06-16-2021, 03:58 PM | #199 |
Rep 1,240
Drives: 2016 BMW 340i
I had Remote Services until the day of the upgrade and it was supposed to last until 08/31/2025. After the update, I have lost it and I was told that with the upgraded ComBox, the only way I can get Remote Services is if I paid for it again annually. So, I basically lost the service I had and they now want me to pay to get it back again.
2016 BMW 340i 688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494 Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals |
06-16-2021, 04:03 PM | #200 | |
Rep 106
Drives: BMW 428i xDrive Gran Coupe
If it's a free upgrade I just figured why not. Everything is factory settings on my car and I haven't changed any coding. Appointment is Saturday, I'm just trying to make my best informed decision.
~Scott~
06-16-2021, 05:57 PM | #201 | |
Rep 881
Your HUD will be fine. Not sure whether Map updates or RTTI are affected (maybe only any voice-related parts?). Handsfree is within-the-car (no?), so not likely affected as it's using your phone for the call.. I'll try to learn more myself tomorrow, when I can talk to the techs about the upgrade more at my dry-run test. |
06-16-2021, 06:11 PM | #202 | |
Rep 881
I've been on annual renewal now with my Connected Drive services since 12/2019. This upgrade will let me continue past 2/2022. |
06-16-2021, 06:49 PM | #203 | ||
Rep 106
I also don't want to drive a vehicle that has obsolete hardware in it that no longer does what it could/should because I didn't take advantage of the free upgrade. Yes please keep me informed after your visit, I'd appreciate it. Thank you.
~Scott~
06-16-2021, 10:10 PM | #204 | |
Rep 36
06-17-2021, 07:30 AM | #205 |
Rep 692
I'm unclear now. Will I just lose the "on star" (lol) capability that calls a human in case of accident ?
I only am interested in keeping the ability to display weather in my screen which I pay for today through connected services. My car seems to have 4G if that helps. But i am told I am eligible for a free upgrade.
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
06-17-2021, 09:38 AM | #206 | |
Rep 881
Pretty sure your Weather app would continue to function (BMW apps use the 4G data connection). |
06-17-2021, 09:53 AM | #207 | ||||
Rep 692
The problem I see is that apparently if you don't get the upgraded module/service then bmw will not renew your services or even allow you to renew. If that's true then even if the current hardware is capable of receiving partial service (weather apps etc) there wouldn't be a way to obtain it.
06-17-2021, 12:09 PM | #208 | |||||
Rep 106
~Scott~
06-17-2021, 12:12 PM | #209 | ||
Rep 106
~Scott~
06-17-2021, 10:27 PM | #210 |
Rep 881
So, after my ISTA trial-run today, here’s the scoop.
tl;dr — I can confirm it IS possible, for some cars, to get the 3G Upgrade and not have your DME ‘locked’. My car is an F-series N55, 2016 435iX GC, NBT EVO/iDrive 4, with MEVD172G DME. This DME has the bootmode flaw that will always enable a bench unlock (cuz hardware). Mine is one of the earlier cars among the eligible batch, so the upgrade for me involves both a HW swap + SW update. (later cars in the batch only need a SW Update). We ran a test to see what the free offered 3G Upgrade will do to my DME, since it will also get updated as part of the ISTA step SW bundle calculated to accomplish the Telematics upgrade. Will the ISTA update ‘lock’ the DME from supporting OBD Flashing or not? I’ve been running MHD. I flashed back to stock tune prior to bringing it in to hook it up for the test. —- Upon hooking it up, before even calculating the plan, ISTA flagged my DME as ‘likely’ being tuned. Info says the latest ISTA has a new diagnostic module specifically added to ‘intelligently assess’ this. Good to know. In my case, while I now had the OEM tune installed, my flash counter didn’t match what ISTA records said it should be. We proceeded anyway - accepting that the ‘flag’ might increase the likelihood to calculate a DME update into the plan. —- The ISTA programming measures plan was calculated to take me to step: F020-21-03-545. My first reaction was that’s March 2021, ‘that ain’t good’… but I was happy and grateful for the test info. After I got home I quickly contacted my tuning company expert (super customer service). They were able to review the technical unit level software changes included in the proposed DME update. The prognosis? I’ll be fine - like, say what? Your particular DME won’t be locked from flash tuning by this ISTA step. At the technical level, because my BTLD technical SW unit, once updated, would still be at revision 001.069.002. —- So, as you’d guess, I’m scheduling the free 3G Upgrade service ‘for real’ . Frankly, even if my DME was gonna be locked, since it’s readily bench unlockable, I was thinking I might have done it anyway… I like all my Connected services. Hope this info’s helpful. I realize it doesn’t have much info of use to other types of cars in the eligible batch (like early LCI, B58 models). And it still doesn’t answer what becomes of the various Connected Drive services, post 2/22, if you don’t do the free upgrade. (like what’ll still work?) . |
06-20-2021, 12:29 PM | #211 |
Rep 881
FWIW, I still haven’t found much more than this from the 3G FAQ:
“Some vehicles factory-equipped with 4G telematics devices will no longer have access to services that require a voice connection, such as BMW Assist eCall and Concierge Services, but will continue to receive certain ConnectedDrive/BMW Assist services such as Advanced Real-Time Traffic Information, Remote Services and BMW Online, depending on your BMW model.” What’s not clear is what particular services or bundles will be renewable once current contracts expire.. But interestingly, look at this chart below, showing ConnectedDrive service offerings for pre-2018 cars. My hunches are that 1) all the eligible cars for the 3G Upgrade fall into the second-from-right column (the eligible batch, as these models have 4G modems but use 3G for voice CD services), AND 2) taking the Upgrade Offer will move the customer Telematics tech-wise into the right-most Column (June 2016+ build). Note the specific CD features that are only renewable for cars in that column…. It kinda matches up with the official 3G FAQ quote above too. Neither my shop technical folks nor my SA could give me any additional info or answer particular service offering questions. They admitted the BMW online/connected services biz is pretty separated from the mainstream parts/services side. We might have to wait until 2/22 to see what services BMW Connected will actually offer for renewal to non-upgraded cars. . |
06-20-2021, 04:33 PM | #212 | |
Rep 106
I figure take the upgrade now while it's free instead of a year or two down the line when maybe it isn't? I've done zero modifications/coding with my 428i X-Drive Gran Coupe, so I'm not concerned about losing anything. Thanks again for the info.
~Scott~
visionaut1307.00 |
06-20-2021, 06:22 PM | #213 |
Rep 10,256
I own both 2017 F36 and 2015 F15. 2015 F15 received a 3G discontinuation notice a few weeks ago.
If asked - BMW NA and local dealer will continue to state that 'technology upgrade does not exist". While the solution does exist, it's not necessarily simple or inexpensive. NBT Evo head unit + ATM 4G module + wiring loom + installation by BMW wiring / coding expert will cost north of $2.5K USD. |
06-20-2021, 11:25 PM | #214 | |
Rep 881
I’d NOW say: But interestingly, look at this chart below, showing ConnectedDrive service offerings for pre-2018 cars. My hunches are that 1) the eligible cars for the 3G Upgrade all fall into the far right column, the earliest cars in this group, built probably within 18 months of the July 1 2015 build cutover date (these models have 4G modems but use 3G for voice CD services). AND 2) taking the Upgrade Offer will move those customers Telematics tech-wise into a common, consistent solution for all cars in this group. Nothing here adds to the official 3G FAQ statement regarding which services might cease to be offered though, for the subset of earliest cars in this group that don’t do the upgrade (or can’t). . |
gnolivos319.00 |
06-27-2021, 04:34 PM | #215 |
Rep 1
Hello all. I just registered to join this thread as I'm moving (have been in a city where my poor 2014 335xi/F30 w/HUD and now expired real time traffic/etc have been idle for the last 6-7 months) and will be driving my car again on the regular. I was setting up the MyBMW app and then found out I can't renew traffic or connected drive services and have spent the last half hour trying to figure out what is what.
I apologize sincerely for the stupid question, but given that my car was manufactured in April of 2014 but my services (save remote unlock, ventilation, location, etc) are expired is there no way forward for me? I don't often use the real time services but love the HUD and Spotify has long since not worked through the car despite it being always listed (maybe my Connected drive subscription lapsed?). I originally purchased the vehicle as a CPO in 2015 and am well out of warranty and happy to do retrofits myself (provided they are not too intensive) but obviously if there is a way to get the vehicle upgraded (fee or not) to 4G through BMW proper that would be the preferable route. |
06-27-2021, 07:03 PM | #216 | |
Rep 881
I believe BMW has cut-off renewals right now for cars even in the 'upgrade eligible' range, pending the upcoming cease of service support 2/2022 for 3G modems. Sorry, I don't know what's been offered in Connected Drive services for cars in your earlier technology range recently or going forward. From what I've read, if you're 3G-only there's no ready upgrade path to 4G. Your HUD will be unaffected, it's not a Connected Drive driven feature. I don't use Spotify, but there's other threads on that issue, but I don't know the cause or the solution, if any. HTH |
06-27-2021, 10:28 PM | #217 |
Rep 16,079
I got my email today, and it says there's no upgrade available for my F34. I'm fine with that. I stopped paying for connected drive services two years ago, I don't want them messing up my coding, and whatever I need 4G for that's why I have a phone.
06-28-2021, 01:27 AM | #218 | ||
Luxury at the redline :)
9105
Rep 7,563
This offer not really an upgrade, per se, as both the older and newer telematics units run on the same 4G LTE connection. It's just that AT&T Wireless, the one and only data carrier BMW utilizes for its US telemetry operations, is killing off the original circa 2007 LTE standard that relay solely on circuit switching for voice calls, which is commonly known as "VoIP" or Voice Over Internet Protocol. After 02/2022, AT&T will then only support calls to be packet switched via a system called VoLTE; which is sending of voice data through cellular data such as 4G LTE. VoLTE will become AT&T's standardize system used for transferring voice calls by using the LTE connection. Since the earlier BMW 4G LTE telematics radios uses the now retiring VoIP technology for emergency calls, BMW is now offering a revised telematics system which would now support VoLTE or LTE-A calls, thus, emergency calls would remain functional, even after the obsolete "VoIP" technology for voice communication is officially sunset by AT&T. If one already has a 2016+ vehicle with a early 4G LTE (VoIP) radio and chooses not to take advantage of this VoLTE/LTE-A upgrade offer, most of the regular ConnectionDrive will still remain active as normal, with the exception of the emergency SOS calling, which would be the only feature no longer supported. https://www.androidauthority.com/vol...obile-1148654/ https://www.xda-developers.com/t-mob...-shut-down-3g/ |
QuarterMileJoe9.00 |
06-28-2021, 12:24 PM | #219 | |
Rep 36
Do you know which ATM part numbers support the new voice call standard? |
06-28-2021, 06:12 PM | #220 | |
9105
Rep 7,563
Any system that currently supersedes these older unit's part number is replaced by the newer revised system, upon any official warranty repairs or official replacement. For good measure, you can verify that any telematics unit with a built after 07/2016 has the most current technology (LTE-A/VoLTE). Also, any factory iDrive 6 and beyond guarantee to have a VoLTE compatible radio in the telematics unit. Also, no worries about this 4G LTE-A system becoming obsolete anytime so since the LTE-A standard that this new system runs on today's 5G we currently use, thus, they both work on the same frequency, so by extension, for the long run, LTE-A is here to stay. |
