BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > M4 Rims (437M) on F30 FINALLY!!!!! added more pics to pg3
Studio RSR
      02-01-2021, 01:12 AM   #419
misguided_will
misguided_will's Avatar
Australia
57
Drives: 2018 BMW 340i M Sport
Originally Posted by MBP1988 View Post
How much are you guys buying the rims for? Is $2000 a reasonable price for a set with minor scratches?
I paid 1900 with 4s tyres and a few very very minor scrapes.
      02-06-2021, 06:15 AM   #420
Belong
Drives: E60 m5, F81, m550d
Awesome!
      02-06-2021, 09:00 AM   #421
misguided_will
Australia
57
Originally Posted by Belong View Post
Awesome!
https://www.ebay.com.au/itm/373450218176
2k in melb but doesn't describe the condition well.........
      04-03-2021, 08:25 AM   #422
M3Dreams
Drives: F83,F30340,E82135,E90M3,E46330
This thread helped me a lot on my decision, so thought I would add to it. Here is my 2016 340i xDrive with Michelin Pilot Sports in 225/40/19 (Fronts) and 255/35/19 (Rears) sizes. The car looks awesome, and has somewhat gone from plain Jane to a head turner. I am also running KW Street Comfort coil overs lowering the car by 25 mm all four corners. No rubbing at all. Tires look a bit stretched but nothing absurd. Wheels sit very slightly poked out, would have been great if they were 5mm less offset, but again something very minor and only a trained eye can spot it. These are OEM Ferric Grey 437M wheels off an M3.
      07-29-2021, 04:28 PM   #423
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
Hey guys … just got a set of 437M for my 328i RWD with stock m sport suspension and m performance brakes
Do you guys suggest
245/35 r19
275/30 r19
I am even thinking of 285/30 r19 for the rears but again have a doubt whether 328i will have enough power to push 285?
Thanks.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
      07-29-2021, 10:35 PM   #424
weehe126
Drives: 2017 340i
Do you guys suggest
245/35 r19
275/30 r19
Thanks.
Im running 245/40 and 275/35. The fronts rub a little on the fender liner when turning, it also rub ever so slightly at the top of the fender on dips. Rears rub the fender over large dips. This is on stock msport suspension as well. It's not enough rubbing to cause issues, but I will eventually increase camber in the rear and get camber plates for the front. I wanted to do 285 in the rear as well but really glad I didn't. This is also with RE71r tires which run wide. MPS4 275 didn't rub in the rear. The M437 offsets are 5mm too aggressive.
      08-13-2021, 02:03 AM   #425
CMCinAZ
Looks sweet!
      08-17-2021, 03:53 PM   #426
nicksgaragesocal
Drives: 2013 BMW 335i F30
245/35/19 front 265/35/ 19 rear lowered on H&R Sport Springs... look perfect and still very comfortable for a lowered BMW. Check it out on my insta for more pics: @NicksGarageSoCal
      08-29-2021, 05:45 AM   #427
menjo
Drives: bmw 330e
nice!! i cant tell from the pics but so with your stock tires
      09-09-2021, 04:27 AM   #428
clart
clart's Avatar
36
Drives: F31 330d
Just about to get a set. They are off an M4 so have tyre sizes. Will these fit?
Fronts 265/35/19
Rears 275/35/19
He's also including some 255/35/19s
I'm on stock adaptive suspension on an F31 2014.
They come with TPMS do i have to do anything to get the new ones working when i swap the wheels?
      09-09-2021, 11:39 AM   #429
alohasurftoad
Drives: 440i gran coupe w/mppsk
Originally Posted by clart View Post
Will these fit?
Fronts 265/35/19
Rears 275/35/19
He's also including some 255/35/19s. I'm on stock adaptive suspension on an F31 2014. They come with TPMS do i have to do anything to get the new ones working when i swap the wheels?
265/35/19 up front will rub the liner while turning. you wlll need to install the 255/35/19 up front and move the 265/35/19 to the rear wheels in order to keep the front and rear diameter difference at or below 1% for x-drive.
there are two different tpms available for our cars. they have different valve stem caps. if the tpms valve stem caps are the same as you have on your car, they will work when you reset the tpms through i-drive. if the caps are different, the tpms wont work.
      09-09-2021, 11:47 AM   #430
clart
clart's Avatar
36
Drives: F31 330d
I don't have x drive.
Was thinking maybe 255 front and keeping 275 rears? dependant on poke.
      09-09-2021, 11:57 AM   #431
alohasurftoad
I don't have x drive. Was thinking maybe 255 front and keeping 275 rears? dependant on poke.
yes, if no x-drive you can do whichever rear size you like better.
      09-09-2021, 11:58 AM   #432
gameson
Drives: 2015 BMW 320i N20
M4 rims looks really nice on an F30, just wow. absolutely perfect
      09-12-2021, 07:13 PM   #433
freespirit
freespirit's Avatar
83
What tires are you running on them? PSS?
      09-16-2021, 04:18 AM   #434
clart
clart's Avatar
36
Drives: F31 330d
So I've finally got some 437m wheels.
I've decided on 265/365 at the back but i'm unsure whether to go 235/40 or 235/35 at the front. I was looking at 245/35 but there doesn't seem to be any stock anywhere. Michelin must have been hit hard by the pandemic
Stock adaptive suspension with no plans to drop at the moment.
Any photos to compare 235/40 and 235/35?
      09-16-2021, 07:55 AM   #435
Randy Johnson
M340i
Randy Johnson's Avatar
Drives: BMW M340i
2021 BMW M340i  [10.00]
Wow!!! Now this looks perfect to me. Perfect amount of lowering with these wheels.
      09-17-2021, 12:34 AM   #436
nicksgaragesocal
I wish! Just running Hankook Ventus V12 Evo 2's
      09-26-2021, 07:45 AM   #437
clart
clart's Avatar
36
Drives: F31 330d
I’ve just put the rears on that have 275 35 tyres on and the poke is ridiculous on my f31.
It’s at least an inch past the body - was thinking about 265 but not sure it will make that much difference ?
      09-27-2021, 07:52 AM   #438
clart
clart's Avatar
36
Drives: F31 330d
hmmm
      09-27-2021, 09:35 AM   #439
freespirit
freespirit's Avatar
83
hmmm
I will be loading 437m with 265/35 rears on to my f30 in a couple of days. Will keep you posted with pictures on how it looks so you get the idea.
      09-30-2021, 05:21 PM   #440
freespirit
freespirit's Avatar
83
hmmm
So with 245/35 at front and 265/35 at rear, there is like one forth of an inch poke at both front and rear. Not sure how others managed it. Here are some pics
437m, f30, rims, wheels
