05-11-2018, 08:38 PM | #1 |
Rep 63
B58 surging
What's up bimmers!
I'll try to make it short and to the point. I have stock 2017 340i the there is a surging problem when slowing down in traffic then accelerating at low speeds and the throttle pedal is not linear and has a delay in response. Hesitations after cold start and going uphill are horrible. I also noticed form time to time all this problems disappear and the car runs perfectly the throttle is linear and predictable and no surging but that happens once in awhile. I scanned for fault codes and there is none Any help would be greatly appreciated... Last edited by Panda340i; 05-11-2018 at 08:49 PM.. |
05-13-2018, 11:00 AM | #4 | |
Rep 2,292
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971. |
05-13-2018, 11:23 AM | #5 | ||
Rep 63
I went in for an oil change service for 20k km They will replace: Engine oil Spark plugs Air intake filter AC filter Front brake pads (as they the remaining life is 3mm) All above was part of the 20k km service They told me that the problem should be fixed after that especially after the spark plugs change. |
05-13-2018, 12:36 PM | #6 | |
Rep 2,292
I think the dealer is wrong, there is a software upgrade for the stumbling problem. Don't know if it is transmission or engine related.
05-13-2018, 12:52 PM | #7 | |
Rep 63
[QUOTE=tuco44;23186692]
I know right, but they told me that our local fuel is not the clean and they require spark plugs for 20k km service If you could provide me with a bulletin for the reprogram to show it to the dealer, that would be great! |
05-13-2018, 12:53 PM | #8 |
Rep 7,484
Try a different dealer. There are updates for these kind of issues. If you can demonstrate it to them then even better.
Something is up it the throttle reset works for 2 days. |
05-13-2018, 01:08 PM | #9 | |
Rep 2,292
[QUOTE=Panda340i;23186729]
All I can tell you.
Panda340i16.00 |
05-13-2018, 01:49 PM | #10 | ||
Rep 63
[QUOTE=tuco44;23186775]
05-13-2018, 01:51 PM | #11 |
Rep 63
Waiting for anyone to chime in...
nirvanabob31.50 |
05-14-2018, 05:06 PM | #13 |
Rep 63
Update..
After the dealer changed: Engine oil Spark plugs Air intake filter AC filter On my way back home the the problem disappeared ( Which is normal for me after every oil change service, the car always runs great after oil change) But at the evening I went for a test drive, the problem seemed be to growing back in) I notice a slight sluggish delay after coming to a stop then accelerating in traffic. 0 to 15 km/h I asked the dealer again to reprogram tranny before leaving the dealership and he told me there is no such thing and the spark plug should fix the problem. I need a SIB or Bulletin of the software update to show it to the service dealer. I'm really upset of this problem and there is only 5 months left till the warranty ends. |
05-15-2018, 06:57 AM | #15 | |
Rep 552
05-15-2018, 07:28 AM | #16 | |||
Rep 63
Bmw recommends changing pads when they reach 3-4mm of remaining life. |
05-16-2018, 07:28 PM | #20 | |
Rep 1,988
How will your warranty end in 5 months on a 2017 model with 20k km on it? |
05-17-2018, 02:26 PM | #21 |
Rep 3,622
This happened on my dads X5. Need to reprogram the transmission
BMW CCA Member #516012
