07-14-2021, 06:00 PM | #1 |
Rep 5,506
California will test for tuned cars with new SMOG requirement
Anyone know more about how they detect a tune? Also, if a car flashed back to stock and locked will show as a "tuned" car?
From what some other people said, it looks like they are looking at a CVN checksum value. https://www.roadandtrack.com/news/a3...g-smog-checks/
Auto Detailing Enthusiast!
07-15-2021, 12:45 PM | #3 | |
Rep 85
-Ryan H
07-16-2021, 10:09 AM | #4 | |
Rep 54
"Before your vehicle will pass a Smog Check, you must have the vehicle’s software restored to the OEM software version. Once the software is restored, have your vehicle reinspected by a licensed Smog Check station. Note that vehicles initially directed to a STAR or Referee station must return to the same station type to complete the inspection process." Looks like piggyback chips from reputable tuners will be the way to go. (i.e., DinanTronic Sport Tuner, JB+, etc.) Just unplug and pass SMOG. Plug it right back in after you pass.
2016 328i XDrive N26 8AT: K&N Drop-In Filter * GPlus FMIC * ER Chargepipe * DinanTronics Sport Tuner (Race +4psi) * AWE Midpipe (2nd Cat Delete) * Dinan Axleback Exhaust * Dinan Sport Springs * Megan Racing Front Strut Tower Bar * Cross-Drilled Rotors * Hawk HPS 5.0 Brake Pads * StopTech SS Brake Lines
07-16-2021, 10:13 AM | #5 | ||
Rep 85
OEM Orginal equipment manufacturer meaning you will need to go to the dealership and have them restock it it says it right there you looking at what you wanna look at, flashing back to stock on a flash tune the DME is still unlocked the dealerships can see that you don't think the government can? Lol
-Ryan H
07-16-2021, 11:43 AM | #6 | |
Rep 54
07-16-2021, 01:51 PM | #7 |
Rep 16,065
+1. I doubt that the test equipment will have the level of sophistication to detect if a tune has ever been used. All that's required is that OEM or California Air Resources Board (CARB) approved tunes are in place at the time of the test. This doesn't necessarily rule out tunes either, so long as they meet CARB requirements. Any tunes that do will undoubtedly make a point of saying so in their ads and on their websites.
BrysonDM53.00 |
07-19-2021, 12:56 PM | #8 |
Rep 5,506
Flashing back to stock and locking the DME should allow it to pass as it should be the OEM tune and have the same checksum values?
I assume any change from stock would trigger a different checksum i.e. flashed back to stock but DME unlocked?
07-20-2021, 06:02 AM | #9 |
Rep 144
Putting the car on a dyno and comparing torque & dyn HP graphs versus stock would be technically much more feasible and consumer friendly than using time consuming forensic methods for the sake of passing or failing state vehicle inspection.
07-20-2021, 06:16 PM | #12 |
Rep 376
I saw this message from the instagram of a tuner in CA (HD Tuning) that I follow. This is NOT my explanation, it's HD Tuning's. I'm not advertising, just re-pasting his explanation here in case this is helpful info. For brevity I only copied the parts that I thought were relevant, but you can check out their instagram post for everything.
** "The day we knew was coming is here, from my understanding even a stock file that has a single byte changed will fail automatically as its a CVN check. For those with end user flash tools, your stock file in that flash tool may get you past the dealership but won't pass smog. These obd2 flash tools leave a patch/signature so even with a "stock" file it will not pass emissions. Check with the tool manufacturer or your tuner to see if your flash tool removes all patches when reinstalling your stock calibration or you could be state refereed and need to challenge it........... If you have coding done to your car (sport button memory for instance) you still fail even though it has nothing to do with emissions it's just a setting preference. Putting the burden of proof on the consumer is absolutely bullshit. If you buy a used car that was tuned by a previous owner and set back to "stock," you could fail your smog and get refereed and in some cases even the dealership can't reflash the ecu if there is no update. This means that your car that has all monitors set and is running a stock file will fail emissions. A new ECU could be thousands of dollars with programming and that is not a burden the state should be putting on a huge number of car owners and enthusiasts......
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
08-05-2021, 03:50 PM | #13 |
Rep 73
Hard to read this stuff as one who loves cars and loves liberty and freedom. Not to get political, but all the more reason to pack up and leave.
2017 BMW 330ix MSport Estoril Blue - B46, ER Catless DP, ER Chargepipe, FTP Intake Charge Pipe, BMS Cone Intake, BMS OilCC, Bm3 Stage 2. FI Exhaust, xHP Stage 3 OTS Transmission tune. CSFRace heat exchanger. Performance M Brake kit. AFE Carbon Fiber D.A.S.
https://www.instagram.com/bfourtysick/ |
08-06-2021, 08:16 AM | #15 |
Rep 16,065
Totally ridiculous, as we've not seen anything official that comes close to the doom and gloom proffered by the conspiracy theorists and irresponsible sources only interested in drumming up page views. You can check the legality of aftermarket parts here:
https://www.arb.ca.gov/msprog/afterm...es/amquery.php |
08-06-2021, 03:23 PM | #16 | ||
Rep 906
I was a bit curious about this, so I think it merits some poking around. The smog test checks the car over generic OBDII, not the special Ethernet link BMW uses for E-Sys or ISTA. Using the generic OBDII functions of VCDS, I scanned my F31 328d N47 on Mode 9 (Calibration Identification) that is supposedly what CARB is looking at: Quote:
A few months ago, I VO-coded in 205 for a test drive and then coded back in stock 2TB, so the EGS module was definitely touched. So based on what I see, VO-coding back to stock doesnt alter the CVN. Please fact-check me.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
08-15-2021, 04:28 PM | #18 | |
Rep 5,506
Can anyone verify that CVN matching Calibration ID is what is checked? If so that would be a good check for anyone going to a SMOG appt.
12-23-2021, 12:41 PM | #19 | |
Rep 906
The dealer recently upgraded the I-Level on my car to F020-21-11-540, reflashing all the ECUs. I did another Mode 9 query and this is how it looks:
01-09-2022, 07:19 PM | #22 |
Rep 43
check this thread
