BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > Sim Racing > Looking for opinions on cockpits
      12-18-2020, 04:38 AM   #1
Mach550
Mach550's Avatar
Drives: 2019 M550i
2019 BMW M550i  [8.00]
Looking at getting in to a fanatec clubsport v2.5 setup and I'm trying to find a cockpit that will be stationary and not need to be packed away. Was looking at GT Omega which is around $400. Would like to stay under $500 but if it's solid and doesn't really flex when you're at 11/10ths I might go up to $1000 tops. Do not intend to mount a screen to it, just the wheel setup.
      12-22-2020, 08:54 PM   #2
440xiGCMSport2
Drives: EB440xiGC
In my opinion get something like the Simlab P1x set up with aluminum extrusion. This type of set up is stiff enough if you decide to go Direct drive and the flexibility in mounting of different accessories. Look for something similar if the P1X is more than you want to spend.
      01-01-2021, 10:02 AM   #3
Slow///1
Drives: F80, GT3, X7
I agree with the 80/20 direction. SimLab is a good option and there is a US based company called TrakRacer which sells locally.
      01-02-2021, 12:45 AM   #4
Mach550
Mach550's Avatar
Drives: 2019 M550i
If I don't intend to move up to direct drive is the extra $300 really worth it?
https://www.trakracer.com/product/tr...-2-wheel-deck/
https://www.trakracer.com/product/si...th-wheel-deck/
      01-02-2021, 10:58 AM   #5
440xiGCMSport2
Drives: EB440xiGC
in my opinion it is worth it because of the flexibility it provides in accepting different types of equipment setup. if somewhere down the road and something breaks or you upgrade it is easy to do.
Because extrusions are more or less standard(make sure company uses standard extrusions) that means even if the company you purchased from is no longer producing the same rig you can use a different companies product in attaching to your cockpit. This on top of the extra rigidity.
The Fanatec Clubsport plus steering wheel price comes really close to the Accuforce V2 price. It is a big step above in feedback.
      01-02-2021, 06:09 PM   #6
tszene
Drives: M4
I have a 2.5 fanatc wheelbase and the inverted v3 pedals. I had a playseat as a rig for 3 years but it flexed way too much. This Xmas I upgraded to the trakracer 160 with the triple monitor mount. Worth every penny if you race regularly. The assembly was lengthy but again, it was all worth it in the end.
      01-02-2021, 10:56 PM   #7
Dlpfcb
Drives: AW E92 M3
Dam! That's a setup
      01-03-2021, 08:33 PM   #8
440xiGCMSport2
Drives: EB440xiGC
If you aren't going with a DD wheel that trackracer 160 is more than enough for rigidity. if you do intend to go upto a DD wheel than spend a little more for the Simlab P1x. The wheel deck on the P1X is a lot stiffer due to design and material. The trackracer 160 wheel deck design is more like the Simlab Evo and reviewers have indicated that there is some flex with that design with the DD wheel. Also with a DD wheel go with a standalone monitor mount rather than one that connects to the cockpit.
      01-09-2021, 03:20 PM   #9
Maitre_Absolut
Maitre_Absolut's Avatar
882
Drives: M3 CS, Audi RS6
I have a Trak Racer RS6 and am 100% satisfied. The seat is very comfortable I've never had any sort of pain or need to get out after 2h+ sessions. Running Fanatec elite+ on it, not DD.
23 Audi RS6
23 BMW X3 30e Msport
18 M3 CS
17 Porsche Macan GTS
14 Audi S4
      01-12-2021, 08:27 AM   #10
Racer20
Drives: F80 M3, 228i THP, E46 ZHP
80/20 rig is really the only way to go IMO when you consider cost, rigidity, and adaptability. Nothing else can really compete. I just picked up a P1X and although it's not up and running yet I'm impressed with the quality.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
      01-21-2021, 06:01 PM   #11
Malakas
Drives: 2020 M2c
I have the Rseat chassis with the Clubsport gear and I love it. It's VERY robust. I think it weights 250 pounds.
