05-14-2018, 09:34 AM | #1 |
Rep 60
Remove MPPK exhaust from 440i without changing ECU.
I am in the process of swapping cars and would like to remove the M Performance Exhaust that was fitted as part of the MPPK. I have heard that if I simply remove the exhaust and do not get the ECU reflashed with stock software it will potentially make the car having running issues. As I am possibly going to be selling to a friend, I would like to make sure that I am not going to cause any issues before doing so as he does not want the exhaust.
Thanks |
05-15-2018, 02:04 AM | #2 | |
Rep 148
05-15-2018, 05:22 AM | #3 | |
Rep 60
Thought as much. Unfortunately, I am not sure it is feasible to get both the tune and exhaust removed. He wants to run the stock exhaust as it is quieter. Oh well, he can have it with the tune and exhaust or sort it himself! Cheers |
05-16-2018, 01:38 PM | #4 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
Not sure if the tune can be "downgraded" to the stock tune - that's something you'd need to ask the dealer if they can do (although, I think he'd be insane to do it )
You definitely can't transfer the tune to another vehicle as it's tied to the original vehicle's VIN when the MPPSK is ordered from BMW AG. One suggestion is he could get a DINAN mid-pipe installed with the stock exhaust which removes the two resonators. This should work better with the MPPSK tune but it should be quieter than the MPPSK exhaust.
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch Last edited by DrifterX; 05-16-2018 at 01:44 PM.. |
06-14-2018, 02:35 PM | #5 |
Rep 554
Im runnin mppk xh only in my new 440i ..
No issues .. Need 2 dyno & see diff .. Wil do som test runs with buds 340i mppk & see results. |
06-14-2018, 07:09 PM | #6 |
Rep 9,708
You are definitely overthinking the importance of the SK exhaust. A 240i comes with nearly as much power as an MPPSK 340i, yet it still has a very similar exhaust to stock 340i. Running the MPPK tune on stock exhaust will be fine. They are the same diameter pipe, and the CAT is more restrictive, which is unchanged.
kern4174464.00 |
06-16-2018, 10:31 AM | #7 | |
Rep 10,394
"Drive more, worry less. "
06-18-2018, 06:52 AM | #8 | |
Cheapskate
4464
Rep 4,995
06-18-2018, 10:21 AM | #9 | |
Rep 844
I mean, it’s right from the stick on top of this section.... “There's two ways to increase power - intake more air, or reduce back pressure allowing for faster air exit. With the previous MPPK (for the N55 engine) we went the route of more air intake, but for the 340i (B58 engine) we modified the the exhaust system to reduce back pressure and allow the air to exit the car faster, which together with the modified ECU, results in more power.” So I’m confused about why folks are saying the exhaust has no effect. |
06-18-2018, 10:42 AM | #10 | |
Cheapskate
4464
Rep 4,995
Right off the turbo you have a catalytic converter that is literally a series of screens and mesh blocking the air way. The MPPSK does nothing to change or remove that obstruction. And nothing in the catback system has that sort of obstruction in the sense that it would reduce back pressure by straight piping the exhaust. Keep in mind that BMW also claims that their aero package is specifically design to optimize the cars balance so you must install the front lip with the rear trunk lip and diffuser. Someone actually asked in another thread if it would throw off t he balance of the car by installing a front lip. But I think all of us understand that it's just marketing and the mperformance parts they offer are just for show. Basically all they are doing is forcing you to buy the exhaust with the tune because too many people were just buying the tune and then an aftermarket exhaust system for much less. |
jalkster220.00 |
06-19-2018, 10:59 AM | #11 | |
Rep 844
06-19-2018, 01:19 PM | #13 | |
Cheapskate
4464
Rep 4,995
c'mon dude. put the ///m tea down. It's not about "knowing better than BMW." It's about understanding simple physics, and the fact that nothing in the stock catback creates back pressure that is holding back power. Look at every tune on the market. There are tunes for stock cars, tunes for downpipes, and some even make tunes for intakes. Why isn't anyone making a tune for a catback? BMW saying that they specifically designed the MPPSK to run with their exhaust is no different than saying the stock tune was specifically designed to run with the stock exhaust. So what happens when you swap out the stock system without a tune? Does driveability suddenly go out the window? Is everyone that has an aftermarket midpipe on a stock car just driving a ticking time bomb? Are we leaving a bunch of hp on the table? Just think about it. Regardless, since you want facts, here's the inside of a stock F30 muffler. It's a straight pipe with holes in it to muffle the sound. Where's the obstruction? Where is the excessive backpressure? https://f30.bimmerpost.com/forums/sh...d.php?t=819125 And if you're one of the guys that thinks exhaust gases are just bouncing a round in there and limiting flow, there are plenty of articles and videos online that explain how exhaust flow actually works. Here's a good one. Start at 19:10 Hope that helps lift the veil. |
06-20-2018, 10:33 AM | #14 |
Rep 844
Okay, I guess all the info on the sticky is just BMW fake news, they have no idea what the MPPSK they designed does or how it works.
I guess I’ll believe you when you show me the dyno results of the MPPSK with the MPPSK exhaust and another without....on your car. Because I’m sure you have the courage of your convictions. Thanks also for the videos. Lucky that BMW didn’t make those or they’d be fake too. |
06-20-2018, 10:54 AM | #15 | |
Cheapskate
4464
Rep 4,995
You're hopeless dude. Reminds me of the guy that was convinced his suspension got stiffer in sports mode even though he didn't have adaptive suspension. You can put all the facts and evidence in front of a person, but if they want to be ignorant anyway theeeen.... |
06-20-2018, 06:12 PM | #16 | |
Rep 10,394
Catback exhaust is mostly about sound and maybe something like 5hp.
kern4174464.00 |
06-21-2018, 10:49 AM | #17 | |
Rep 844
06-21-2018, 12:14 PM | #18 | |
Cheapskate
4464
Rep 4,995
It's going to sound crazy, but with the maybe whole 2 dynos done that i've seen with the MPPSK, the chances of finding one with a stock exhaust or other aftermarket catback are little to none. Maybe you can find some dyno numbers that prove the catback is critical to making power with the MPPSK tune? Otherwise you're going to have to use your imagination on this one.
And no, I don't have wind tunnel test results to prove that an mperformance front lip with out the trunk lip won't throw off the balance of your car. You probably believe this one too. Clearly it's because of all the aerodynamic engineering that went into designing the part, not just BMW trying sell more parts in a package. https://www.shopbmwusa.com/PRODUCT/4...FRONT-SPLITTER Quote:
06-21-2018, 03:43 PM | #19 |
Rep 1,169
The difference between marketing as in the context under discussion here vs real accepted good practice like following the manufacturer's new car break in recommendations can be subtle but if one accepts F32Fleet's assertion that "Catback exhaust is mostly about sound and maybe something like 5 hp." I would point out that 5 hp is a significant amount of the 35 hp gain claimed with MPPSK, that is not just marketing. Just as a point of reference I will also point out OP stated the reason to remove the exhaust was to revert back to stock so that is 5 hp gone and not being made up for with a different aftermarket exhaust. Just throwing my two cents worth into the discussion, I got no dog in this fight.
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
06-22-2018, 07:28 AM | #20 | |
Cheapskate
4464
Rep 4,995
Also both AA and JB4 maps for stock engine setups make more power than the MPPSK. And that's with just a piggyback. So either the almighty BMW lack some competency in their own engine design, or they choked the power output which begs the question, why would an exhaust modification be needed anyway? Basically it comes down to the statistics, because your car and engine are constantly dynamic and performing in a dynamic environment. If sometimes it doesn't show a gain (even 1hp), then it's not creating a gain. There's too much noise in the system to truly identify what caused the improvement (or loss). This goes double when the science behind it proves that it doesn't make a difference. |
06-22-2018, 12:36 PM | #22 | |
Cheapskate
4464
Rep 4,995
There are multiple posts on here that explain why the exhaust isn't critical. NISFAN clearly explained how they were able to pull the same MPPSK level of power out of other B58 cars without the MPPSK exhaust. even babyboss said that there were no issues after removing the MPPSK exhaust and will try to get a dyno to pacify you. And I added the comment on aero mods because it is just another example of a bmw claim that isn't true, despite the reference that I linked. Go to the general section and you'll see another new thread started where someone explained how BMW says we don't have to rotate tires on our cars because the 50/50 balance means it's not necessary. I've read that before and, again, most people on here have the mental capacity to realize that it's not true. So like I said before, if despite everything on the table you still believe that the mppsk exhaust is critical to making mppsk power and everything else that BMW tells you, you're hopeless. Good luck on your future endeavors. I'll bow out now. |
