BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Do Carbon M Sport Exhaust tips fit on the standard stock exhaust (non-MPE)?
      03-21-2021, 04:09 PM   #1
hokiedood
Drives: 2016 BMW 340i
2016 BMW 340i  [0.00]
I don't have the MPE but I want the tips. Will they fit?
2016 340i | EB | M Sport
      04-02-2021, 11:02 AM   #2
435gc
435gc's Avatar
174
Drives: 2015 435i Gran Coupe xdrive
The passenger side tail pipe on the stock exhaust is a smidgen narrower then the driver side so the carbon tip will be a little loose. I solved this with a single wrap of exhaust wrap on the tail pipe and then put the tip over that so it clamps down snug.
The 60mm diameter at the very tip is wider than where it clamps down. There's a bit of a flare at the tip on the stock exhaust.
Drivers side clamps down with no issue.
These are what I bought:
https://www.ebay.com/itm/2x-Glossy-B...c-7317f31e11ed
They look good and pretty high quality for aftermarket. Indistinguishable from the genuine BMW.
      04-02-2021, 11:22 AM   #3
johnung
No they won't fit. Standard exhaust pipe should be 60mm in diameter. My M Performance Exhaust has a 70mm diameter exhaust pipe.
Diameter = Circumference divided by pi (3.1416)
So measure around the exhaust pipe to get the circumference and divide that by 3.1416 to get the diameter. If your tape measure is in inches then 25.4mm = 1 inch
There are many exhaust tips made in China just make sure to order the correct size
      04-03-2021, 06:10 PM   #4
J555
Drives: F31 LCI 340iX
Have these on the way: https://xxiituning.com/collections/b...31276162711654
Can report back after fitment, if interested.
      04-08-2021, 12:38 PM   #5
435gc
435gc's Avatar
174
Please do.
      04-19-2021, 05:57 PM   #6
J555
Originally Posted by 435gc View Post
Please do.
Here you go... The quality seems to be excellent, the fitment is exact. However, no surprise they actually arrived directly from China - assume they can be found (with some risk) on ali for less
      04-28-2021, 08:15 PM   #7
435gc
435gc's Avatar
174
Looks nice!
Love that last shot with the power station.
Glad no fitment issue with yours.
J555567.00
