BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > High Mileage F30 - Problems
      09-09-2022, 08:27 PM   #551
pcking
pcking's Avatar
Drives: 2014 BMW 320i xDrive
Originally Posted by jcordier View Post
Which engine? That's amazing to hear.
Good old N20, broke 295k last week. The countdown begins!!!
jcordier162.50
sspade2464.50
M Smurf156.50
      09-10-2022, 10:19 PM   #552
dv8ed
Drives: 2013 F30 328i N26
Originally Posted by MetzgerMeister View Post
2013 F30 330d:
- Whole new engine at 65,000 km due to spun bearing (full engine cost covered by BMW under goodwill. I paid the labour so have a 2 year warranty on the new engine)
When new engine is put in by dealer is odometer reset to zero or current mileage?
If it’s a new engine miles set to 85,000 it will probably last long unless it’s a refurbished engine w/ similar mileage.
2013 F30 328i N26
      10-09-2022, 07:44 AM   #553
gpchamp
Drives: '18 440i GC '23 Tesla Y
48k miles. Leaking front struts. I suppose I could just let it be and drive it for a while under these conditions, but I decided to bite the bullet and get them replaced. Gotta love the shitty Houston roads.
BTW, this is the first real issue I've had with my 440i, and it's not really her fault. It's been an absolute gem in terms of reliability.
      10-09-2022, 11:48 PM   #554
DO444
Drives: 340i
Wow, that’s shorty tbh.
Only 48k?
How much to replace?
      10-10-2022, 08:26 AM   #555
pcking
pcking's Avatar
The car handles amazingly well as delivered but if you can afford it, a few upgrades take it to another level. Not sure if you can do that without voiding the warranty, but that is ancient history for me...
FWIW, I just did my 5th suspension refresh thanks to the crazy roads here in the northeast. This was my 2nd set of Bilstein B8+ Sport dampers; I reused the Dinan springs and camber plates but changed everything else (bearing, rubber spring seat, boot/bump stop, etc). Car rides like a dream again. At 296K now and will hit 300K before the end of 2022.
In terms of cost, I get all my own parts (FCP Euro & ECS tuning) and do all the rear R&R work myself but have my indy do the front strut replacement for safety reasons. He charged me 3 hours at $137/hour, so just over $400 in labor. Parts costs can vary based on what you choose and if you do other upgrades (springs, camber plates, spherical bearings, and more).
Even if you are doing a stock replacement, I would still suggest changing all the little parts (boots, rubber seats, strut bearing, bump stops, etc). If you blew a strut, like I did, you'll find that other parts take beating and begin to fail. My suggestion is to inspect and replace anything that's not up to snuff while you are in there otherwise you'll be taking it apart again.
Another nice thing about buying your own parts and doing it yourself, is you can buy everything you need and then decide whether or not to use the new parts based on the condition of the old ones. In my case, I ended up not using the new upper rear shock mount since the one I replaced during a previous suspension refresh was still in great shape. Same thing with a couple boots and bump stops. The were 8-9 out of 10 so they will very likely outlast the damper and so some minor TLC and back on they went. Now I just return the unused items and everything is right in the world. It cost me an extra 20 minutes and about $10 in return postage.
Mods: Stoptech Sport Brakes, Injen Intake, BMS Catch Can, AFE Downpipe & 328i Sport Exhaust, Evolution Raceworks Chargepipes, VRSF intercooler, AFE tBody Spacer, MHI Big Turbo, BM3 Stage 2 93 Octane tune, Bilstein B8 Sport+ dampers, Dinan Perf Spring Set & Camber Plates
      10-10-2022, 08:36 AM   #556
MidtownMike
Drives: BMW F30 LCI 320i M-Sport Shado
320i - Oct 2018 - 47k km - Emergency Call Failure.
The backup battery in the roof communication module had gone bad. "Aging"
Was covered under CPO warranty, but apparently it is around 600 euros to have it replaced out of pocket, because of the labor of removing the headliner.
The lifespan is apparently only 4 years plus the big ass failure warning in the digital cluster blocks all the info you want to see from the board computer. Looks like I will need to do this myself in 4 years. The battery is only 80 euros or so.
      10-10-2022, 10:35 AM   #557
Bootboot340
Drives: 2016 340i 6mt Stage 1
2016 340i 6mt m-sport and thp. Got it 2½ years ago at 40k miles. Now at 113k. Only 1 issues so far- emergency call malfunction due to low battery. I coded it out with Bimmercode watching a youtube video.
pcking87.50
      10-10-2022, 11:33 AM   #558
BHF30N55
BHF30N55's Avatar
Drives: 2012 BMW 335I (F30)
2012 335i. I bought it in March 2021 with 104k(116k now) on the odo. The chargepipe exploded, the horns went bad, and the battery died.
      10-10-2022, 11:34 AM   #559
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
2013 335i xDrive, 183k miles
Right mirror assembly corroded off, going to go find a used assembly at a junkyard (kenny u-pull) and put one on.
      10-10-2022, 01:03 PM   #560
MidtownMike
I get the fact that you coded it out, because it's annoying as hell. Are you thinking about replacing it? Seems kind of handy that the car calls emergency services and gives them your location as you lay unconscious in a puddle of blood with the car bent around a tree...
      10-10-2022, 01:20 PM   #561
Dvtchmxn
Dvtchmxn's Avatar
Drives: '17 440ix, '16 228ix (Sold)
2017 440 xDrive 55k miles. Only real issue was the PCV diaphragm being destroyed, It was a $20 fix and only requires a trim tool. Other than that I can feel that the spark plugs are on they're way out so those need to be replaced soon, most likely after this winter
      10-11-2022, 08:56 AM   #562
Prak903
Prak903's Avatar
188
Drives: 2018 440i xDrive Gran Coupe
I'm at 53k now. About to do plugs as well. Would you say its better to get PCV out of the way now because of the likelihood of it going soon anyway?
      10-11-2022, 09:04 AM   #563
Dvtchmxn
Dvtchmxn's Avatar
Honestly I would. The condition of my diaphragm after 55k miles was so bad. The rubber was very soft and thinned out. It's only a $20 replacement kit. I'm planning on getting the Ross racing pcv delete kit with the occ. planning on keeping a extra kit in my car in the meantime.
      10-11-2022, 09:13 AM   #564
Prak903
Prak903's Avatar
188
Awesome, thanks for the reply. Saw the vid on the Ross Racing PCV delete...did not realize it was $300 . May just do the replacement for now and see if I need it in the long run.
Did you buy the replacement from dealer or FCP?
      10-11-2022, 09:22 AM   #565
Dvtchmxn
Dvtchmxn's Avatar
Neither. They both charge ridiculous amount. FCP does charge less tho. I just got the b58?0"-,58, pcv cap kit for $19.95 from Ross racing performance
      10-11-2022, 03:30 PM   #566
gpchamp
Only 48k?
Yeah, I know, but the roads here in Houston are horrible. Pot hole city. I can't tell you how many tires I've had to replace due to impact bubbles. And I have the 18 inchers!!
3k to replace both front struts. So dang expensive because they're adaptive.
      10-11-2022, 05:38 PM   #567
AntF32
Drives: G30 540i xDrive - Carbon Black
2017 435D GC - Both front adaptive shocks and strut top mounts replaced, driver side was blown, passenger side had just started weeping.
It's going in next week as I think the steering rack may need replacing
      10-12-2022, 08:53 AM   #568
Bootboot340
Yes I'll replace it at some point. There's some good vids on yt. I always have my phone with me and usually my work phone too
