08-16-2018, 08:35 AM | #23 |
Rep 16,075
Back track it. If the sensor is good then the voltage that is supposed to run through it may not be there. At the socket where it connects, with the ignition on, measure the voltage that should appear across the pins.
08-16-2018, 08:38 AM | #24 |
Rep 878
In that case check the connector just to make sure the pins are correct and not pushed back?
08-17-2018, 07:34 AM | #25 |
Rep 123
Its weird because Live data on my Foxwell says that Brake pad wear sensors status is OK for the front and back
Current: 2007 335i
Past: F30 M3 clone/ IS-F/ E46 M3/ Gen Coupe/ MS6 |
08-17-2018, 07:53 AM | #26 |
Rep 123
What an almighty Foxwell, i just didnt know how to use it right, went through the CBS maintenance reset, the life of pads showed 255%, went and reset it now its back to 100% and NO LIGHT! Thank you all for helping out
Current: 2007 335i
MacklinUSOB518.00 |
08-17-2018, 09:06 AM | #27 |
Rep 16,075
Not quite worth its weight in gold, but pretty close.
MacklinUSOB518.00 |
08-17-2018, 09:08 AM | #28 |
Rep 123
Current: 2007 335i
01-15-2019, 01:28 PM | #29 |
Rep 1
I can confirm that using the Foxwell NT520 allowed me to reset the brake wear warning light. In my case mine read 255% just like the original poster.
Before I bought the Foxwell I took it to the dealer I bought my car at after I had changed the rear pads myself and they said they would have to do a "full mechanical and electrical diagnostic" and probably "upload I quickly walked out, ordered my Foxwell, reset codes. Now it's like I'm driving a new car again! I hate dash lights. Thank you for this post and thank you Foxwell! |
10-30-2019, 05:04 PM | #30 |
¯\_(ツ)_/¯
945
Rep 1,762
Just bumping this thread since I had this issue as well. Rear pads/rotors were good. I did replace the sensor when I replaced the brakes but I installed a new sensor with no avail. Red brake light, cluster warning and rear brake pad service required.
All gone after using the Schwaben scanner made by Foxwell. To do the reset; - connect the scanner - click on BMW - enter series, chasis, connect - service functions - maintenance - go to CBS - rear brakes or front - reset
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC Last edited by Solidjake; 10-30-2019 at 05:10 PM.. |
10-31-2019, 07:59 AM | #32 |
¯\_(ツ)_/¯
945
Rep 1,762
Showing that the brake warning is not there. Thanks
06-06-2022, 10:32 AM | #34 |
Rep 81
yes its possible
connect with ista to your car go to vehicle management service functions Maintenance and pre-delivery check Reset CBS condition based service CBS reset UDS than check the front or rear wear sensor en add reset it. just dit it couple of seconds ago and it works |
