01-15-2022, 11:40 AM | #1 |
Rep 732
"Adding" E85 to tank for timing corrections?
Is it safe to add a gallon or two of E85 to my tank if I have low quality gas? Ie, add 93 octane and I get timing corrections, could I add E85 to boost the octane and get less corrections? Is there a certain point where the car can't run well without an E30 map, or does an E30 map just have a higher octane requirement that can only be had with E85/race gas.
Im not sure if that is how it works or not. Any insight or explanation? |
01-15-2022, 12:54 PM | #2 | |
Rep 558
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
01-15-2022, 04:35 PM | #3 |
Rep 282
there is NO 93oct fuel that doesnt have any corrections with any 93oct map
all tuners have this , if you cant stand them add ethanol or toluene .
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
dmanb2b2124.50 |
01-15-2022, 05:47 PM | #4 | |
Rep 126
01-15-2022, 07:52 PM | #5 |
Rep 1,454
If you're gonna add some E to clean up timing, might as well run the E30 map lol.
2022 CT4-V Blackwing 6-speed
eluded3038.00 |
01-15-2022, 10:56 PM | #6 |
Rep 3,368
01-16-2022, 02:31 AM | #7 |
2JZ-GTE
3038
Rep 3,992
I tried everything, add in a few gallons of e and the solution was to run e30
01-16-2022, 08:17 AM | #8 | |
Rep 94
01-16-2022, 09:06 AM | #9 |
DisplacementReplacement
409
Rep 1,100
Ethanol is very addictive and what i mean by that is, it is an effective and relatively inexpensive fuel that increases performance visa v the octane boost and cooling affect among others. I would say if you have access to it, use it, turbo engines especially tuned are better off with it imo assuming you log and make sure your tune is handling it.
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
imperfectluck426.50 |
