02-17-2021, 03:24 PM | #3015 |
Rep 7
Sound Issue
hi Everyone
I just installed the 10.25 android unit the sound come from one side either left or right not both what seems to be the problem i am using the unit without connecting the AUX as i plagued it and no difference any suggestions |
07-19-2021, 08:33 AM | #3017 |
Rep 30
Screen flickers when sun/heat hits the car
Hi All,
Over the past few months, my screen flickers whenever it's hot outside/inside the car. In the morning/night, it works perfectly fine. However, during the daytime when it's warm 70F and above then the screen flickers. Any idea on how to fix this or this is this basically end of life of the screen. I originally bought it in 2016. Thanks. |
01-15-2022, 11:09 PM | #3018 |
Rep 13
Hello .. Does anyone has their set reboot by itself, using it less than 5mins or running?
I am hvg MTK version/ Android 10, and noticed the set will self reboot continuously. However it happened under hot weather conditions, ard 38deg C .. After the car has cooled down, it can run back to original condition. During the loop mode, i can return back to original IDRIVE with no problem while reverse-camera also no issue (Original car doesnt have). The only thing i changed was setting the air-vent timer to activate itself and the 1st occurence of reboot happens exactly the same time as timer. Not sure it is related or not. |
05-31-2022, 06:01 AM | #3019 |
Rep 3
i want buy this unit
https://pt.aliexpress.com/item/32968...yAdapt=glo2bra can i listen to the original radio and an Android app at the same time? Like, have waze on the screen, receive audio directions from waze, and also still have FM radio running? |
05-31-2022, 06:02 AM | #3020 | |
Rep 3
can you listen to the original radio and an Android app at the same time? Like, have waze on the screen, receive audio directions from waze, and also still have FM radio running? |
06-28-2022, 12:30 PM | #3021 |
Rep 4
Carplay As Default Navigation App ???????
I installed the Avin unit in my 2010 e61 and it works pretty well.
I remember seeing a video that showed how to launch CarPlay when selecting one of the main red tiles (nav, apps, settings etc). I want to launch Carplay when I select the Navigation tile. Does anyone know where I can find this? Thanks again |
10-13-2022, 11:07 AM | #3022 |
Rep 742
Not sure if this was discussed but my Avin does a full shutdown (by design), is there a way for it to go to sleep so it doesn't boot each time? The boot time is a few seconds but what I want the most is remember what I used last.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
01-12-2023, 10:41 PM | #3023 | |
Rep 3
https://www.aliexpress.com/item/32852239954.html https://hualingan.en.made-in-china.c...ar-Button.html |
01-13-2023, 12:36 AM | #3024 | |
Rep 1,048
Its also not produced anymore, i asked the company some years ago, you would need to buy a couple hundreds of them so they would do a new production batch. Kri |
01-13-2023, 03:30 AM | #3025 | |
Rep 3
I actually found a forum member selling his used one but I don't think it will work with the aftermarket iDrive knob. I took one of mine apart and it didn't have any ribbon cables inside. I plugged a mouse into my AVIN unit and it worked flawlessly like a regular PC. So, what I ended up doing is searching a couple hours for an appropriate touchpad to install in place of the useless aftermarket iDrive knob included with the AVIN. Here is what I purchased: https://www.adafruit.com/product/5061 The dimensions are exactly what I need to be able to fit this into the OEM cupholder of my E83, though I'll definitely need a Dremel to modify it. Fingers crossed! |
04-02-2023, 03:12 PM | #3026 |
Tech retard
Rep 7
Hey all, bumping an old thread, I just bought and installed an old but new in box 10.25” 8.1 unit and is quite happy with it.
My question is how do I find out if I have the version I can put a data sim in? I do have the door on the left hand back side. |
07-21-2023, 10:44 AM | #3028 |
Rep 61
Drives: 2016 M3, 2022 X3 M40i
Hi,
I was planning to purchase a new AVIN unit per the link below, which is an Android 12, but the processor is not specified. https://avinusa.com/12-30-multimedia...2-f83-f84.html Does anyone know what processor it uses? Also I plan to use the KSW-ToolKit, https://github.com/Snaggly/KSW-ToolKit, with this unit. My purpose is to program an Idrive button to switch on the front aftermarket camera for parking. Has anyone tried this before, or know if there are any issues? |
01-25-2024, 07:26 PM | #3029 | ||
Rep 223
I noticed that not all audio is routed through the DAC though. e.g. phone calls and AV-IN/DTV audio still goes out as analogue via the harness (also available via the harness Audio-Out 3.5mm socket). Are you experiencing the same issue? If anyone else has this problem with their own DAC, let me know. If someone has managed to overcome this problem, let me know. Your response is of great value to me. |
02-07-2024, 05:52 AM | #3030 |
Rep 1
Android 13 BMW Alphine stereo speaker problems
NaviFly Android 13 head sucecsfully installed alle is working, moved the fiber cables to the new Harnas but left front and rear right speaker have no sound, neither has the seat bas speaker?
Any suggestion welcome? |
