01-15-2022, 07:32 AM | #67 | |
Rep 4,876
Maybe the low end boost spike ends up with a power cut? PTF did mention they increased the boost level across the band. All I can say is I thought the car was a demon before, but it's just crazy now. It was getting more to the acceleration feeling my boss's Telsa P100D felt like! What I can say is with that extra low end grunt, I can see how people could get themselves into precarious situations if you kept hard on the throttle when the nannies started to kick in. If you start to let up, the TC brings everything into check and all becomes well again. |
Beet6.50 |
01-15-2022, 10:35 AM | #69 | |
Rep 126
Wires1645.50 |
01-15-2022, 11:02 AM | #70 |
Rep 82
I think we should all always be ready for the car to loose traction and the rear end to step out, Just like if the brakes lock up or you are on snow/ice, need to pump the breaks, counter stere etc. These newer cars have ridiculous power now, great brakes and handle well. I remember when a 14 second car was fast, 15 mpg was great, poor brakes, no anti lock, more fish tailing, manual trans, car wouldn't turn and no traction control. The amenities now for safety reasons are great but they shouldn't be relied upon as much as they are by the driver, you have to be prepared for anything and not blame the car or the tune.
Wires1645.50 |
01-15-2022, 12:50 PM | #71 | |
Rep 126
1.Read what people have been saying..and no not all of them are 17 and just started driving 2.Drive around for awhile with the previous gen maps. I have for years and I could always nail it in any situation and I NEVER lost control but it was still fast as could be and that was stage 1 93. And apparently even with the new stage 1 93 people’s cars are breaking loose and spinning rpms up and up which exacerbate the loss of control. Sorry but more than likely it has something to do with one of the many many parameters they set with the OTS maps. It’s just a matter of dialing in some other setting(s). |
01-15-2022, 05:51 PM | #72 | |
Rep 4,876
As I mentioned before, I think the root cause is PFT fixed a bunch of stuff, the engine can now spool up insanely faster, which is effecting the OEM traction control PID loop (fancy engineering crap). I'd assume since they are doing the custom ROM stuff, they would be able to touch that as well, who knows. But that isn't an easy task to dial in. If it's too far the other way, everybody whines, complains and moans on how aggressive the TC now is. And how it "never did that on the 2.1 and prior maps." But I think it's more than just plugging a couple numbers in here and there. And maybe I'm wrong, and I am willing to eat crow, but I 100% agree with Cobra358's comments. If you just pin the gas on a cloverleaf, or doing a corner, you need to expect crap may go sideways. I've got hard on the throttle with OEM tuning, and the car can come unglued. With this new map, it just is that much more aggressive that one needs to be aware of tire condition, road condition, temperatures, etc. Like I said, with great power comes great responsibility. |
john_f3016.50 |
01-15-2022, 06:40 PM | #73 | |
Rep 82
01-15-2022, 07:21 PM | #74 | |
Rep 126
01-16-2022, 04:10 AM | #75 | |
Rep 9
I could get my wheels spinning at 2000rpm with about 50% throttle position. Wires, how much power do I have at that moment? 50ftlb more torque? You really have no idea what you're talking about. Please explain us what tables you modify to get that much difference with the same hardware? |
01-16-2022, 10:17 AM | #76 | |
Rep 4,876
50 ft lb is more of a "that's what it feels like" I'm not saying that's what you are getting. And perhaps you are down low compared to the past map do to the fixes they did? They upped the boost across the entire band == more power. They fixed boost spikes down low under load (IE when you are taking off from idle). How much of that impacts extra DME intervention of over-boost retard, knock intervention, etc? Have you tried loading in the 2.1 map, do a drive, and then load the 2.2 map and do the exact same things? There is a HUGE difference on the power it's delivering on my car. As a FYI, your car is delivering power based on torque targets, not boost targets. At 50% throttle you will be getting VERY high torque. Turn on your sport gauges and you can see what the DME should be targeting. It's not 50% power at 50% throttle if that's what you are thinking. I've had the opportunity to drive BM3 on the 2.0, 2.1 and 2.2 maps over the past couple years. When I initially bought the tune, my concern was if I had a brain fart, and nailed the gas, would the extra power have the car fully lose control. Here is what I've experienced over the map changes (340, AWD, 8AT 91 octane, comfort or sport mode). 50% of the year I'm on winter tires, and I live in a place I can get 4 freaking seasons on any given day. v2.0 / stage 1: Off the line felt 100% stock, no difference in the traction control or power delivery. Somewhere around 2-3K rpm, there was a step jump in power, and then it just took off, but never impacted traction. v2.1 / stage1: The fixed that step jump and the power came on smooth and boost gained rapidly. Even on wet pavement, I could get on the throttle hard, and no tire spin. -- added a catted DP -- v2.1 / stage2: Same feel of power delivery as stage 1, just more power. The car would now spin tires off the line on wet pavement and I started thinking this game would start to be paid in tire wear. v2.2 / stage2: Power comes on VERY hard at the bottom end. If you played with their anti-lag tune, it feels like that off the line. Now if I've hard on the throttle (50%+ / 2000 RPM+) it will spin tires unless it can find traction. |
01-16-2022, 10:32 AM | #77 | |
Rep 4,876
Like I said, if it concerns people, open a ticket with them. It seems all here are assuming they patrol the forums looking for issues. My only concern about the 2.2 map is I can see that my tire wear is going to increase. The nannies kick in under lighter load/RPM's which is what I want them to do. |
01-16-2022, 04:00 PM | #78 |
Rep 3,189
Power is being requested based on load, not torque, in relation to throttle input. If you have a linear throttle map like in comfort mode of TC fully off, 50% throttle will target 50% of the tunes max load target for that rpm. If you use the sport or sport+ settings throttle is not linear and 50% throttle (with your foot) is closer to 80% throttle requested.
Wires1645.50 |
01-18-2022, 11:45 AM | #80 | |
Rep 126
335kc4.50 |
01-19-2022, 01:14 AM | #81 |
2JZ-GTE
3038
Rep 3,992
I'm stage one but I found it asked for half a pound more of boooooooooooodst and 3° less timing
01-19-2022, 09:02 AM | #82 |
Rep 133
For anyone in this thread looking for answers on the apparent TC issues, check out the thread I have created specifically on this topic. PTF has explicitly acknowledged the problem and is working to address it. As of this morning they provided me with a test map that as far as I am concerned 100% addresses the TC problem while retaining frankly terrifying amounts of torque. See full update here: https://f30.bimmerpost.com/forums/sh...3&postcount=34
F36 /// 440i Grand Coupe - Carbon Black - MPPSK - M Sport - Carbon Fiber Aero - Bm3 Stage 1
lemonana3.00 |
01-19-2022, 05:20 PM | #83 | |
Rep 4,876
