05-29-2017, 02:27 PM | #1453 |
Rep 1,976
Drives: 2020 G20 320i M Sport
It's more like 190% now since we now have ID5 almost at 100%
Yes, 1lyfe needs to change the title as that was my car several years back.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
Almaretto2374.00 |
05-29-2017, 03:00 PM | #1454 |
Rep 25
Has anybody tried an NBT retrofit in a car that already has the widescreen CIC? Does it just require a head unit and idrive controller replacement? Or is there more work to it
05-29-2017, 03:45 PM | #1455 |
Rep 8,364
05-29-2017, 03:47 PM | #1456 | |
Rep 1,976
But yes, you can keep the CIC screen for NBT but you will need to rewire the USB, Amp, Bluetooth and Microphone.
07-22-2017, 02:29 PM | #1457 |
Rep 21
Help with Retrofit 2016 NBT EVO HU on my 2013 F30
Hello, Bimmer Users.
I just got the NBT EVO HU from a BMW breaker. It was removed from a 2016 F30. My F30 is late 2013 and has the business nav and I'll like to retrofit the NBT EVO HU on it I managed fixed the 2016 idrive touch controller to my F30 but no touch just knob control. MY QUESTION
Pictures of my OLD unit + NBT EVO below. My VIN is WBA3D32090J384786 Your response is appreciated. Cheers. |
07-23-2017, 08:31 AM | #1458 | |
Rep 40,720
So, you will need both Emulator and a bunch of Coding to convert car from CHAMP2 to EVO head Unit.
07-23-2017, 08:48 AM | #1459 | |
Rep 21
Looks like I'll have to look for some one local to help with this retrofit + coding except I can get the kits and links to order online. If its too complex I might just go for an older version for the ease of retrofit? do you have part numbers or links to where I can buy the emulator kit to get them connected? Is there any major downside to retrofitting the NBT2 on my F30? Cheers |
07-23-2017, 08:59 AM | #1460 | |
Rep 40,720
NBT rather than NBT2 EVO would be easier as it has GPS connector. If car has TCB module, your Telematics will continue to work, but if car has Combox for Telematics, you will not have functional Telematics with NBT either.
07-24-2017, 10:42 AM | #1461 |
Rep 1,976
Whatever you do, DO NOT connect that head unit to the car without an emulator otherwise you will end up with a bricked head unit.
If you already did and it says "No Signal" on the screen, it will be very difficult to get it out of lock down mode. It's happened on ours a few times and in some cases, it will be irreversible.
07-24-2017, 08:30 PM | #1462 |
Rep 56
Can any tell me he part number for the Screen connector wire to the box? Usually a purple/pink color on the units, but sometimes the wire connectors come in green. The two top pins broke, and now I cannot get power/info to the screen. Need a new wire and not 100% sure what to buy.
08-25-2017, 03:49 PM | #1463 |
Rep 5
Hi,
I am also planning to change the Champ2 Navi Business to a NBT EVO on my 2013 F31. Unfortunately I have a combox, so what I understood from all These threads on here, this will be some wiring work needed. There are just emergency call and teleservice, no CD Services, so I think this will be OK. I plan to go for a FSC set. What I am struggeling with is the correct Hardware. I really want to have the new ID5/ID6. Since I don't have a TCB or ATM I will Need a head unit with internal GPS correct? Is the ATM or an emulator needed even if I use Hardware with internal GPS? I have seen HW2.3 B140 with GPS and HW3.1 from G30/G11 with GPS. What will be the best one for me? Perfect would be Hardware with 4GB Ram. Is HW2.3 also available with ID5, perhaps B240 versions? Hope you could help me with this. Regards, Sven |
09-08-2017, 11:25 AM | #1464 |
Rep 30
Hi all quick question I considering doing the upgrade to NBT Nav,
I have Business Nav currently along with a Combox and HK Sound system I understand I have to isolate out the combox and install new antenna for GPS and blutooth etc.. Does anything special need to happen to make the HK system work after the conversion either coding or remote activation wires for the amp ? Many thanks |
09-08-2017, 03:12 PM | #1465 | |
Rep 1,976
If the donor vehicle had stereo or Hi-Fi, you will need the NBT HU coded to use HK as the signal routing is different on these sound systems. For Bluetooth and USB, you will need to reroute the existing cables and antennas from the combox back over to the HU. We usually provide new ones to our customers so there is no need to tear up the carpeting or removing your seats. You're also going to need to run a new mic cable directly to quad lock for the Bluetooth Phone and voice control to work. The combox will either need to be coded out or you can use a most loop closing ring to terminate the combox. Also for HK, if you're using an emulator, don't forget to move the most optical cable from your existing quad lock connector over to the emulator otherwise there will be no sound.
09-08-2017, 03:19 PM | #1466 | |
Rep 1,976
If you can get hold of the G30 unit with GPS I would say that's your best bet. Please check my previous post in regards to the combox.
09-09-2017, 06:23 PM | #1467 | |
Rep 21
http://www.germaniks.com/ My 2013 F30 is taking a new shape one step at a time. Next is to complete the reverse camera, adaptive LED, and 6WA Cluster ... See pictures below. I had to do the following
09-10-2017, 02:15 AM | #1468 | |
Rep 30
Great job I'm considering the same myself couple of questions What emulator module did you use ? Did you use the original mics or just run new ones ? Is your com box totally disabled now ? Did you use existing gps and Bluetooth or run new ones ? What coding was required did you do it ? Many thanks Steve |
09-12-2017, 04:18 AM | #1469 | |
Rep 21
09-20-2017, 12:35 PM | #1470 | |
Rep 40
09-20-2017, 10:44 PM | #1471 |
Rep 1,976
You can either use a most loop adapter to close the loop after pulling the plug on the combox or you can keep the combox plugged in but disable BT and USB via coding.
09-21-2017, 08:34 AM | #1472 |
Rep 40
10-31-2017, 11:15 AM | #1473 | |
Rep 17
Can you confirm this steep to deactivate combox? BT_EIN_AUS nitch_activ A2DP_AVRCP_EIN_AUS nitch_activ HANDSFREE_SECONDARY nitch_activ VCARD_OVER_MOST nitch_activ API_EIN_AUS nitch_activ USB_HUB nitch_activ API_TWO_USB nitch_activ |
11-12-2017, 03:17 PM | #1474 |
Rep 3
Just wondering if someone could give me a little help. Ive just purchased a used 2012 320D with nav, bluetooth and the usb port but it doesnt do Bluetooth audio streaming, just the basic bluetooth. I have done a vincheck and it decodes to say i have;
S606A Navigation system Business S6NHA Hands-free with USB interface I dont have possession of the vehicle yet so cant check if it has a combo box installed, would I be able to do the EBT? Can someone PM me or give me a rundown. |
