08-17-2018, 07:25 PM | #1 |
Rep 63
K&N Air Filter Opinions
Hey everyone, I am thinking about dropping in the K&N air filter...Website promises slightly more HP and Fuel efficiency. What are your thoughts on this? Pros and Cons?
edit: I have a 2015 320i thanks! |
08-17-2018, 07:53 PM | #2 | |
Rep 5,456
Drives: F30
Do yourself a favor and pick up an oil/cleaner kit on eBay for $15 shipped (from ECS Tuning) and youll be good to go for a long time. I clean and oil mine every oil change (5k miles). |
F3010418.00 |
08-17-2018, 07:55 PM | #3 |
Rep 5,456
Drives: F30
Also... you might want to look into the aFe scoop. Mounts right behind the right kidney grille and directs more air into the intake system.
If you play your cards right... you can get the filter, scoop and oil/cleaning kit for about $100. No brainer in my opinion. |
F3010418.00 |
08-17-2018, 09:35 PM | #4 |
Rep 1,267
it won't make much difference on stock power except 'maybe' hearing a little more intake noise but if you were pushing JB stage 1 or beyond, it might make a difference. The thing is that the airbox design on the F30 just isn't really restrictive so the different filter element won't really matter. There have been dynos etc. of drop in air filters and they do close to nothing.
2016 Black Sapphire 328i | M Sport Pkg. | JB+ | Premium Pkg. | Heated Seats | Driver Assist Pkg. | Navigation | Misc. Coding | 35% Ceramic Tint
Past: 2014 Black 320i | Sport Pkg | BMS Stage 1 |
ooshnoo877.50 alohasurftoad3076.50 |
08-18-2018, 01:16 AM | #5 |
Rep 328
Drives: 2013 335i, ‘08 328i, ‘03 316ti
Not a fan at all! If you over-oil the filter after a cleaning it can mess with the Mass Airflow Sensor. Also, I think the cleaning process itself is just an unnecessary and fussy waste of time compared to the simple swap of the OEM paper filter. In addition, I have read somewhere (can't recall where) that the oiled filters are not that effective in keeping small particles at bay in dry, dusty climates. Furthermore, there is contradictory info out there as to the gain caused by these filters, seems mostly negligible in stock cars that are daily driven in normal traffic.
08-18-2018, 06:47 AM | #6 |
Rep 799
I would get the AFE Pro-Dry S air filter instead of the K&N. I heard the same thing as mentioned above about too much oil applied on the filter can mess with the MAF sensor.
alohasurftoad3076.50 BEM-S44515.50 |
08-18-2018, 08:57 AM | #7 |
Rep 16,079
Of course they do, otherwise why would you want to buy one? If you want as much HP and fuel efficiency possible don't use any filter. You'll destroy your engine, but at least you had fun while it lasted. You can get some minor gains with a filter that allows more airflow, but the only way to do that is by also allowing more particle flow, which reduces engine life.
08-18-2018, 08:59 AM | #8 | |
Rep 63
08-18-2018, 09:12 AM | #9 |
Rep 5,456
Drives: F30
Not disagreeing with any of the commenters on this thread but would like to say:
I have never had an issue with over oiling my filter and messing with the MAF sensor. I usually take care of filter clean and oil first and then let it dry in the sun while I change the oil. By the time I have everything buttoned back up, the filter is ready to go. |
08-18-2018, 09:25 AM | #10 | |
Rep 63
08-18-2018, 09:47 AM | #11 |
Rep 842
Well....over at the Miata forum...and these guys are just as committed as those here...an actual engineering test was done on air filters, as the same K&N question comes up.
Result....the OEM air filter does just as good a job. Meanwhile....on the Triumph Bonneville forum...also a committed bunch....an aftermarket supplier of high performance air filters tested his against others. Result....his “won” by about 3% over the stock one, and the stock bested all the others. |
F3010418.00 alohasurftoad3076.50 |
08-18-2018, 09:49 AM | #12 |
Rep 5,369
Don't run an oiled air filter. If you must have an aftermarket filter, get a dry one.
08-18-2018, 09:50 AM | #13 | |
Rep 63
08-18-2018, 09:52 AM | #14 | |
Rep 5,456
Drives: F30
You are saying that K&N Engineering has been bullshitting people since its inception in 1964? And people just keep buying their overpriced filters that provide absolutely no value? I wish I could come up with a business idea like that! |
F3010418.00 |
08-18-2018, 09:53 AM | #16 |
Rep 842
I’m not saying anything, I am relating 2 instances of comparison.
08-18-2018, 09:57 AM | #17 | |
Rep 63
08-18-2018, 10:22 AM | #18 |
Rep 16,079
The purveying of snake oil is hardly a new concept. The oldest commonly used term related to it is 'caveat emptor', and the Romans were by no means the first to issue warnings to consumers that truth in advertising is an oxymoron.
08-18-2018, 10:28 AM | #19 | |
Rep 5,456
Drives: F30
Do we really think that hidden behind the walls of K&N Engineering's manufacturing facility lie a team of uneducated illegal immigrants gluing paper and rubber together, sticking it in a fancy box with a logo and hoping for the best without any engineering, quality or testing guidelines? I would have to believe that they are genuinely testing and engineering a quality product that meets ISO standards as the claim they are. Not to say everyone in the business is doing this but can we at least have a little faith in humanity for once!? |
F3010418.00 |
08-18-2018, 11:05 AM | #20 |
Rep 4,327
i have had a k&n and unifilter(foam flows better than gauze) in the past. no objective testing. subjectively(butt dyno), found both to make slightly more noise. power gains, if any, were insignificant.
with both filters long gone, i just recently threw out the cleaner and re-oiling spray for both which was on the shelf for years, and thought to myself what a waste of money and time, and how they get you with all that marketing. having said all that and "knowing better", getting a high flow drop-in still occasionally crosses my mind. if i were to, i'd just get a dry filter. clean it with low pressure air (reverse flow) and/or vacuum it. wash it if it was really bad. if you want to try something i'd just get this ebay one. 1/3 the price of k&n and 1/4 the price of afe dry, probably works the same. if it's junk, it was just $18. https://www.ebay.com/itm/Reusable-Bl...cAAOSwEZdZ8vug if you have more money to waste and want to try the name brand stuff https://afepower.com/afe-power-31-10...y-s-air-filter https://www.ecstuning.com/b-pipercro...er/pp1885~ppc/ https://www.hpashop.com/HPA-F30-F32-...Air-Filter.htm i'd monitor and clean the foam ones more often as there are more holes and less material. this ain't rocket science... |
08-18-2018, 11:13 AM | #21 |
Rep 16,079
08-18-2018, 11:39 AM | #22 | |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
http://nicoclub.com/archives/kn-vs-oem-filter.html The ISO 5011 Standard (formerly SAE J726) defines a precise filter test using precision measurements under controlled conditions.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
