08-19-2019, 04:20 PM | #111 | |
Rep 114
Well might be a hard reset - could help with a lot of issues. |
08-20-2019, 08:28 AM | #113 | |
Rep 67
i did not notice any change, my dashboard application is still not updating the doors (open/close), speed and rpm. other values like temp, capacity and seatbelt are updated tho. MCUVer: 415144bLZH-NBT-HW7-190402[B1280_170325] FrameworkVer: 9 PQ2A.190305.002 eng.work2.20190724.190747 AndroidVer: 9 AppVer: 2019072501_1280x480_970 |
08-21-2019, 02:15 AM | #116 | |
Rep 54
From other stores it seems that you can have 1920 and the old grey screen, or 1280 and the newer blue light/antiglare or deeper black screen. Considering its 10" screen, I think that I would rather have a lower resolution, but deeper blacks and anti-glare. |
08-21-2019, 09:04 AM | #117 |
Rep 21
Hello Friends.
After some trouble and Bugs with my Android 9.0 unit my vendor send me newest Firmware thats are aviable for these units. After the Update the unit feels so much fast and smooth. Everything working now. Finaly stable Internet and bluethoot conection and i wonder the screen is now a little bit brighter. With old Firmware some colors and pictures was dimmer and darker. Now iam in love. Here is the New Version. |
08-21-2019, 09:45 AM | #118 | |
Rep 114
08-21-2019, 09:58 AM | #119 | |
Rep 1,048
sincerely Chri |
08-21-2019, 10:52 AM | #120 |
Rep 153
08-21-2019, 12:07 PM | #121 | |
Rep 21
with msm8953 Chip and 8 Core CPU. I can share link soon because i have to upload the Firmware. The size big is arround 1.4 GB. In the past in a other thread you promised to me make an instruction for rooting this unit because i wanted to edit the icons with Photoshop of the bad looking id7 Menü. But never heard something about you Greetz Last edited by blackDMX; 08-22-2019 at 08:54 AM.. |
08-21-2019, 12:35 PM | #123 | |
Rep 114
Hope you can do it and help us all. Regards |
08-21-2019, 12:41 PM | #124 | |
Rep 1,048
i wanted to check the root access routine to my device before releasing it but i was not able to re install my ota image so i did not know what had to be done exactely :/ with a new image i can do the procedure again to verify what exacteley is needed Chri |
08-21-2019, 08:22 PM | #126 |
Rep 114
I think you are right .
But I remember there is a method to unlock LTE bands on any Qualcomm modem . In Snapdragon unit , there is X9 LTE modem . https://forum.xda-developers.com/gal...-qxdm-t3785458 Now, it remains problem of antenna - which might not be supplied with the unit . Owners can confirm if there is an antenna or not. |
08-22-2019, 04:08 AM | #127 |
Rep 10
I just received the newest Zlink.apk for Carplay. Maybe somebody will try it, if its working without the internal CarPlay function. It requires an internet connection during first start.
https://we.tl/t-tfTVhQaAHX |
08-22-2019, 05:06 AM | #128 |
Rep 1,048
I also just got link for 2.4.5 Update for Snapdragon unit
i`ll try to update and redo the root procedure, and then will post it here, but will be next week, i`m the rest of the week on road. Chri |
08-22-2019, 06:12 AM | #129 |
Rep 500
Thanks guys for the update on Snapdragon unit. Also, can anyone compare the audio quality on FLAC compare to NBT unit playback. Is it on par with NBT? Also mention there is DSP build in so can we use that to fine tune the EQ? I might pull the trigger on Snapdragon 4Gb unit.
08-22-2019, 06:42 AM | #130 |
Rep 220
Drives: MINI Cooper, 2020 X1
Would be somebody willing to post a link for 2.4.5 Update for Snapdragon unit here?
08-22-2019, 07:55 AM | #131 |
Rep 54
Before I invest in one of these I'm hoping for some opinions:
I have an x1 E84 with Business Nav & CIC btw 1) Is the audio quality any better than the earlier units? 2) Does it still need the 3.5mm aux (another audio quality related question), as it seems that some do, some don't? 3) Did everyone get the black bezel unit or silver bezel unit (assuming its not embedded in your dash)? 4) what about the much hyped black screen / blue light anti-glare? Is the screen noticeable darker than the Android 4/7/8 versions 5) Anyone have the 8 core snapdragon one and a UI other than ID7? ie does it also include the earlier interfaces? 6) Do they have an optical out (Toslink)? 6) Anyone from UK buy from aliexpress and get caught for import duty? 7) Anyone using a GPS splitter cable so they can use the existing roof mounted GPS antenna? 8) Is there anyway of using the vehicles microphone for calls? 9) I'm going to running DAB, airplay/android auto, and possibly a 4G dongle. Can I use a selfpowered USB hub? |
08-22-2019, 08:06 AM | #132 |
Rep 67
just buy from a seller with europe stock (spain, italy, poland) 7) Anyone using a GPS splitter cable so they can use the existing roof mounted GPS antenna? yes, works perfect, i use something like this: https://www.realmediashop.de/FAKRA-A...PS-DAB-DVB-GSM fakra splitter + fakra to sma |
Zack1uk11.00 |
