11-27-2017, 07:43 AM | #1 |
Rep 6,944
Formatting USB stick for BMW map update
I keep getting this message on my PC:
The USB device selected has been formatted using the wrong file system. Please format it using a FAT32 file system. (FILES0069) I am using a 64GB USB 3.0 stick, which I have previously used for the 2017-1 map update. When I try and reformat the stick my Windows 10 PC gives me the choice: File System: exFAT / NTFS (I choose exFAT) Allocation Unit Size: quite a few choices here, but 128kb is the default - I have tried 128kB and 32kB and still get the same warning message. Any ideas please? |
11-27-2017, 07:48 AM | #2 |
Rep 1,455
The error message is telling you the problem.
You need to format FAT32, not exFAT You will probably need to use Disk Manager to partition the stick into two separate 32GB partitions. You should then be able to format FAT32. I think FAT32 has a 32GB limit |
JD64270.50 |
11-27-2017, 08:47 AM | #3 |
Rep 404
your best bet is something like the HP usb format tool
http://www.softpedia.com/get/System/...mat-Tool.shtml |
JD64270.50 |
11-27-2017, 09:43 AM | #4 |
Grumpy Old Man
1334
Rep 1,306
I've just had exactly the same issue myself today.
Downloaded this - EaseUS Partition Manager FREE - from here https://www.easeus.com/partition-mas...rmat-tool.html and it worked perfectly.
Alan
JD64270.50 |
11-27-2017, 12:01 PM | #5 |
Rep 334
Assuming windows:
Open Command Prompt (type "cmd" in search or run box) At the prompt, type "format /FS:FAT32 X:" Replace the letter X with the drive letter for the external device you wish to format and hit Enter No need for downloads/tools - it's all there in the OS |
11-27-2017, 12:24 PM | #6 | |
Rep 6,944
You would have thought that they could have given that as an option when I right clicked format, instead of just exFAT / NTFS |
12-28-2017, 04:09 AM | #7 | |
Rep 3
Non-Compatible medium (file system) The selected folder is not suitable for unpacking the map material. Please select another folder to unpack the map material. (UNZIP0077) I am only partitioning part of the disk, the rest is in NTFS. Could be the reason. I am surprised more people are not frustrated by this. Win95 DOS programs were more intelligent than this piece of software. |
10-18-2018, 04:34 PM | #8 | |
Rep 1
Of course, first I had to track down something that'd hold over 32GB. Eventually found a MicroSD card in my camera that I had to backup and format, after finding a SD-to-USB adapter as my new(ish) laptop doesn't have an SD card slot. BMW Download Manager is currently unzipping with about as much speed as a 1982 Lada. And not one of the nice ones. I might actually be able to try it in the car sometime next month! I'm still in the all excited stage, having picked up my shiny new (well, four year old) F31 just two days ago. |
allachie91334.00 |
10-19-2018, 12:47 AM | #9 |
Rep 1,303
There is a far easier way....
As long as you have one fat partition big enough to hold it use a zip tool to manually extract it. I have used my 500gb external hard drive (powered by usb) with a single 40gb fat partition. Got the same error as the OP. Found the folder the bmw tool downloaded it too - somewhere like - local user/app data/ bmw. Its actually a zip file so manually unpacked it to my drive and the car picked it up fine. |
Tjeez0.00 |
10-19-2018, 04:05 AM | #10 |
Rep 797
Same problem with MacOS - I have to retrieve the downloaded .zip file from my temporary items folder and manually unzip that, then copy across to the (correctly formatted!) USB drive.
Hopeless.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG |
10-19-2018, 07:14 AM | #11 |
King of the North (living in the east...)
1056
Rep 2,154
I had no issues just allowing windows to format a new 64Gb drive however it wanted.
Used BMW download manager to transfer the files, and boom, all done. Worked straight away as soon as I plugged it into the car. FAT 32 is not compatible as it can't recognize the data >32Gb I believe....
2021 M340i in mineral white, options galore
Previously 2018 440i GC in MG 2015 330D F30 MSport EBII 2012 Alfa Guilietta 2.0d Veloce 2009 Fiat bravo sport 2000 ST Mondeo |
12-09-2018, 05:24 AM | #12 |
Rep 1
Kan inte spara ner kartfil på FAT32 formatterad USB minne
Har testat det mesta som skrivits i denna kolumn utan att lyckas
Har testat att formatera USB minnet till alla FAT32 system (cluster 2kb till 64kb) som man kan hitta men får alltid samma fel varje gång. "Fel filsystem". Har checkat USB minnet och programmen säger att minnet är formaterat till FAT32. Men det kommer ändå ett felmeddelande. Har testat med både 32 och 128Gb USB minne. 128GB minnet har jag även testat att dela upp i 2 partioner där den mindre var 32Gb vilket blev tillräckligt för kartan men icke.. Har testat med program från EaseUS partion och MiniAide Fat32 Format. Kan inte spara ner kartfilen. Några tips ? Last edited by Rune; 12-09-2018 at 05:51 AM.. |
12-09-2018, 05:37 AM | #13 | |
Rep 6,944
Kanske är 128 GB USB-stick problemet? |
12-10-2018, 03:00 AM | #16 | |
Rep 1,303
Just format the disk in FAT32 and then unzip the contents (from wherever you got them!) to the usb key and you'll be ready to go!! |
12-10-2018, 10:32 AM | #17 |
Rep 542
Yes. But i think youll find the 64gb drive you have formatted with fat32 has created a drive that is now only 32gb.
Use exFat32 to format above anything above 32gb for the car. You can then manually extract the zip files to it. That’s how it worked for me. |
01-08-2019, 09:28 AM | #18 |
Rep 112
Drives: BMW 1M Coupe + M2 + 330e
When I plug my USB stick into the car (armrest or the port located on the panel below the AC control panel) nothing happen (the update screen should pop up in theory).
And I can't find a way to start/force the update in the iDrive. Car : 2016 BMW 330e F30 with NBTevo USB stick: Samsung 64Gb Fit Plus Maps download and saved on the USB stick using the BMW software "Download manager" I formatted the USB stick in FAT32 with my MacBook. Could someone help me ?
BMW 1M Coupe - AW - 2012
BMW M2 DCT - BSM - 2017 BMW 330e iPerformance - GSM - 2016 |
01-08-2019, 09:47 AM | #19 | |
Rep 1,660
With the file unzipped, you should hopefully have 4 files on the root of the drive 1x config 3 x NBTEvo_ECE..... etc 2 directories (or folders if you prefer - I am a DOS Dinosaur!) 1 directory named 1 with 8 sub directories 1 directory named FSC with one file in it. Check to see if all unzipped properly. My 2018-4 download was 30.4Gb on the stick HTH Last edited by AlwynMike; 01-08-2019 at 09:48 AM.. Reason: Spellchucker |
01-08-2019, 10:29 AM | #20 |
Rep 71
When you format USB stick with a MacBook it creates additional files. Someone told me you need to delete those files. I put the USB stick in a windows machine and deleted those files and had no problem installing maps to the car. You could try that.
01-08-2019, 11:49 AM | #21 |
Rep 112
I just deleted the "hidden files" in order to have exactly the files described by AlwynMike but it's still not working.
I'll try with a SD card in a USB-SD adapter
01-08-2019, 02:39 PM | #22 |
Old Fart
361
Rep 693
I just use a little program to format my 64gb USB stick and it works perfectly in the car...
https://www.google.co.uk/url?sa=t&rc...jk8SVB9YCZhNYg It's hilarious just how slow the BMW download manager is at putting the files onto a USB 3 drive though
The doctors said it's OK to listen to the voices..... just don't do what they tell me
