10-09-2019, 05:41 AM | #1 |
Rep 199
Car Shake/Judder
When at a standstill and idle, not jumping revs or anything, my cars shakes like the revs drop.
It used to it little and often to more frequent. Any ideas? |
10-09-2019, 10:55 AM | #2 |
¯\_(ツ)_/¯
945
Rep 1,762
Mine has done the same about one every few months. What mods do you have on the car or is it stock? Did you scan the car to see if there are any pending codes present?
10-09-2019, 01:38 PM | #3 |
Rep 199
10-09-2019, 01:53 PM | #4 |
Rep 38
I am having the same symptoms and I don't like it - shuddering at idle without the rpm dropping. Changed plugs, coils (regular maintenance tbh, 90k km on track) and it did not change a thing.
Probably it is normal and a result of the low output combustion mode of DI engines and is something we have to accept. |
10-09-2019, 01:53 PM | #5 |
Rep 640
Drives: 2008 M3 (E93)
Any check engine lights? How old is the car? and how much mileage?
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
10-09-2019, 05:54 PM | #6 |
Big Turbo Boys N Girls
327
Rep 579
When is the last time you checked on your valves? DI engines gum up the intake valves and this results in poor running car and shaky idle. Valves should be cleaned every 100K or so.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
10-10-2019, 05:04 PM | #9 | |
Rep 206
CURRENT: '18 340i |
10-11-2019, 10:22 AM | #11 | |
Rep 199
Was thinking flywheel or engine mounts? Sometimes the shake is violent, similar to when a car drops revs then the revs come back. |
10-11-2019, 10:30 AM | #12 |
Rep 199
10-11-2019, 10:37 AM | #14 |
Rep 38
10-11-2019, 04:24 PM | #16 | |
Rep 640
It could be a couple of things. At a standstill though, you likely wouldn't feel a problem with flywheel and engine mounts would only be affected under load but would not cause a shuddering or engine idle drop. It's possible your plugs are starting to foul out. But usually you would also feel something like a power loss upon acceleration as well and you would likely feel it most/all the time. It could also be your fuel pump starting to fail. I had a 2011 328i xdrive and the fuel pump went right around the same mileage. It could be working most of the time but every once in a while it may not pump at the proper pressure causing a lack of fuel, hence the shudder. Tough to say without really experiencing the problem or without any check engine lights
Solidjake945.00 floridaorange10163.00 |
10-11-2019, 05:54 PM | #17 | |
¯\_(ツ)_/¯
945
Rep 1,762
Savageenterprise980.50 |
10-12-2019, 05:55 PM | #18 |
Rep 38
Hi Guys,
I have given my MAF a bath today and the car seems to idle without shuddering even though it still vibrates a bit. Maybe it is due to AC compressor, cabin resonating or whatever. My dad's X3 with the same engine n20 idles so smooth and without any vibrations that I start to envy that comfort even though I don't like SUVs. Do you guys also feel some vibrations on idle with AC turned on? Best regards |
10-13-2019, 02:58 PM | #19 | |
¯\_(ツ)_/¯
945
Rep 1,762
