04-11-2020, 12:25 PM | #1 |
Rep 1,282
122004 dv error
I am running the turbosmart dual bov on my n55 and I am getting error 122004 diverter valve cable error code. The check engine light isn't on but I believe it's a shadow code. Could it be when I installed it that it left error in the system? I forgot to disconnect the battery when I installed it.
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
04-11-2020, 01:27 PM | #2 |
Car Hypochondriac
335
Rep 901
Could always try erasing the shadow code and see if it comes back. If it doesn't, it's likely from installation.
04-11-2020, 01:53 PM | #3 |
Rep 7,606
Not sure if it helps but i got shadow error codes for my MAF when i unplugged it without disconnecting the battery or letting the ECU go to sleep (i had to pull my intake to do boost leak check). I cleared them and they never came back.
So +1 for saving the codes, then clearing and seeing if they come back. |
oma3710194.50 |
04-14-2020, 08:30 PM | #4 |
Rep 1,282
Deleted it and it came back. 122004 diverter valve disruption cable. Ugh! If cable is disconnected wouldn't I get engine malfunction?
04-15-2020, 05:36 PM | #5 |
1296
Rep 3,533
yeah, of course you would.
06-16-2020, 06:06 PM | #6 |
Rep 354
Getting the same error. 122004 Recirculation valve, control: line interruption. I have the turbo smart plum back installed. Did you ever get this resolved? Was there a disruption in the cable?
06-16-2020, 08:32 PM | #7 | |
Rep 1,282
I checked the cable and it was all good. No issues so far.
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ Last edited by oma3710; 06-17-2020 at 07:35 AM.. |
MAKH 588.50 |
06-20-2020, 12:24 PM | #9 |
Rep 7,606
They both should hold pressure fine. The only potential drawback to the GFB is that there might be maintenace required. So on the long term, the turbosmart might be the better solution, but it hasnt really been out long enough to prove itself yet either.
06-20-2020, 04:51 PM | #10 | |
Rep 764
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
06-20-2020, 06:52 PM | #11 |
Rep 1,105
06-20-2020, 08:02 PM | #12 |
Rep 7,606
06-21-2020, 07:01 AM | #13 |
Uhh... Khakis?
54
Rep 155
I’ve had both and my GFB+ did need maintenance. Without applying oil fairly regularly it begins to stick. I replaced it with the Turbosmart dual port because it’s a pain in the ass to get to it and I didn’t want to hassle with the maintenance. I haven’t had any issues so far with the Turbosmart.
I wish I had more information on a potential fix but mine didn’t generate an error. Could be dual port vs. plumb back but not sure why that would be an issue. |
ozymandias435142.50 AmuroRay2275.00 |
09-18-2020, 02:34 PM | #15 | |
Rep 2,639
I got mine installed today and popped the same code.
09-18-2020, 03:18 PM | #16 |
Rep 325
I made a thread recently about a code I was getting after my plumb back version was installed. It was also not throwing a cel just a shadow code. It was a code for bov jammed closed. I found out that it was throwing that code because it's a stiffer spring dv then stock so it flutters under very low boost instead of completely opening. I have had zero actual issues once I found out that it was a harmless code and it was operating properly. I will be installing a pure stg2 turbo when ever it gets here so I'll have the turbosmart dv back out so I'll look it over just to be sure.
09-18-2020, 03:26 PM | #17 | |
Rep 7,606
09-18-2020, 04:12 PM | #18 | ||
Rep 325
MAKH 588.50 |
01-14-2022, 09:21 AM | #19 |
Rep 5
I have been getting the same code on the 2011 550i, started a year ago after I installed the TurboSmart blow-off valves. Emailed TurboSmart but got no reply. If I drive the car daily I do not get the code but any time the car sits more then 36-48 hours then I get the 122004 code. Frustrating
