BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Navigation infos doesnt show up on cluster
      09-16-2018, 03:42 AM   #1
Furkan Akyon
Drives: 2015 BMW 320i
Hi people,
I have nbt installed on my f30. when I set a route and when route wants me to turn it doesnt show up in cluster but I saw it showing up in a diffent car
Do I have to enable something?
Or coding required ? ( if it is please give me the codes to change if possible )
Thanks for your attention.
      09-17-2018, 05:39 PM   #2
Jhnblckwood
Drives: F30 2014 320i xdrive
Originally Posted by Furkan Akyon View Post
Hi people,
Do u have hud? If so that's why if not then prolly coding but idk the exact values to change sorry. Is the nbt retrofitted? Try vo coding kombi with 6wa and 609 in FA
      09-17-2018, 09:32 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
It shows up on mine, I didn't have to do anything.
      09-18-2018, 02:33 PM   #4
Furkan Akyon
Hud of what ? And yes its retrofitted
      09-19-2018, 08:20 AM   #5
1QuikWS6
No 55mph
1QuikWS6's Avatar
1616
Drives: F32 435ix MSport
HUD = Heads Up Display
      09-19-2018, 01:17 PM   #6
Furkan Akyon
Nope I dont.
      09-19-2018, 03:39 PM   #7
Jhnblckwood
Nope
Did u tru vo coding kombi and hu with 609 and 6wa in FA?
      09-20-2018, 03:00 AM   #8
sandwi54
sandwi54's Avatar
Drives: G07, F90
Did you only retrofit the navigation and not the 6WA cluster? You need the 6WA cluster to show navigation directions. Your car probably only has basic kombi if it didn't have navigation.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD)
      09-21-2018, 09:11 AM   #9
Furkan Akyon
I have this
https://4.bp.blogspot.com/-FwSump703...25282%2529.jpg
      09-21-2018, 09:31 AM   #10
Furkan Akyon
I haven't but I will, is that the codes I should change ?
and if there are some missing or extra codes can you tell them ?
KOMBI L7_MID > Anzeige_Konfiguration 3000 > NAVI_NBT_ENABLE = kein_nbt [Default]
KOMBI L7_MID > Anzeige_Konfiguration 3000 > NAVICOLOR_TABLE = alte_farbtabelle [Default]
KOMBI L7_MID > ERM_Konfiguration 3004 > DISP_DCRN_ASST_APPL = nicht_aktiv [Default]
KOMBI L7_MID > FZG_Ausstattung 3003 > HUD_ENTERTAINMENT_MOST_ENABLE = nicht_aktiv [Default]
KOMBI L7_MID > FZG_Ausstattung 3003 > HUD_NAVI_ENABLE = nicht_aktiv [Default]
KOMBI L7_MID > FZG_Ausstattung 3003 > NAVI_VERBAUT = navi
KOMBI L7_MID > FZG_Ausstattung 3003 > VZA_ENABLE = nicht_aktiv [Default]
KOMBI L7_MID > PIA_Einheiten 3008 > HUD_PIA_NAVI = nicht_aktiv [Default]
KOMBI L7_MID > PIA_Einheiten 3008 > KI_PIA_ANKUNFT = aktiv
KOMBI L7_MID > PIA_Einheiten 3008 > KI_PIA_DISTANZ = aktiv
KOMBI L7_MID > PIA_Einheiten 3008 > KI_PIA_NAVI = aktiv
HU_NBT > EXBOX 3001 > KOMBI_CIC = kombi_mid
HU_NBT > EXBOX 3001 > SETTINGS_INFO_DISPLAY = aktiv [Default]
HU_NBT > HMI 3000 > BASIS_KOMBI_MMI_LIST = nicht_aktiv [Default]
HU_NBT > HMI 3000 > HIST_GAS_CONSUMP = aktiv
HU_NBT > SYSTEM_EINSTELLUNGEN 3004 > EXTERNE_MOST_DIAG = aktiv
HU_NBT > SYSTEM_EINSTELLUNGEN 3004 > EXTERNER_MOST = aktiv
      09-22-2018, 09:29 AM   #11
Jhnblckwood
I don't kno all the codes by heart n not by computer to Check but that's why u VO code with 609 and 6wa in FA because esys will change all the values necessary automatically
