BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Before you ask why your exhaust is broken and why only one side is dirty: READ THIS!
      08-12-2020, 11:00 PM   #111
DickBlisken
DickBlisken's Avatar
Drives: Like a hooligan
2009 E92 328i  [0.00]
I just purchased a Veepeak OBDCheck BLE+ as well as the BimmerLink app, and when setting the exhaust flap to 'Open' while the car is idling in Comfort mode, it opens to 100% for a half second, and then closes to about 75%.
Is that normal behaviour, or am I missing something here? I've searched around the forums and can't seem to find a definitive answer. Everything I'm seeing shows the valve as 100% open.
2016 F30 340i M Sport | 2009 E92 328i 6MT
      10-07-2020, 11:34 AM   #112
Alloutofdonuts
Drives: 2007 BMW 335xi
Does anyone have a wiring diagram for the motor/wiring to the motor? I think any will be helpful? Long story short, I put an f82 m4 exhaust system on my e90 335 and I’m trying to wire the valves up to a switch &/or remote. I have the connectors and pins for the wiring part but I’m not sure where & what the signal is. I also bought a CG VSC-2 for the project. It just has +/- & the signal wires but I’m not sure if I run the signal to a switch, it will power the vsc-2.
I saw a thread on a mustang forum for a AE retrofit, which uses the same or similar motor, but the user had to cut the motor case openf, and solder 2 wires onto the motor, bypassing the circuit board. I have no problem doing this, and I bought another actuator motor to play with.
My concern is that if there is no timer or limiting controls for the motor, it could keep activated(if the switch or remote button is held too long) until it burns out or breaks the gears. So I’d prefer to keep the factory safeguards. At the same time if the signal is too complicated to replicate I can just rely on my ears to know when to let of the button. I’ve read it activates very wuickly(~1 second?). Thanks for any help or helpful suggestions. And no, ‘go **** yourself’ is not considered helpful lol.
      06-13-2021, 02:55 AM   #113
DATN26Shheeesh
DATn26Shheeesh
Drives: 16-F30-328
Bimmerlink Mobile App
There is a setting in the Bimmerlink App where you can change set the exhaust flap to be permanently opened.
Check out this video for more info:
      06-20-2021, 08:23 PM   #114
JrCidR1
JrCidR1's Avatar
Drives: 2019 BMW 440I RWD
Great Info for someone like me, new to BMW and 4Series
      08-22-2021, 09:38 AM   #115
whoslooking
Drives: BMW 420i GC
Thanks had wondered about this
      09-27-2021, 12:20 PM   #116
ks195
Drives: 430i xDrive Gran Coupe
Thanks for the information!!
      01-19-2022, 11:44 PM   #117
yelite
Drives: BMW 335xi
Great explanation! Thanks!
      02-15-2022, 09:49 AM   #118
oem.plus_440gc
oem.plus_440gc's Avatar
353
Drives: 2019 440i XDrive GC
If you use BimmerLink to open the flap, does it stay open after the car shuts off, or does it always reset back to "auto" when the car shuts off. I thought I saw that somewhere. I want my exhaust flap open, but I don't want to have to connect bimmerlink everytime i start my car.
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
      03-05-2022, 07:36 AM   #119
bimmerf30_2015
Drives: BMW 328i X Drive (2015)
OEM.Plus_440gc = shuts it off permanently or until recoded back to normal operation.
      03-07-2022, 07:19 AM   #120
oem.plus_440gc
353
Must be different across years/models. I used bimmerlink to set my flap to "open". It stayed open during my initial drive (about 10 minutes). Turned off the car, ran into the store for a few minutes, came back out and started my car again, and the flap was closed. So I believe on a 2019 F36, it will reset that option when the car is turned off.
      03-08-2022, 01:37 PM   #121
Berkova
Berkova's Avatar
Drives: E39
      03-16-2022, 07:57 PM   #122
f30cole
Drives: 2014 bmw 335i m sport/1999 911
exhaust flap fuse
i pulled the fuse for the exhaust flap, is ppulling the plug on the actual device better?
      04-06-2022, 11:25 AM   #123
chrisxt
Member
chrisxt's Avatar
Drives: F32 BMW 435i
Now I know why, haha. Thanks!
      04-07-2022, 09:01 PM   #124
kongeli
kongeli's Avatar
Drives: 2014 BMW 435i
      05-06-2022, 12:49 PM   #125
f30guy2022
Drives: BMW F30
Thank you for the info.
      06-07-2022, 03:20 AM   #126
rajkumar145
Drives: bmw
Great post as this is a pretty common question:cool!
      06-19-2022, 04:35 PM   #127
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Had this on my M2 and loved it. The valve(s) will default to whatever setting you want and you can open and shut them manually with the garage door buttons: https://www.cgprecision.com/#!/VSC-1...egory=17975162
      07-17-2022, 11:28 AM   #128
Durbelik
Ukraine
Drives: BMW F30 328iX, BMW F10 53iX
Thx for your post
      08-20-2022, 01:57 PM   #129
Freddie345
Drives: BMW F30 340i 19 plate
This post has saved me from a load of head scratching. Thanks
      09-29-2022, 01:32 PM   #130
Bori_san
Rider/Modder 🚗+💻
Bori_san's Avatar
Drives: 2016 BMW 428XI MPerformance
cool
Wow! cool stuff
      10-24-2022, 08:11 PM   #131
mdpelta
Drives: BMW 340i xDrive
In California, this cam cause serious issues with passing emissions smog checks that are mandatory. I considered this product: https://valvemaster.ca/products/bmw-...40945876664506
      11-23-2022, 02:49 PM   #132
jimgandhi
Drives: 2018 BMW 340i drive M Sport
Originally Posted by Tim2189 View Post
just get the black tips
thats what I did, makes more sense
