06-11-2017, 08:25 AM | #155 | |
Rep 5,997
sspade2464.50 |
06-11-2017, 03:00 PM | #158 |
Rep 3,211
I don't have high mileage but I also have ZERO problems
Scanned a magazine I forget which at the bookstore rating all the autos..it is rating the 3series the highest ratings on all categories except electronics.. BMw has come a long way..and considering many bimmers get pushed hard, tracked, and modded I am sure it skews the reliability ratings down a bit. |
06-12-2017, 04:01 PM | #159 | |
Rep 35
perhaps I should explain that it's a company lease and I'm not subject to any mileage limit! I actually do more like 35k per year. It's a 90 mile round trip to work. 1 hour each way on nice roads. And some days I go to different offices. Also I've taken this happy car to various fun destinations like Germany, Scotland, and that sort of racks up the miles as well. |
06-12-2017, 08:48 PM | #160 | |
Rep 153
Anyway, AFAIK the design issue that caused the earlier engines to need the walnut blasting has been corrected. Don't know if that's really true, but I don't recall hearing that F30 owners have needed to have their engines walnut blasted. |
06-12-2017, 09:24 PM | #161 | |
Rep 2,639
These are my valves after 80k miles. Just don't do short trips and do some WOT once in a while.
06-12-2017, 09:26 PM | #162 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
2016 340i xDrive M Sport.
31,000 Miles no issues at all. Every service has been done as recommended by BMW NA. |
06-13-2017, 11:56 AM | #163 | |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
06-17-2017, 05:19 PM | #164 |
Rep 247
2014 335i N55 Log
Two oil leaks repaired under warranty at 36,660 miles. The Oil Filter Housing gasket failed and a Oil Check Valve (aka Hydraulic Valve, aka solinoid) had to be replaced.
My SA said that they replace the filter housing gaskets all the time. That was a common problem on E46s too,but only after around 100k miles. My SA couldn't explain why, but guessed it was due to the higher oil temps in FI BMWs. I have no idea what the check valve is for. Oil cooler? VANOS? I'm glad that I caught these oil leaks on warranty, but dissapointed that they presented themselves at such low mileage. Replaced Charge Pipe. Had to stop competing in autocross and limp to Dealer. May be related to increased boost from Dinan Stage 2. However, replaced under warranty by Dealer. Replaced Water Inlet O-Ring. This is the for the pipe that runs from the water pump to the engine block. It was a "class 1" leak in that there wasn't any visible water, but the surrounding area was green from coolant. Last warranty item; it's all on me now.... Replaced Xenon head light Replaced upper coolant line (between expansion tank and upper hose connector). This line is only about 1/4" and made of plastic and metal. It cracked where the plastic met the metal. BMW coolant parts usually have the decency to last to at least 60k miles, but this failed at 48k miles. I guess this part was an over achiever. I was able to drive it home by cleaning coolant off the line and then wrapping it up with electrical tape. My engine compartment has been burning oil recently, so I suspect that I'm about to do a valve cover gasket. History: (Under Warranty) (Replaced by 1st Owner) -Steering Wheel Replaced: 10,857 -Steering Wheel and Horns Replaced: 15,238 -Ignition Coils and Spark Plugs Replaced: 21,120 -Transmission Replaced: 25,461 (Replaced by Me) -Oil Leaks: Filter Housing Gasket, Oil Check Valve: 36,660 -Charge Pipe Replaced 37,881 -Water Inlet O-Ring replaced 41,197 (Not under Warranty) -Xenon Headlight (left) Replaced: 44,690 -Upper Coolant Line Plastic Cracked (thin line between upper hose connector and expansion tank): 47,908 -Valve Cover Gasket: 48,130 -PVC Breather Pipe: 48,130 -Air Box to Turbo Intake Tube: 48,130 Last edited by lkstaack; 07-15-2018 at 09:26 AM.. Reason: Keeping my log updated. |
01-18-2018, 02:44 PM | #165 |
Rep 302
Reviving this from the dead...
14' 335i M Sport 43k miles Standard maintenance -- no issues so far (knock on wood) Any F30's in the 100k territory?! |
01-18-2018, 04:00 PM | #166 |
Im real pressed.
104
Rep 203
2017 340i Xdrive ~ 4,854 Miles
~ Trunk Latch Failure. ~ Power Folding Mirror's would not fold back out with interior button had to manually push them back out. ~ A module failed. ~ Parking Sensors Failure. ~ Sunroof wouldn't come down from vent position. ~ Failed TPMS sensor. All which were fixed under warranty of course, and along with some other miscellaneous issue's. But other than those issues the car has been fine and I still love it!
Current Lineup: 2017 Tesla Model S 100D/2017 340i Xdrive/2015 Audi Q5 Prestige Quattro/2017 Kia Optima SXL
01-24-2018, 10:26 AM | #167 | |
Rep 3,211
01-24-2018, 12:35 PM | #168 |
Im real pressed.
104
Rep 203
Pretty sure it was built in Germany.....
01-24-2018, 03:44 PM | #169 |
Rep 247
01-24-2018, 04:07 PM | #170 |
Im real pressed.
104
Rep 203
Actually it was built in South Africa.
01-24-2018, 04:37 PM | #171 |
Rep 3,211
Safr is supposed to be tight.. have the newest equipment in manufacture QA
I guess someone has to get the ONE I think your the only LCI I've heard of with so many minor issues My German built.. no issues whatsoever GUTEN TAG fingers crossed on longer-term issues but the LCI sure does look like we are hitting a QA lotto here |
01-24-2018, 04:53 PM | #172 | |
Im real pressed.
104
Rep 203
01-24-2018, 07:31 PM | #173 |
Rep 331
Interesting so many of you had issues. My car has been relatively issue free, which is even more surprising considering it's FBO and tracked all summer long.
2013 335i 6spd -Currently at 57k miles 35k- Mass airflow sensor failed 48k- Chargepipe failed Other than routine maintenance, it hasn't had any other issues.
2017 F80 M3 - Mineral White/Amaro Brown
2003 E46 M3 - Jet Black/Cinnamon |
01-24-2018, 10:11 PM | #174 |
Rep 7,484
2012. 320d Auto. 184ps
14,000 miles. Steering column replacement under warranty. Known issue. 16,000 miles. PAT heater burned out. Started parking in garage so have left this. 18,000 miles. Tail light cluster in trunk lid fell off. Broken plastic clips. DIY repaired. 19,000 miles. Passenger side. Telescopic headlight washer nozzle broke. Clip holding it in snapped. DIY repair. 19,500 miles. Seat belt buckle/lock housing broke. Part where seat belt is clipped in and you press button to release. Warranty repair. 20,000 miles. Side view camera (surround view) failed seal. Allowing water mist in. Replaced under warranty. Usual service costs e.g. oil, cabin filter etc. |
01-24-2018, 11:25 PM | #175 |
Rep 320
2014 F30 335i M sport - 110k Km's
All work done under warranty: -50k Side view camera's and wiring. -70k Fuel pump replaced. -70k exhaust flap actuator motor replaced. -100k heard a clanking noise from the front left side of the car. Took it in and they changed the tie rods. -100k noise still present, changed the steering box. -101k noise was still there, changed both thrust arms. -101k unfortunately, the noise was still there and they replaced both front struts. -108k Side view camera's and wiring changed again. Still drives pretty good. Last edited by G80BSM; 10-31-2018 at 11:09 PM.. |
01-25-2018, 01:51 PM | #176 |
Rep 1,267
2016 328i, 12000 miles. No issues... hahar
2016 Black Sapphire 328i | M Sport Pkg. | JB+ | Premium Pkg. | Heated Seats | Driver Assist Pkg. | Navigation | Misc. Coding | 35% Ceramic Tint
Past: 2014 Black 320i | Sport Pkg | BMS Stage 1 |
