06-22-2021, 09:09 AM | #1 |
Rep 923
Coding backup camera to stay on in neutral?
I back out of my garage with my 2016 340i and when I put it in reverse to get out, the backup camera comes on.
But, as my driveway slopes down, I drop into neutral and keep rolling back to the bottom where I stop before getting onto the street because I have shrubs blocking my view. Every time the backup camera turns off as soon as I stop and I have to turn on parking assist and then the backup camera. Do you know of a way to code it to keep it on until I turn it off or go into a forward gear?
06-22-2021, 09:13 AM | #2 | |
Rep 562
Drives: 2017 BMW 330i xDrive
But, you can mess around with it in Bimmercode. It's under rear electronic module. Down near the bottom, you'll see rear view camera speed and distance switch-off threshold. Mine are set to 15 km/h and 10 m respectively, but can go as high as 50 km/h or 250 m. Just above that, there's also a setting 'activate PDC when rolling backwards'. Mine is on not active, but you might change yours to active and see what it does.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
dmaxdmax417.00 |
06-22-2021, 11:56 AM | #4 |
Rep 923
I like the 'rolling backwards' option. Seems like it should do what I want!
Thanks for the pointers, guys!
06-22-2021, 12:28 PM | #5 | ||
Rep 849
Drives: BMW 435i
I can back up and the camera stays on after backing up whether I'm in reverse, neutral, or 1st gear.
06-22-2021, 12:44 PM | #7 | |
Rep 562
06-22-2021, 01:34 PM | #8 |
Rep 16,054
You can even code the camera to stay on, and to be able to turn it on from the console switch at any speed. This is useful if you've got cargo blocking the view of the rear view mirror. I did that using ESys, I don't know if it's possible with Bimmercode in expert mode.
06-22-2021, 01:42 PM | #9 | |
Rep 562
06-22-2021, 01:49 PM | #10 | |
Rep 259
Garage:
2020 F32 440i 6MT 2018 Mazda 3 6MT 2013 Mazda 3 6MT 2008 Honda Oddyssey |
06-22-2021, 02:11 PM | #11 | |
Rep 923
Appreciate your thoughts!
06-22-2021, 03:42 PM | #12 |
Rep 16,054
With ESys you code the REM CAFD lines for distance and speed from FF to 00.
Be aware if you do this the camera doesn't turn off after you've been in reverse, you have to change the iDrive view to whatever you normally have running. |
auburnf30x434.50 |
06-22-2021, 04:07 PM | #13 |
Rep 4,870
Wouldn't it just be easier to leave it in reverse and keep the clutch depressed while you roll down hill?
Not sure what you are saving by popping it into neutral, stopping and then back into reverse to get onto the street. You are wearing your synchro's much faster than that throw out bearing. |
dmaxdmax417.00 |
06-22-2021, 05:40 PM | #14 | |
Rep 923
I'm going to try coding soon-ish and see if either 'on when rolling back' or 'always on' works for me and will report back.
06-29-2021, 04:33 AM | #15 |
Rep 923
That did it...thanks for the ideas!
I've increased the length of the 'roll' from 10m to 100m and also selected "turn on when rolling back"--my camera stays on for when I need it. Thank you all so much!
