07-21-2021, 05:53 PM | #23 |
Rep 576
Ordered them 5 minutes after I made that post. Should be here Friday and I'll update after installed.
07-22-2021, 12:39 AM | #24 |
Rep 20
07-23-2021, 02:07 AM | #25 |
Great Teacher
1076
Rep 1,303
Drives: 06 e91 325ix
Great minds. My up7 arrives tomorrow and I ordered the earthquakes as well. Just can’t justify installing 2 or 3 8” subs under the rear floor in one cube as I don’t think they’d play low enough to be worth it.
Thanks also to Billfitz for sharing the parts numbers for your better passive xovers. Plan on copying those ASAP.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… Last edited by Onizukachan; 07-23-2021 at 02:13 AM.. |
07-23-2021, 03:56 PM | #26 |
Rep 576
Installed the earthquakes today. They definitely hit a-lot lower and are also a little louder, but also aren't anything close to a trunk system. I believe I'm content and wont do a trunk sub though. Overall pretty happy, will see how they sound after a few hours of play time.
Onizukachan1076.00 |
07-26-2021, 04:20 PM | #27 |
Great Teacher
1076
Rep 1,303
Just arrived and looking forward to install.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
07-26-2021, 05:51 PM | #28 | |
Rep 460
I upgraded my base HiFi speakers to the L7 speakers, and this is fine. Extra power handling headroom. I wanted to know though, how can I design a passive highpass filter for use on the underseat midbass speakers? I want to use a sub in the trunk for anything below 65~80Hz and use the midbass for everything above that. Assuming a 4ohm speaker and say a first-order 80Hz HP crossover. Is this doable without sacrificing too much power? |
07-26-2021, 09:37 PM | #29 |
Rep 16,054
Passive crossovers in that frequency range are impractical, and expensive. First order filters don't do diddly. You're better off leaving as is with the stock arrangement, turn the head bass EQ down to remove some of the low frequency content from the under seats, use a sub amp that has low frequency boost to bring it up as required.
07-28-2021, 12:18 PM | #31 |
Rep 576
On the ride home from work I noticed the speakers were fine again, and then the left one eventually stopped working, again. What could this even be? One thing after another.
07-28-2021, 02:46 PM | #33 |
Rep 576
I checked it out and the posts on the adapter ring were very loose, so I tightened those and reinstalled the wiring and all seems to be well again. Not sure how the terminals became loose.
07-29-2021, 03:13 PM | #35 |
Rep 576
New issue of the day: not sure whats causing it, will have to take everything apart once more to check it out, but now the drivers side sub vibrates to the extent that I cannot even enjoy my music. Even at low volumes, you can hear a significant vibration. These things sound good when they work properly.
Edit: checked it out, and one of the corners of the mounting screws came loose, and it seems that whatever it screws into is now stripped. The screw is tightened, yet still spins. Wasnt like that when installed. What should i do about this… |
07-30-2021, 05:08 AM | #36 |
Great Teacher
1076
Rep 1,303
Wax the bolt really well (as in hard wax not car wax) and epoxy it in? The wax is so you can unscrew it once it dries.
Alternatively a breakers yard/ junkyard/ pick a part might have one( or several) from an f30/31 for purchase. Since you are pulling it back out suggest you also trim back the carpet so it doesn’t impinge on the surround and add some poly fill around the edges and especially across the vent area, I have 0 sideskirt rattle on the right side and only a tiny bit on left side after doing mine.
07-31-2021, 05:21 PM | #37 |
Rep 576
I pulled the screw out, and the plastic threads of the enclosure were inside the screw (if that makes sense) so I imagine the screw hole is smooth now. I covered the screw in silicone and put it back in the hole with some pressure and let it tack, but with no threading leftover I dont believe that will work. May have to use a larger screw and create new threads. Anyone else have this issue with these subs in stock enclosures?
08-03-2021, 02:58 PM | #38 |
Rep 576
This is getting ridiculous. I used epoxy to secure the screw and sub, and now the sub doesnt even play unless I apply pressure to the middle of it. What even is this…?
08-03-2021, 04:31 PM | #39 |
Great Teacher
1076
Rep 1,303
I feel for you, mine have been perfect since first install.
08-03-2021, 07:37 PM | #40 |
Rep 576
Super strange. Ive done many audio installs and never had these issues. But, I'm tired of messing with it so I may take it to an audio shop when I get some free time and pay them to do whatever they need to do to get the whole thing working properly.
08-04-2021, 03:50 AM | #41 |
Great Teacher
1076
Rep 1,303
Id suggest that you check if you lost a connection somewhere between factory wiring, adapter ring and the driver inputs themselves. Hoping that the frame didn’t get tweaked during your initial install. Noted these were thin stamped frames and not cast so when I installed I used the 4 lug star pattern and did them up in about 4-5 passes. To avoid bending them.
08-05-2021, 03:00 PM | #42 | |
Rep 576
08-11-2021, 09:29 PM | #43 |
Rep 576
Update: drivers side sub stopped working again so i checked it out and the negative wire came out of the terminal and refuses to go back in, so tomorrow I get to take my seat out yet again and try to find a better solution for keeping the wires in the terminals. Frankly, I'm not very fond of these speakers and mounting rings. Quite a PITA, and I move back in at my university in 3 days so Im running out of time to get these things to where they wont be an issue any longer.
