02-21-2019, 12:43 PM | #1 |
Rep 16
N55 Engine - *WTF* Misfiring and MAJOR SMOKE! (2015 640i Gran Coupe)
delete thread
02-21-2019, 01:29 PM | #2 |
Rep 1,137
Wish I had more insight on your issue to offer advice BUT....
In that 2nd video i noticed your rear BMW trunk emblem moved, is that aftermarket or is that how the 640i works?? |
02-21-2019, 01:32 PM | #3 |
Rep 173
Does the smoke smell sweet or like burning oil?
Wagner Competition Intercooler, ER Chargepipe, Fabspeed Catted Downpipe, Bootmod3 OTS Stage 2 93 oct
02-21-2019, 01:36 PM | #5 |
Rep 16
02-21-2019, 01:36 PM | #6 |
Rep 356
turbo =;(
SportySpice254.00 |
02-21-2019, 01:48 PM | #7 |
Rep 16
02-21-2019, 02:51 PM | #8 |
Rep 173
Turbos are oil cooled, when they fail, oil will get into the induction system and you'll burn oil like a mofo.... Get the turbo inspected, stop running/driving the car.
SportySpice254.00 |
02-21-2019, 02:54 PM | #9 | |
Rep 16
Here is why I haven't done it so far: I bought the car from a private party and sent the warranty transfer paperwork to BMW. It has to be notarized and costs $200. After this happened, I called BMW and they told me it takes 6-8 weeks to transfer the warranty. I am afraid to bring it to BMW before the warranty is in my name in the event it is something VERY expensive and BMW tries to get out of honoring the warranty. Thoughts? |
02-21-2019, 02:57 PM | #10 | |
Rep 173
02-21-2019, 03:00 PM | #11 |
Rep 16
Everything is currently in stock configuration. I was told by a few people it wouldn't make a difference since the mods downstream from the issue. Not sure what exactly that means... not even sure exactly what the issue is. Just want to play it safe
02-21-2019, 03:40 PM | #12 |
Rep 1,498
Anybody else catch that the OP says his N55 is a V6 twin turbo
02-21-2019, 05:14 PM | #14 |
Rep 16
02-21-2019, 05:19 PM | #15 | |
Rep 89
02-21-2019, 05:20 PM | #16 |
Yoda of mods
1691
Rep 3,004
Drives: X5 RWD
Find a new shop ASAP.
Current: 2020 Explorer ST (Agate Black Metallic) AWD, F15 SGM RWD
02-21-2019, 05:44 PM | #17 | |
Senpai
556
Rep 1,108
if it ever pulled downpipe codes, the dealership will see that as well.
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
02-21-2019, 05:56 PM | #18 |
Rep 16
What do you think the odds are he caused this issue? Asking because I’m clueless when it comes to this kind of stuff, hence why I brought it to him to modify and tune. I relied on his experience and knowledge.
Just a bad cooincodence or a direct result of his negligence? Under 50k miles, full inspection from BMW within last 6 months for the CPO warranty. No issues found at that time |
02-21-2019, 06:03 PM | #19 |
Rep 66
Could a careless downpipe installation and overtorque crack the turbo? Sounds like you have a failed turbo.
Interested in what happens. If you take it to the dealer with an aftermarket downpipe, you're toast in terms of any warranty. They'll blame it on that part, the installation, whatever -- and they have every cause to do so. It was fine until someone messed around in there, now its bad. The simplest explanation is usually the right one. Sorry bud. |
02-21-2019, 06:12 PM | #20 |
Rep 1,623
OldCrow7xx74.50 |
02-21-2019, 06:39 PM | #21 |
Rep 194
1. You need to get a list or invoice of exactly everything that was done to your car. Can't begin to figure out what might be wrong if you don't know what was done.
2. Don't go back to this shop. Just installing an AFE intake and ER catless DP even without a tune should not cause these problems. With the catless DP, you will get a CEL but that is only because the car is throwing an emissions code. Won't adversely affect the engine otherwise. Neither should the intake. (Assuming proper installation) *Note: Aftermarket intake is a waste, won't gain you anything but a lighter wallet. 3. That much white smoke from exhaust means coolant getting into cylinders so probably blown head gasket. Cause ould be vacuum leak from improperly installed intake and/or improperly installed downpipe causing the 02 sensor to read wrong. Either would cause the DME to try to make adjustments and engine would not run right. And if the shop took the car for a spin to test with an improperly running engine, bad things can happen. 4. You need to make sure when you have work done that you take it to a shop with a good reputation. And you should learn about your car, its engine and how it works. 5. I would put everything back to stock before you bring it to BMW. If not, they will void the warranty. |
02-21-2019, 06:49 PM | #22 |
Rep 360
I can't really agree more with what Space said.
The biggest thing here is just taking some time to learn what you're doing, what you're talking about, and what you're blowing your money on. There is so much unknown in this thread from your responses, the crappy shop you used to do the work on your car, and just the uncertainty in what is going on. It is your car, you spent however much you spent on it, and you have very little knowledge about anything going on. Not trying to be an asshole here, just saying to take some time to really understand what is going on so you don't have to go to forums to have people figure it out for you. that shop screwed you to put it lightly. definitely, echo what everyone else has said. Just put the car back to stock, pray they don't find any trail of you putting on the downpipe, and hope everything gets fixed under warranty. You could find a member that lives close to you that could do a better job of installing the parts that shop did, and for a whole lot cheaper I'm sure.
gran coupe m sport, head gasket, n55, smoke, white smoke |
