05-08-2018, 03:45 PM | #13355 |
Rep 5
Hi Shawn I have downloaded e-sys and pzda files however when I click on the connection tab no car data comes up in the box it's just blank any ideas what I've done wrong ?
Any help much appreciated |
05-08-2018, 03:50 PM | #13356 | |
Rep 40,755
05-09-2018, 03:40 PM | #13357 |
Rep 5
the pzda file is correct installed and e sys in settings / program is set to C:\Data in main series I have folder F20\F20_18_03_524_V_004_001_000\adx\dist which is empty
How ever when i click on connection tab my target box is empty Last edited by Scott bishop; 05-09-2018 at 03:58 PM.. |
05-09-2018, 03:42 PM | #13358 | |
Rep 40,755
Make sure you have c:\psdzdata and not c:\psdzdata\psdzdata.
05-09-2018, 04:52 PM | #13360 |
Rep 40,755
05-10-2018, 02:18 PM | #13362 |
Rep 40,755
PM sent.
05-10-2018, 03:45 PM | #13363 |
Rep 5
Hi Shawn I'm trying to code 6NS into my F20 from 6NH I followed a guide however when I try to code HU it says please activate fa first with G008 would this be because my intergration level is higher on the car than on the e -sys ? Or is there something else I'm doing wrong
05-10-2018, 03:52 PM | #13364 | |
Rep 40,755
05-10-2018, 04:14 PM | #13366 |
Rep 40,755
At top of FA, it should show Active if it is Activated.
05-11-2018, 11:07 AM | #13368 |
Rep 40,755
PM sent.
05-11-2018, 11:44 AM | #13370 |
Rep 40,755
05-11-2018, 05:18 PM | #13372 |
Rep 40,755
05-12-2018, 04:06 PM | #13373 |
Rep 3
I've just configured these settings on my F30 330d (2017), and yes it works!! Thanks Frogman. My car, for reference
Now they're working, any ideas how you stop them from flickering? This doesn't appear to be a warm/cold check as its flickering really rapidly, rather than once or twice per second. And... the cold/warm front indicator check setting appears to be switched off already. MAPPING_SIDEMARKER_L_DEPENDENCY_FUNC: function_1 [00] MAPPING_SIDEMARKER_L_DEPENDENCY_PWM: level_nr [00] MAPPING_SIDEMARKER_L_DIMMED: not_active [00] MAPPING_SIDEMARKER_L_DISABLE_OUTPUT: initwert [00] MAPPING_SIDEMARKER_L_FIXED_PWM: pwm [00] MAPPING_SIDEMARKER_L_FUNCTION: standlicht [01] MAPPING_SIDEMARKER_L_IGR_RELEVANT: not_active [00] MAPPING_SIDEMARKER_L_OFF_MODE: level_nr [00] MAPPING_SIDEMARKER_L_OUTPUT: fra_v_l [0D] MAPPING_SIDEMARKER_L_PART_OF_WL: hard_on [02] MAPPING_SIDEMARKER_L_PRIORITY: priority_2 [02] MAPPING_SIDEMARKER_L_PWM_LEVEL_4: pwm_1 [00] MAPPING_SIDEMARKER_L_PWM_LEVEL_5: pwm_1 [00] MAPPING_SIDEMARKER_L_PWM_LEVEL_REAR: 8.2V [52] MAPPING_SIDEMARKER_L_PWM_LEVEL_REDUCED: 8.2V [52] MAPPING_SIDEMARKER_L_PWM_LEVEL_STANDARD: 8.2V [52] MAPPING_SIDEMARKER_L_SPARE_OUTPUT: spare_channel_1 [00] MAPPING_SIDEMARKER_L_VOLTAGE_PEAK: level_nr [00] MAPPING_SIDEMARKER_R_DEPENDENCY_FUNC: function_1 [00] MAPPING_SIDEMARKER_R_DEPENDENCY_PWM: level_nr [00] MAPPING_SIDEMARKER_R_DIMMED: not_active [00] MAPPING_SIDEMARKER_R_DISABLE_OUTPUT: initwert [00] MAPPING_SIDEMARKER_R_FIXED_PWM: pwm [00] MAPPING_SIDEMARKER_R_FUNCTION: standlicht [01] MAPPING_SIDEMARKER_R_IGR_RELEVANT: not_active [00] MAPPING_SIDEMARKER_R_OFF_MODE: level_nr [00] MAPPING_SIDEMARKER_R_OUTPUT: fra_v_r [0E] MAPPING_SIDEMARKER_R_PART_OF_WL: hard_on [02] MAPPING_SIDEMARKER_R_PRIORITY: priority_2 [02] MAPPING_SIDEMARKER_R_PWM_LEVEL_4: pwm_1 [00] MAPPING_SIDEMARKER_R_PWM_LEVEL_5: pwm_1 [00] MAPPING_SIDEMARKER_R_PWM_LEVEL_REAR: 8.2V [52] MAPPING_SIDEMARKER_R_PWM_LEVEL_REDUCED: 8.2V [52] MAPPING_SIDEMARKER_R_PWM_LEVEL_STANDARD: 8.2V [52] MAPPING_SIDEMARKER_R_SPARE_OUTPUT: spare_channel_1 [00] MAPPING_SIDEMARKER_R_VOLTAGE_PEAK: level_nr [02] Last edited by doddy550; 05-12-2018 at 04:07 PM.. Reason: Added the settings |
05-12-2018, 09:49 PM | #13374 |
Rep 6
Hi, I have an f36. I have just fitted a m sport steering wheel. The steering whee buttons/paddlesl work fine however the lights behind the buttons don’t turn on, I did try to put the cluster on full brightness but made no difference and my horn isn’t working either. Any ideas? Cheers
