BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 2015 F32 435i N55 PI AIC1 Controller - Car won't start
      08-01-2021, 09:48 AM   #1
ssanders307
Drives: 2015 435i xdrive coupe
Hello everyone,
Apologies in advance for any formatting issues as this is my first post - I hope the picture below of my MHD error codes comes through.
Disclaimer: I'm not very mechanically savvy however really enjoy getting under the hood to do anything that I can reach - I seem to be out of my league when it comes to troubleshooting electrical issues.
I have installed BMP port injection / intake manifold and AIC1 controller however the car cranks but won't start. I have checked my connections multiple times, removed and re-installed the entire system a couple of times, tried starting with AIC tapped in as well as completely removed, and I appear to be dead in the water. I receive ignition/starter lights as well as drivetrain malfunction. Fuses are all good, fuel pump cycles as well.
I have been able to connect to my ECU through MHD which has shown the codes you can find below. I cannot seem to erase these codes, not sure what the meaning of that is.
Any input would be greatly appreciated! Thanks!
      08-02-2021, 07:05 PM   #2
thejeremyman9
thejeremyman9's Avatar
4358
Drives: 2015 BMW 335i
I have no personal experience with PI or that controller, but does it require tapping into the OEM wiring harness? Or is it plug and play? You said "tapped in" but not sure what you meant. Did you disconnect the battery while installing/removing?
The laundry list of electrical errors suggests a wiring issue, or less likely but potentially damage to DME if something wasnt installed correctly.
      08-03-2021, 02:44 AM   #3
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
also, I have no idea if there was any ground wires that were messed with in any way, that could do it as well.
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      08-04-2021, 02:01 PM   #4
Dynamic_m235
Drives: 2016 m235i xDrive
Originally Posted by ssanders307 View Post
Hello everyone,
Attachment 2662208
Did you get the file for the base map for the PI from your custom tuner or from RT tuner pro? And don't use PI unless your running e85 btw.
aic1, n55, port injection
