and it won’t auto-fill the active.
Steve
      01-21-2019, 12:29 PM   #2
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
Steve
I know the active tank is located in the vehicle underbody in front of the right rear wheel, passive tank is located behind the right rear wheel.
I've attached a technical training PDF from BMW, hopefully it helps.
      01-21-2019, 12:57 PM   #3
scarvaines
Thank you Dave! I will look again - thought I scoured the car looking for the active fill tube but will look again with the info you provided. Don’t remember seeing anything with a blue cap like on the passive fill tube.
