BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
      01-16-2022, 09:00 AM   #2047
Cobra358
Drives: bmw 335i
Originally Posted by IMS-340MP View Post
It's good, some timing inconsistency between cylinders but ok.
Try to log at least in 3rd gear or preferably higher, multiple gears if you can.
I am not so sure. Did you see the HPFP drop to 1600? That doesn't seem correct to me? Why would it do that on a 91 map?
arvi60461.00
      01-16-2022, 09:09 AM   #2048
Jnat
DisplacementReplacement
Jnat's Avatar
394
Drives: 2020 X3M
i'm thinking anything under 2000 psi is cause for concern so agree...
2020 X3M /// MHD Tune
Prior Bimmers
2017 240XI Hybrid / FBO / MHD E40
2015 235XI FBO / MHD E30
2009 335XI FBO / COBB / E30
arvi60461.00
      01-16-2022, 09:23 AM   #2049
IMS-340C
IMS-340C's Avatar
Egypt
395
Drives: Self Tuned 340i 8AT RWD
Yeah noticed that but timing and timing correction are ok, the ECU will close the throttle or pull timing if something not right.
But as I said it's a 2nd gear log I would like to see a proper 4th gear log for better judgement.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT --------
      01-19-2022, 05:40 AM   #2050
MeByName
Drives: BMW 340IX
Adding mine here.
3rd and 4rth - https://datazap.me/u/bmwest/4th-5fth...=11&zoom=24-67
4-5-7 - https://datazap.me/u/bmwest/test?log...-46&zoom=26-68
Missfires and Check Engine - https://datazap.me/u/bmwest/ce-missf...18-19-20-21-22
Seems like last replacement of spark plugs was not going well.
      01-23-2022, 05:19 AM   #2051
IMS-340C
IMS-340C's Avatar
Egypt
395
In terms of safety and performance logs are good, some corrections here and there but nothing dramatic.
Most probably the DTM light and missfires are a result of very low fuel rail pressure not spark plugs, could be a sign of HPFP failure.
Other than DTM light and missfires are you noticing any long cranks ?
Originally Posted by MeByName View Post
Adding mine here.
      01-23-2022, 05:48 AM   #2052
MeByName
Drives: BMW 340IX
Adding mine here.
3rd and 4rth - https://datazap.me/u/bmwest/4th-5fth...#38;zoom=24-67
4-5-7 - https://datazap.me/u/bmwest/test?log...#38;zoom=26-68
Thanks for the review.
I have replaced spark plugs to the correct ones(NGK) and gapped them to 0.5mm.
Some time ago I have also replaced fuel injectors, though that might be a reason as well.
HPFP is TU oem, it's 1 year old.
I will try to test it again, after snow will stop here.
      01-23-2022, 05:51 AM   #2053
MeByName
Drives: BMW 340IX
Adding mine here.
Adding mine here.
Is it a case that fuel pressure is low after switch of gear, because of disability of 3,4,5 cylinder?
      01-23-2022, 07:28 AM   #2054
IMS-340C
IMS-340C's Avatar
Egypt
395
No, fuel pressure drop occurs in gear.
Check what fault code the DME registered.
      01-23-2022, 07:29 AM   #2055
MeByName
Drives: BMW 340IX
Pretty easy. Recorded them.
      01-23-2022, 07:49 AM   #2056
T_H_O_M_A_S
Drives: M140i
hpfp behavior is normal , post shift your rpm drops , so output aswell , the quantity valve adjusts and comes right back up . although the resolution of your logging seems low , or is it normal in mg flasher ?
once again why gapping ?
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
      01-23-2022, 08:13 AM   #2057
MeByName
Drives: BMW 340IX
Seems to be normal in mgf. I can increase a resolution of logs, could you please give me some hint on soft which I can use for this?
      01-23-2022, 08:21 AM   #2058
T_H_O_M_A_S
Drives: M140i
maybe some users with xp in mg flasher can help
putting your units into psi is easier to read , because its mainly used overhere
https://datazap.me/u/thomas/stg2-hpf...ata=3-17-18-20
this is how its looks in mhd , yours is too rough
      01-23-2022, 09:03 AM   #2059
IMS-340C
IMS-340C's Avatar
Egypt
395
It's not post shift it's in gear, hover to 5000 RPM in the log below, fuel pressure drops from 20 mpa to 11 mpa:
https://datazap.me/u/bmwest/ce-missf...&data=11-14-15
      01-23-2022, 09:19 AM   #2060
T_H_O_M_A_S
Drives: M140i
its paints a different picture
anyway i would start with oem plugs and gaps anyway and relog
forget the gap bs
      01-23-2022, 01:00 PM   #2061
MeByName
Drives: BMW 340IX
https://datazap.me/u/bmwest/ce-missf...;data=11-14-15
Could it happened because of misfire?
      01-23-2022, 10:29 PM   #2062
b7ff
Indonesia
Drives: BMW 340i
Hi Guys, I have a Stage 2+ 340i using BM3 OTS 93 Oct tune and brand new TU pump.. Just wondering whether you can give some inputs to my data-logs as there are some "knock detected" -- during normal driving and some on WOT. Is this troublesome?
I see that Cylinder 5 continue to see the biggest timing correction mostly, is this a cause of concern? How much timing correction will start being a problem, >5 degree?
Logs on normal driving:
https://www.bootmod3.net/log?id=61e2...729b3b8e49702c
https://www.bootmod3.net/log?id=61eb...729b3e67787c7a
Logs on WOT (through several gears):
https://www.bootmod3.net/log?id=61eb...90c640becd3103
https://www.bootmod3.net/log?id=61eb...729b40366d4ec5
Just wondering whether its the bad fuel octane, bad spark plugs (it is only 10k kilometres old) or heat?
      01-24-2022, 03:05 AM   #2063
IMS-340C
IMS-340C's Avatar
Egypt
395
If Fuel pressure target also drops I would say yes.
Try re-gapping the spark plugs to original gap, if it didn't work buy another new set from a different source.
      01-26-2022, 01:30 PM   #2064
vcx
vcx's Avatar
82
Drives: 340 xdrive MPPSK 6-manual
Hello!
Could someone please explain me what is "ignition angle" (vs timing correction), and what value is considered normal?
Thank you!
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07
      01-26-2022, 05:32 PM   #2065
b7ff
Indonesia
Drives: BMW 340i
Any help or input for the below will be much appreciated guys, I am considering to bring down my tune to Stage 2 91 Oct if you guys think this is NOT safe.
      01-26-2022, 09:53 PM   #2066
talontdone
talontdone's Avatar
Drives: 2017 BMW 340Xi
Base Map E85 logs with Vargas GC ...car felt a bit faster than my 93 map but nothing crazy. A few more degrees of timing up top (2-3 degrees) but similar boost to 93 tune ... thoughts???
https://www.bootmod3.net/log?id=61f1...90c609919ff44e
https://www.bootmod3.net/log?id=61f1...90c60c0769c69a
      01-28-2022, 07:38 PM   #2067
WrxToBeamerGuy
WrxToBeamerGuy's Avatar
492
Drives: BMW 340i xDrive
Everything about this data log is garbage
My timing pull is terrible
My HPFP is dropping during a pull
My boost is off target
My AFRs are fine
Is all of this because of my HPFP dropping off? I have terrible fuel here in Utah (91 Octane) but I did dyno tune this car in the summer with PJ.
This is stock turbo, stock fuel pump.
https://datazap.me/u/wrxtobimmerguy/...39-40-41-42-43
This is dyno revision 3
      01-30-2022, 03:00 PM   #2068
vcx
vcx's Avatar
82
Originally Posted by vcx View Post
Hello!
Thank you!
Bump!
Corvette C6 Z06 Z07
