12-13-2021, 03:07 PM | #1 |
Rep 43
N55 Engine Swap Options
My '14 435i EWG, spun a bearing a few days ago at 82k miles, and I'm weighing my options on what engine to drop in, my engine code is N55B30M0, I'm wondering if a N55HP from a ActiveHybrid5 would work as a swap, or even an M2 N5530T0, without going into too much work, would any of these engines work as a swap?
If this isn't feasible, what should I invest into instead for a better engine ? Forged internals on the new drop in? Thank you and any advice is appreciated. |
12-13-2021, 06:43 PM | #2 | |
1296
Rep 3,532
zinner559.00 |
12-17-2021, 03:06 PM | #5 |
1296
Rep 3,532
slightly better engine components if you plan on making big power
12-17-2021, 04:00 PM | #6 | |
Rep 10,252
Polo088161610.00 |
12-22-2021, 12:17 AM | #7 |
Rep 75
Based on my limited knowledge, my build in your situation would be an N54 closed deck block and forged crank and rods and the S55 oil pump and pan. Aftermarket turbo of choice. Should be good to go after that. Should be able to handle 600+ whp easy. My 0.02
01-03-2022, 09:08 PM | #8 |
Rep 517
Drop a B58 motor in it
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
01-03-2022, 09:33 PM | #9 |
Rep 931
racemepunk8.50 |
01-04-2022, 08:10 AM | #10 |
Rep 1,111
Drives: 2015 BMW 435i Xdrive MSport
Close deck convert the N55 and forge thr motor and you'll never have issues again for big power. I'll be doing this from the start. Even some B58 rod bearing issues are popping up. These motors aren't indestructible. Thicwhips on YouTube spun a bearing in his B58.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
Pussiwillow521.00 |
01-04-2022, 10:57 AM | #11 | |
Rep 5,369
If I had the choice, I'd get the N55 M2. It will be EXTREMELY hard to find a salvage one though. The Active Hybrid N55 isn't worth the risk. It's likely quite different internally from the N55 used in the non-Active Hybrid cars.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
01-04-2022, 11:56 AM | #12 | ||
Rep 1,111
01-05-2022, 03:46 PM | #13 |
Rep 5,369
True. Also true is that a lot more stuff will break or be severely compromised in the long term if your plan is to push 600wtq through a stock block N54, N55, S55, or B58. The verdict is still out on the S58. None of these short blocks were designed to survive running 600wtq. A EWG N55 or an N54? Try 500wtq. Beyond that, you're really walking on egg shells with the stock block. The B58 has issues with it's plasma coated liners once you really start cranking up the power.
01-05-2022, 04:31 PM | #14 | |
Rep 1,148
01-05-2022, 05:08 PM | #15 | ||
Rep 1,111
01-05-2022, 05:26 PM | #16 | |||
Rep 1,148
Boostedphil698433.00 |
01-05-2022, 09:11 PM | #17 | ||
Rep 43
01-05-2022, 09:20 PM | #18 |
Rep 3,695
An M2 short block from BMW is $13k.
Just out of curiosity, what do you all think the all in cost is to source and rebuild an M2 block? With 540wtq I’m hoping I don’t have to find out someday, but you never know. |
01-05-2022, 10:51 PM | #19 | |
Rep 1,148
You'd be fine at 600wtq if you move torque further into the rev range, and or not completely beat the hell out of the car, launching etc etc, roll into it etc. Shit wedge performance m235i dct swapped made 700+ wtq and he ran many runs, no idea about it now, tho. Ends up depending how well the tune is set up. |
01-06-2022, 03:07 AM | #20 | |
Rep 43
You'd have better luck getting a m235i core |
01-06-2022, 03:13 AM | #21 | ||
Rep 43
It really does just depend on how serious you are with maintenance and your driving. Given I beat the hell out of mine, I still never thought I would have seized mine after only putting 20k miles on it (acquired at 60k) (Full FBO, E40, MHD for 4–5k~) |
01-06-2022, 10:55 AM | #22 | |||
Rep 1,148
I think if mine goes, I'll hunt down an s55 and dct since the car is paid off and is my fun car, I drive it once a week so I can have it down if need be ha. |
