04-12-2019, 09:56 AM | #89 |
Rep 14,115
Drives: G82 M4C X-Drive
Spacers give you a wider stance and is mainly for aesthetics. In most cases handling can be adversely affected because of the increases scrub radius and reduced spring rate effectiveness at the wheel which more than likely cancels out any traction benefits from being 20-30mm wider. I found that I did not like how spacers affected my F80 handling characteristics. They look great and make a big difference in the aesthetics and enjoyment of the car in that department but ideally, they should be run on the street and removed for high performance driving on a track. They are also restricted on some track days which should tell you something.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
RMachuca3d723.50 |
04-12-2019, 01:57 PM | #90 | |
Rep 38
I have a 320 sport line... I don't track or race and I am not looking for performance. Will it affect the handling at a point where I don't like to drive my car and feel it doesn't turn right or something? |
04-12-2019, 02:11 PM | #91 |
Rep 14,115
I had it on my F80 for canyon runs and did 77 laps at Willow Springs... while it wasn't as sharp with it, it was still very fun and driveable. Granted, I had aftermarket suspension which was slightly stiffer.
01-04-2020, 01:26 AM | #92 | |
Rep 46
I have these tires and they are "ok". They have a little bit of a squishy feeling to them. I got used to them now after a year or so so I'm not noticing it as much. The ride IS smooth, the grip is decent (but not better than more expensive products). |
01-17-2020, 11:25 AM | #94 |
Rep 79
I've had them for a couple years now on my supercharged 350Z, they're decent, especially for the price. Pretty progressive and audible on breakaway. They're basically the next generation of the Bridgestone RE760, which was a pretty good tire in itself. For the price, they're a pretty good consumable for track days. Not as sticky as the more expensive rubber, but they'll take a beating and last a while if you're not racing a clock.
02-13-2020, 06:59 PM | #95 | |
Rep 165
02-16-2020, 05:53 PM | #96 | ||
Rep 165
02-18-2020, 04:31 PM | #97 |
Rep 165
Firehawk 500's
What series BMW ?
02-18-2020, 05:23 PM | #98 | |
Rep 165
02-18-2020, 05:42 PM | #99 | |
Rep 7,606
When i got my PS4S installed at Costco a couple of weeks ago, they called me right after they pulled the car in and asked me if i knew i was installing non RFTs in place of RFT. Of course i said yes (that's the point, lol) and they acted like i was crazy saying that i don't have a spare and would have to get the car towed if i got a flat, but they still proceeded with the install without a hassle. |
02-19-2020, 11:40 AM | #100 | |
Rep 849
Drives: BMW 435i
I'm hoping a couple local independent shops won't have any issues. If nothing else I'm pretty sure the speed shop which sponsors our local SCCA autocross events will do any tire work I need, but they are an hour drive away.
02-19-2020, 12:42 PM | #101 | |
Rep 7,606
There were numerous options for different load rating, speed rating, etc, even within the same exact tire size. FWIW, i went from runflat to non-runflat and i also went to a non-OEM size (changed fronts from 225/40/19 to 245/35/19) and Costco installed them without issue. I think i went to a higher speed rating and load rating. |
02-19-2020, 01:01 PM | #102 | |
Rep 109
Now back to the tires, I have them on two of my cars. They are more than fine for my GT. Ride quality and handling are both fine for what i do with the car. The price is real nice. On my other car, i will be getting something a bit more sticky as i break traction 1-3 with them. not worried about 1-2, thats going to happen but I want something that hangs on a bit more in 3rd. |
02-19-2020, 01:44 PM | #103 |
Rep 79
Remember to ask about the friends and family discount. It's been worth 15% a few times for me.
02-19-2020, 07:17 PM | #104 | ||
Rep 165
02-20-2020, 12:36 PM | #105 |
Rep 14,115
I'd like to update my response to this. The adverse effects of spacers are minimal with reasonable widths. What will affect handling is changing the ratio of track width front to rear. You can change grip rotational characteristics this way. This is mostly for those who track their car and are going for PB lap times.
alohasurftoad3078.00 |
02-22-2020, 09:50 AM | #106 | |||
Rep 165
Indy 500's
I am now starting to think about whether or not there will be any issues with the TPMS. I guess I'll find out on Monday. Have a nice weekend. |
02-22-2020, 01:19 PM | #107 | |
Rep 7,606
1. The tire seal/plug kit. BMW M cars come with one OEM. 2. BMW OEM space saver spare, which fits over M brakes. IIRC it was around $350 (tire and wheel) What are you worried about with TPMS? As far as i know mine were reused between my RFT and my PS4S when they were changed. Changing the tires should not affect the TPMS, unless you were saying you were concerned about what happens if you get a flat on a non RFT? Last edited by thejeremyman9; 02-24-2020 at 12:30 PM.. |
02-22-2020, 11:54 PM | #108 | ||
Rep 165
02-24-2020, 12:31 PM | #109 | |
Rep 7,606
02-26-2020, 12:15 PM | #110 | ||
Rep 165
