03-16-2015, 12:13 PM | #23 | |
Rep 749
Drives: 2016 528i Executive Edition
03-16-2015, 01:12 PM | #24 |
Rep 208
I've got the no drill. The gas pedal cover slips over the existing rubber cover. You'd think it'd be loose but it fits quite snug. Had my for just under a year now and no issues.
03-16-2015, 02:23 PM | #25 |
Rep 5,262
03-26-2015, 03:44 PM | #26 |
Rep 16
My 328d M-Sport didn't come with the stainless footrest...
Evil_ss, how was the footrest install? Did it need any drilling like the other pedals? |
04-24-2015, 01:55 PM | #27 |
Rep 258
My 328i M-sport 2012 didn't either come with the stainless footrest . I want to buy the M-Performance pedals and now I have to pay extra for the footrest .
/// M-Sport 328i // Packages -- Adaptive Drive-- Drive Comfort -- Function -- Visibility // 19" 403M // M-Sport Brakes // Harman Kardon // Head Up Display /// |
04-29-2015, 11:42 PM | #28 | ||
Rep 749
Got mine a few weeks back and just installed them the other day. The fit is SUPER snug on the brake and clutch. At first I didnt think it would even go on but after working the rubber around a bit it seems to fit well. As for the gas pedal, I simply slid it on and it doesnt even seem to move. I didn't even utilize the 3M two sided tape. Just left it there without peeling it. Looks beautiful! Now all the pedals match the foot rest! Last edited by E30toF30; 04-29-2015 at 11:54 PM.. |
05-08-2015, 05:17 AM | #29 |
Rep 258
How do you install the M Performance footrest, do you need to drill or is it taped?
05-08-2015, 06:43 AM | #30 |
Rep 374
Drives: 2017 540i
Just taped on top of the existing footrest.
2017 540i :: 2006 M3 :: 2012 328i Sport Line (sold)
05-08-2015, 12:33 PM | #31 |
Rep 258
Great, thanks for the info.
06-13-2015, 04:39 PM | #32 |
Rep 258
I also have now changed to M Performance pedals and it looks much better now . Drilling the brake pedal was a challenge but if you are careful and use quality drills then it will go smooth. I started with 1/8 (3,2 mm) and then finnished with 5/32 (4 mm) drill, thanks guys for the tips . Now i only have left to fix the M Performance rear diffuser and M Performance exhaust.
06-15-2015, 12:58 PM | #33 |
Rep 1,479
Drives: 2020 M340Xi (G20)
Hi,
Having read this post and really liked the looks of the brushed aluminum pedal covers, I must confess that I took the easy route and got a set of no-drill covers from eBay for about $39 (inluding shipping) from KBH_Motors: http://www.ebay.com/itm/161623574633...%3AMEBIDX%3AIT Took about 15-20 minutes including taking off the original covers. Have had them on for about a month with no problems Attached are what they look like
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
06-19-2015, 01:39 PM | #34 | |
Rep 218
Would a center punch accomplish the same thing? |
06-27-2015, 02:33 AM | #35 |
Rep 349
Hi all thanks for this great DIY!
I have a question regarding the height of the gas pedal. Is it pretty much at an even level with the brake pedal after install? It seems like the m performance brake pedal replaces oem while the gas pedal goes on top of stock so it should increase the relative height of the gas pedal. Can anyone confirm? |
09-06-2015, 11:08 AM | #37 |
BACK IN '74
Rep 41
Gas, Brake M Pedal Install
As usual I found it more time consuming doing it myself. I try to be as careful as possible so I don't make mistakes that I am sorry for later. It took me about 2 hrs to completely finish including vacuuming and clean up. It turned out great though and is worth the effort. Sure seems the brake pedal could be a little easier though. Gas pedal only took 5-10 min.
Dinan Stage 2 | Dinan Exhaust | Dinan Carbon Fiber Cold Air Intake | Dinan Carbon Fiber Strut Bar | Ultimate Aluminum Pedals with "M" Emblems | BMW Performance 313 Wheels | Bridgestone RE-11 Tires
09-06-2015, 11:09 AM | #38 |
BACK IN '74
Rep 41
New Car
I now own a 2015 335i M Sport, let the 2008 135i Dinan go.
09-06-2015, 11:40 AM | #39 |
Rep 741
Drives: 22 M4c vert
I installed mine a few days ago - first of all, with the aid of some of the posts in this thread, this was a 20 minute install. With the right - powerful - drill, and - titanium - bits, there's zero issue drilling through the pedals.
Second, these are extremely thin. After installation, the relative offset of the pedals compared to stock seems to be entirely unchanged. |
09-08-2015, 12:47 AM | #40 |
Rep 349
I should have chimed in too.
I got the replicas and it does seem to add some height to it - I am able to physically heel toe unlike before where it was very hard unless you were really stepping on the brake. But physically being able to do it and being proficient at it are totally different! =) |
11-16-2015, 02:44 PM | #41 |
Rep 234
11-28-2015, 02:56 AM | #42 |
Rep 183
12-05-2015, 12:06 PM | #43 |
Rep 151
Great DIY thread! Knowing the bit sizes to pre-drill the brake pedal helped a lot. In the end it actually took me 3 hrs -_-; using pliers to hold onto the washers to screw them in was a pain...
