01-06-2018, 03:51 PM | #67 | |
Rep 1,502
SportySpice204.00 |
01-06-2018, 05:58 PM | #68 | |
Rep 156
I just tried the 1.1A to recharge mine, says 100% but didn't do much, the low battery warning came back after a drive. |
01-06-2018, 06:21 PM | #69 |
Rep 16,079
100% is 100%. One known issue is that the software can be too aggressive at the battery charge where it throws out a warning, especially in cold temperatures. Just to be sure I have one of these:
https://www.amazon.com/INNOVA-3721-B...+voltage+meter I got it as a 'just in case' item. As it turns out I've never had the need to use it, because my iDrive has never thrown a low battery warning that I'd want to independently confirm. In any event if you get a warning after a drive that pretty much confirms that you should put it on the maintainer. |
01-06-2018, 06:28 PM | #70 | |
Rep 156
And considering my battery is now 5 years old, plus an accidental drain, it is a perfect storm. |
01-06-2018, 09:21 PM | #71 |
Rep 16,079
That would be from a more or less dead condition. When that happens you do need at least a 4 amp charger, preferably more. I have a 10 amp charger for those rare occasions. A maintainer isn't intended to do a full Lazarus treatment, it's just supposed to top off a charge that's not all the way there, and just as important to supply the current that the car uses when it's not running so that the battery doesn't have to.
01-07-2018, 08:35 AM | #72 | |
Rep 156
01-07-2018, 10:57 AM | #74 |
Rep 247
Interesting thread. It leads me to believe that BMW's smart charging algorithm is deficient for Bimmers in extreme cold weather. It's common knowledge that smart charger Bimmers must be driven often to keep the battery topped off. It's also known that the management system keeps track of battery condition and ambient temperature. Consequently, a car driven daily should keep the battery charged regardless of ambient temps. The smart charging system is deficient if it can't keep a healthy battery charged under daily driving conditions.
01-07-2018, 11:44 AM | #75 | |
Rep 15,858
One question for those with battery condition warnings, does the engine ever fail to start, or is the warning simply that? |
01-07-2018, 11:51 AM | #76 |
Rep 16,079
01-07-2018, 12:14 PM | #77 | ||
Rep 15,858
Incidentally, Auto Express and the RAC recommend charging our batteries in the winter months, particularly if motorists make short journeys and due to the high electrical loads and energy sapping technology in our vehicles these days. |
01-08-2018, 08:42 AM | #78 | |
Rep 156
I'll still bring it to my indie to get the battery checked, just in case. Same temperatures last year didn't throw the codes. The warning also shuts off accessory power though. Last edited by ToniCipriani; 01-08-2018 at 08:55 AM.. |
01-08-2018, 08:46 AM | #79 | |
Rep 1,953
Drives: 2013 328i xDrive
Yeah I was about to pull the trigger on the CTEK Polar charger but now not so sure.. |
01-08-2018, 09:00 AM | #80 |
Rep 15,858
01-08-2018, 09:34 AM | #81 |
Rep 216
I bought NOCO genius 3.5amp from Amazon and charged my car pretty much all weekend. Thank you BMW for the easy access charging points!! I will be using it often when the temps dip below freezing thats for sure.
01-08-2018, 09:40 AM | #82 | |
Rep 250
I did find an outlet in an elevator lobby in my parking garage on the top floor. Thinking I could sneak the car there and charge it up on weekends. Another option could be using a solar charger and parking the car in the sun for a while but I'm not sure how viable these are. I still haven't pulled the trigger on a charger. Drove the car for a few days last week in EcoPro mode and focused on making sure I was engine braking frequently to optimize recharge time and haven't gotten the warning since. Probably will just order the 1.1A Noco charger just to be safe. It's a good thing to have.
2014 335xi M-Sport : Alpine White | Coral Red
01-08-2018, 10:49 AM | #83 | |
Rep 16,079
I plug my car in every night that the temperature goes below freezing, often don't drive it for 5 or 6 days, never had a warning, not even over the last few weeks when lows went to -15F and highs were around 0. Coincidence? I don't think so. |
01-08-2018, 12:59 PM | #84 |
Sedan Driver
389
Rep 1,018
Got the discharged battery message to go away with the weekend's relatively warmer weather and did a bunch of coasting. Think it was mostly the warmer weather
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
01-08-2018, 01:30 PM | #85 | |
Rep 1,615
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
01-08-2018, 09:02 PM | #86 | |
Rep 156
01-08-2018, 09:03 PM | #87 |
Rep 156
01-09-2018, 11:43 AM | #88 | ||
Rep 250
Do you think the camera is really monitored? Park nearby and just run an extension cord over to the outlet. That way you aren't blocking the car wash bay.
ls3c6fartsucker, ls3c6sucksfarts |
