BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Millway Camber Plates
European Auto Source (EAS)
      04-19-2019, 07:51 PM   #1
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
Just got these delivered today. I ordered directly from Millway's website since I couldn't find any distributors in the USA and they were pretty cheap to begin with (currency conversion comes to less less than $380USD shipped from Sweden). They took exactly 2 weeks to get here. (ordered on 4/5).
http://www.millway.se/camber-plates-...0-f31-f32.html
I chose these because they are quite a bit cheaper than the other options from US companies. Millway sells replacement bearings in case they inevitably begin making rattling noises, but I've also seen some good reviews that mentioned they were completely silent. They are also the preferred camber plate for Ohlins so that was about all the motivation I needed to pull the trigger.
Everything was received in good shape and packaged well. I also ordered a millway sticker because it was like the equivalent of 10 cents, but they threw in about 10 extra no complaints.
http://www.millway.se/decal-millway-motorsport.html
They are pretty substantial in size and seem good quality. The only thing I don't like is that they use screws for mounting instead of nuts and studs. It'll be harder to line up this way but not impossible.
Install pics and initial impressions coming soon.
andino132.00
Wai32861.00
Logicoeur260.50
      04-21-2019, 01:23 AM   #2
FaRKle!
Drives: '17 328d Sport Wagon
Looking forward to your experience and if NVH increases (and what it's like).
      04-21-2019, 04:31 PM   #3
kern417
Cheapskate
Install went pretty smoothly. I forgot that our cars have alignment pins, and Millway includes those 2 set screws that act as locators when lifting the plates into position. So no issue with getting screws threaded.
The only real task is to swap the swivel bearing over from the bottom of your OEM bushings. See pic for reference. On their video, they easily pull it off the OEM part but I had to pry it off with a screw driver. You also have to determine with top nut works for yours. On my KW V1s, I needed the 12x1.25
Currently have it set to 0.5*ish over the factory setup, so I'm around 1.9* of camber. I did a DIY alignment in the garage and everything drives straight. We'll see how it holds up after I get some milage on the setup.
Hardware:
Before:
After:
So far there is slightly more NVH. I can feel and hear road imperfections that I didn't notice before. It's not jarring, but noticeable.
No rattling or metallic noises, but I only have all of 10 miles on the plates. We'll see how it's doing after a few months. They also sell replacement bearings, so it's nice to know I could swap them out if (When) it begins making noise in the future. The real question is how often that'll be. If it's every few years, I can deal with that.
FaRKle!739.50
Logicoeur260.50
alexng72134.50
      04-23-2019, 12:20 AM   #4
alexng72
Drives: 2015 F32 435i Black Msport
Hardware:
Before:
After:
That's exactly how I felt when I installed airbags. Now you can feel the mess on I-75 now haha
      04-23-2019, 06:04 AM   #5
kern417
Cheapskate
It's not fun but manageable. Like I can tell how recently the roads have been paved in different sections now lol. And still steer clear of potholes
I just think it's crazy that all of our camber plate options seem to be $550+. They should be way cheaper considering how wide the use is. These fit all F2x and F3x models. But I guess they just don't sell that many.
Lancelot347.50
      04-23-2019, 09:31 AM   #6
alexng72
I think the main reason is the quality of the ball bearing. I can feel the difference when I switch from universal bags to airlift bags. Their camber plates have different design and much better build quality. Anyway, great job on finding that plates, i was looking for one forever before I decided to go with airlift.
kern4171632.00
      04-23-2019, 04:11 PM   #7
Bee Pee
Drives: AW M2 DCT
I just think it's crazy that all of our camber plate options seem to be $550+. They should be way cheaper considering how wide the use is. These fit all F2x and F3x models, and even F87 models without the carbon strut brace. But I guess they just don't sell that many.
F87 Millway camber plates aren't the same as F2x and F3x.
F87 have same more robust bearing arrangement as m3/m4 to suit larger damper rod of monotube front struts.
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT
kern4171632.00
      04-23-2019, 09:21 PM   #8
kern417
Cheapskate
Yeah we'll see. I found these guys while researching SPL and other bearing options, and they appear to be very in tune with specific suspension offerings. I trust them, knowing that they offer bearings in various sizes to build your own a la carte suspension arms. And of course the lead time of several weeks indicates they're made to order.
Corrected
      04-23-2019, 09:42 PM   #9
andino
Drives: F31 328i xdrive
Super interested in these to see how they fair after some daily driving. I saw one guy on the m2 forums that had his on for about 2 years and they seemed to be okay with them.
Do you put a lot of miles on your car? Mine is a daily but I really only drive 2-3 times a week on average. My car mostly sees road trips and I'm planning to start tracking the car this year. Hopefully with my use case, these should fit right in!
2016 328ix F31 | Bilstein B14 PSS | MPBBK | ER Catted Downpipe | REMUS Sport Exhaust | VRSF Chargepipe | G-Plus FMIC | BM3 Stage 2 | K&N Drop In Filter | KC Front Strut Bar | Superpro camber bushings | BMS OCC | Millway Camber Plates | KMAC Monoball | KC RSB
      04-24-2019, 06:34 AM   #10
kern417
Cheapskate
I don't, and I don't plan on tracking. This was primarily for wheel/tire fitment. I primarily drive in nice weather and never in snow (I only have 1 set of wheels with summer tires). I only put on about 5000 miles per year.
The bearing life all depends on your driving habits. More miles, more potholes, etc. will mean less life. I'm confident in these though, because others that I've had in the past have made metallic noises almost immediately. i was pleasantly surprised to have no noise on the Millway plates. That tells me right away that they're built properly.
And like I said, I have no problem if I have to replace the bearing every few years to keep it noise free. $60 is a no brainer.
http://www.millway.se/ge17-mte.html
andino132.00
      07-01-2019, 10:42 PM   #11
andino
Been a couple months since you’ve installed; how are the plates holding up to your use?
      07-02-2019, 07:12 AM   #12
kern417
Cheapskate
Still silent, but keep in mind I've only put on maybe 2k miles. I'm still keeping an eye on them for a true "long term" review.
andino132.00
Lancelot347.50
      07-02-2019, 04:43 PM   #13
andino
Thanks, I just put in an order for some myself. I drive a fair amount each month so I'll post about how they hold up to my use. Forgot to order an extra set of bearings but they're fairly inexpensive and will be easy to get later I'd imagine.
kern4171632.00
      07-11-2019, 06:25 PM   #14
thisismikeyb
Drives: 2014 328i xDrive M-Sport EBII
Just received mine today, should be installed Saturday morning as long as the Eibach springs come in. The saga continues as my friend says...
2014 328i xDrive M-Sport EBII--M-Sport Brakes w/Stoptech Pads--Full M-Performance Aero--Injen Intake--Active Autowerke Signature Exhaust--Bilstein B6 DampTronic w/ Dinan Springs+Shockware & M3 Bump Stops--Summer Apex FL-5 w/ MP4S 245/45 18x8.5et35--Winter Apex EC-7 w/Pilot Alpin PA4 245/45 18x8.5et35--BavSound Stage 1+Ghost Subs
kern4171632.00
      07-12-2019, 02:29 PM   #15
andino
Hoping to get mine installed this weekend as well. Won't be able to dial in any camber until my monoball arrives though.
kern4171632.00
      07-14-2019, 01:58 AM   #16
andino
I installed these today with my b14s and there's def more NVH over stock. The car feels way more nimble though with the solid mounts. Even the strut rotated more easily in the mounts. Very happy with them so far. I installed an RSB today as well and it was dark when I finished so no test drive or alignment yet. Will update again after some miles and after my monoball comes so I can get an alignment/corner balance.
kern4171632.00
      07-14-2019, 12:34 PM   #17
thisismikeyb
Next weekend for me. The Eibach spring were delayed until Monday for delivery.
andino132.00
kern4171632.00
      07-14-2019, 01:55 PM   #18
Pinkykillaz
Pinkykillaz's Avatar
Drives: 320i,eibach pro-kit
45k km on them- no issues)
kern4171632.00
      07-15-2019, 03:07 AM   #19
kern417
Cheapskate
Awesome, glad to hear. Hopefully more people see them as a quality option.
