09-25-2019, 12:36 PM | #397 |
Rep 1,626
The warranty should apply no matter how many owners. It is the free maintenance that does not transfer to the new owner (except for immediate family).
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
10-13-2019, 02:59 PM | #399 |
Rep 51
Long time lurker first time poster. I feel I'm qualified to post here.
2013 335i M sport 6speed manual, 176k miles. I have been meaning to get the maintenance history from the dealer. Carfax has a long list of "maintenance" entries. Judging by the frequency they appear to be just oil changes. I'm pleased to see the PO did that frequently. The PPi came back with a clean bill of health. It currently drives flawlessly except the heater takes forever to put out warm air. Seems like a stuck open thermostat. As far as things replaced over the years, I don't know. As far as modifications, stock, except for the lighter weight rims. It seems the PO believed, if you repeatedly/evenly curb rash the rims you could reduce the amount of un-sprung mass. Although the PO was on the right track there are better ways of achieving that. Current ongoing projects, changing all the "lifetime" fluids. Changing the thermostat. |
10-13-2019, 05:10 PM | #400 |
Rep 808
2013 335i. Still zero issues at 70,000 miles. Has never been to any shop, I DIY all maintenance pretty meticulously. BM3 stage 2 for the last 20,000 miles.
10-15-2019, 11:06 AM | #401 |
1-800-STOCKAF
157
Rep 376
77,777 miles
2013 335i F30 PWG ZF8 Production year 2012 RK Tunes oil filter housing around 30k eccentric value malfuntion around 46k (Fixed itself) Chargepipe never blew when I had Jb4 but changed anyway valve cover gasket 65k Maf sensor issue due to the intake oil, but gone after cleaning sensor Cars been reliable, no serious issues. -bushings around the car are getting old and worn. -did not do my water pump yet -still need to do my tranny fluid
F30 320i Stock
10-16-2019, 02:34 AM | #402 | ||
Rep 231
2- Steering rack . 38k 2015 435i |
10-16-2019, 04:05 PM | #403 |
Rep 461
2015 435i msport xdrive gran coupe with adaptive suspension.
63k miles Had to replace Vanos tensioner and Vanos solenoids at 62k. Other than that no probs. Jb4, charge pipe, intercooler, 3 gals of e85 and the thing hauls. Replaced spark plugs when i put the performance mods on with NGK 97506's. |
10-17-2019, 08:45 AM | #404 |
Rep 47
Hi all, looking at purchasing my first BMW and hoping to get your opinion.
I'm looking at a 2014 328i xdrive wagon with M sport package, with 144,000km (89k miles). I had it brought to a BMW dealership for the pre purchase inspection, and the results were mostly good. Needs front brakes, some light rash on 2 wheels, paint is good, tires good. The only concern is the front struts have leaked some, and will likely need replacing. As it has the adaptive suspension the quote from BMW to fix this was astronomical, but after looking through the forms and exploring aftermarket, replacing with Bilstein B4 doesn't scare me. I want to keep the stock ride height for winter so this seems like the best option. The only thing that is keeping me from buying the car is the timing chain issue. The more I read the more hesitant I become. The dealer listened to the engine and said it sounds great, if there was an issue they'd be able to hear it. What do you guys think? Any advice is appreciated. Thanks! |
10-18-2019, 12:55 PM | #405 |
Rep 425
I've read a bunch about the timing chain issue on here. Ultimately I stopped reading when a poster, much more knowledgeable than I, went on to explain at length that this issue is statistically insignificant. You might disagree if you spent some time reading about the numerous people who have posted about problems. The numbers of members on here, while very helpful, don't represent the amount of cars on the road at large. Not even close.
Even despite the class action going on in California or resolved. I refuse to think it's a global issue. If you found a car and everything checks out mechanically with the build you want and price, go for it, I say. My .02 |
10-18-2019, 02:13 PM | #406 |
Rep 20
MY63 335d xdrive - 167k
Oxygen sensor - warranty Battery - £200 ish I think Vac hose £27 That's it !!
E46 330i MSport - Gone - E46 330d MSport - Gone
E46 M3 - Gone - E90 335d MSport - Broke it E90 Alpina D3 BT - Rubbish - Gone - E90 330d MSport - Gone - F30 335d XDrive MSport - LOVE IT |
10-19-2019, 10:51 AM | #407 | |
Rep 3,408
10-21-2019, 07:59 PM | #408 |
Rep 14
2014 F30 335i
47k miles. Passenger side headlight failure. 15k - warranty Charge pipe cracked.40k - warranty Passenger side front - vapor barrier failed - water leak cases the illuminated door sill to fail.35k - out of pocket Oil filter housing gasket leak.40k - warranty Valve cover gasket leak. 46k - warranty Oil pan gasket leak.46k - warranty MAF sensor fail.20k - warranty Engine mounts shot.47k - out of pocket Belt tensioner/pulley fail.47k - warranty. I remember the good old times when i had just an oil filter housing gasket leak on my old 2006 330i E90 with 158k miles.... good old times. |
markeys26.00 |
10-21-2019, 08:10 PM | #409 | |
Rep 6,003
10-21-2019, 08:11 PM | #410 |
Rep 288
2014 335xi
66K miles Blew my chargepipe same day I flashed stage 1. Blew a coolant line going to the expansion tank, only cost $32 for the line from BMW though. Other than that just regular maintenance since I've only had the car for a couple of months. They are pretty amazing for sure |
10-21-2019, 11:09 PM | #411 |
Rep 1
Model year 2013 328i bought new in November 2018. Has about 110k miles. Just last month there was a drivetrain Malfunction light on and error message. The car wouldn't get into gear and when it did even when you push the gas there's no power. Took it to a dealer nearby and had to replace the cracked cylinder head. Approx $2000. This is in San Diego California. And a new battery ~$500.
When it had about 75k miles had to replace a gasket/valve and don't exactly recall but was over a grand I believe. |
10-21-2019, 11:39 PM | #412 | |
Rep 943
Drives: F30 328i Msport
10-21-2019, 11:46 PM | #413 | |
Rep 6,003
12-28-2019, 02:33 AM | #414 | |
Rep 1
Only usual maintenance and follow ups |
12-29-2019, 06:38 PM | #415 |
Rep 36
2013 F30 328i. Purchased at 60k miles, currently have 89k on the clock. CarFax states previous owner did all routine BMW servicing. Only thing I've had to replace during my time of ownership is an ABS sensor at 63k and a headlight bulb @ 88k. I do regular oil changes and normal preventative maintanence. Car has been very reliable and I drive it Hard
12-30-2019, 03:58 PM | #416 |
Rep 25
2013 F30 with 100k miles, bought he car around 30k miles with CPO Warranty, only issues have been a thermostat that was replaced under warranty.
AFIAK, no work has been done on the timing chain, the auto-start-stop was coded out around 40k miles. I am losing around half a gallon of coolant every few months though. I need to investigate a bit more. |
12-30-2019, 06:04 PM | #417 |
Rep 32
13' 328I X-drive N20 75K so far just regular maintenance although my combox randomly went out this summer for $800. Car is phenomenal driving in the cities and backcountry I'm not really worried about the timing chain.
I plan to do some basic maintenance like spark plugs and vcg then flip it for a B48 or B58 tbh |
