06-19-2021, 01:26 PM | #1 |
Rep 204
[F30 335i] outside temperature and power
Hey guys,
Few days ago I have done a custom tune and DP. Car seems to be faster. It’s stronger for sure. But today I went to check what is my 100-200kmph time and I am shocked. It’s worse than my stock car. Stock was 14.3s and now is like 14.8s. But stock was measured when outside temperature was around 8C (45F) and tuned when 35C (95F). I am wondering if this temperature difference can cause my car slower now than stock when temperature was much lower? And sometimes can feel that car is a bit lazy when hot outside. |
06-19-2021, 01:32 PM | #3 |
Rep 204
06-19-2021, 01:40 PM | #5 |
Rep 204
So you guys mean that can be like that, because od temp?
Of course I’ll measure times when temp will be low again. But now I AM wondering if something is wrong with car or it is how it is - summer worse times and ‚lazy’ cars. |
06-20-2021, 10:04 AM | #6 |
Rep 68
Does your tune allow you to run a log (BM3 or MHD)? Take a few logs and check intake air temp (IAT). Watch your timing corrections as well. You will most likely see timing and/or boost corrections due to the heat. I live in Arizona and ran BM3 stage 1 with just a downpipe and stock intercooler for a while. Logs showed that my intercooler was getting heat soaked and IATs were way high. Car was pulling power and feeling flat.
I have since upgraded to a VRSF 6.5" Competition intercooler and power is back on back to back pulls. Of course, it's been 117F this week in Arizona (47C) so we're not making much power out here for the summer ! |
06-20-2021, 10:13 AM | #7 |
Rep 16,082
Google 'Ideal gas law'. If it's confusing don't be concerned, Roger Goodell doesn't understand it either. It explains why cars run better in colder temperatures, and why you need to check your tire pressures more often in winter.
06-20-2021, 11:43 AM | #8 |
Rep 204
It’s shame, but I’m vessel engineer and I know that more cold air = more oxygen = more power. 😁
But I’m more curious if this temperature difference can cause that tuned car (when is hot outside) is slower than stock (cold outside) 0.5sec. I think thats a lot. Starter to look for shift point. Because I have floored my car to check times. And it’s like I can feel that now it’s slower. |
06-20-2021, 02:48 PM | #10 |
Rep 4,877
When it's 30+C outside where I live, I can feel a huge turbo lag off the line. When it's 5C, a lot more power.
I've never time checked my car, but there would be a difference in HP between 35C and 5C. For me it's quite noticeable from a cool 10C morning to a hot 30C afternoon when driving (same car, same tuning, before as stock and now with BM3 S2) |
06-21-2021, 12:00 PM | #11 |
Rep 204
Today I have checked my times 100-200kmph (~60-120mph). 35C (95-100F) and it’s 15.0s but I had to shift manually at 6200rpm. Higher was much worse time. But yeah, the point is: What do you guys think, what is the times dofference between 5C and 35C? I’m just wondering how much faster will be the car when temp is cold.
06-21-2021, 01:40 PM | #12 | |
Rep 1,148
My stock intercooler on stage 2 saw 65* over ambient in 70*~ weather on 3rd-4th gear pull Now I see 11-15*~ over ambient and way more consistent. |
06-21-2021, 07:43 PM | #13 |
Rep 150
06-22-2021, 07:21 AM | #14 |
Rep 4,877
Depends on how you read what he wrote. CAI do address this, if you have a car (like mine) that comes with the hot weather kit (aka CAI), then changing that out for aftermarket would be a myth.
06-22-2021, 07:51 AM | #15 |
Rep 16,082
Cold air intakes do make a difference. What's mythical is the claim that after-market intakes make a difference. They make that claim based on being cold air intakes, but fail to note that the stock intake is cold air. Worse, I've seen more than a few that claim to be cold air, but aren't. If you can see the air filter when you open the hood it's not a cold air intake.
01-24-2024, 06:55 PM | #16 |
Rep 12
F30 330i here (b48). I have the exact same issue. Car feels significantly slower during the day than at night time. B48’s are said not to require an intercooler due to the water to air system that it has, but I feel like it could fix my issues. Currently stage 2 on BM3 with a catless DP and a MST CAI. Let me know what you’ve done/ if you have done anything for this problem
01-24-2024, 07:07 PM | #17 | |
Rep 7,606
Datalog when you feel like the car is slow then datalog when you feel like the car is fast and post them both to see if there is something obvious to explain the perceived power difference. |
01-24-2024, 07:17 PM | #18 | |
Rep 12
https://www.bootmod3.net/log?id=6548...eae432fbf5e8c2 https://www.bootmod3.net/log?id=654f...05ef36c8387c32 |
01-24-2024, 10:01 PM | #19 | |
Rep 7,606
01-24-2024, 10:05 PM | #20 | |
Rep 12
01-25-2024, 01:17 PM | #21 | |
Rep 7,606
What were ambient temps on those days? I am not sure if A/W IC upgrades are offered for your platform, but another option is meth injection. |
