BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > New Aftermarket F30 LCI Headlights, thoughts?
      03-05-2023, 02:15 PM   #1
TylersF30
TylersF30's Avatar
Drives: F30 2016 328i
Stumbled upon these headlights modeled after the newer headlights. Not an exact replica but not bad for the price and there are sequential turn signals. They say there is an option for the OEM LCI adaptive LEDs and Xenons. But also halogens? Tempted to pull the trigger and see if these are any good but it's honestly a gamble. What are your guy's thoughts?
https://www.aliexpress.us/item/32568...d=fMOZzxdwACmJ
      03-11-2023, 07:33 PM   #2
bmwenjoyer
bmwenjoyer's Avatar
35
Drives: 2018 340i xDrive
My thought is that, when it comes to headlights, it is almost always better to just save the money and put it toward getting an OEM used pair.
Chicago (@gp_f30 on insta)
F30 340i xDrive M-Sport (Alpine/Coral) Stage 2+
F30 335i (Alpine/Coral) - SOLD
      03-15-2023, 07:57 AM   #3
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
design. Would work great with cars that have body upgrades (front lips, side extensions and etc). Imo, does not work well with stock cars' body lines.
Also, the turn signal brightness is too dim for my likings. - Safety concern.
In most cases this is a typical issue with aftermarket lights - development stage is too short and not enough effort in finetuning the driver/led parameters for appropriate brightness to meet standards. There is also light leakage into the rest of the assembly when the blinker is on...
The driving lights (aka angel/halo) and low/high beams seem to be adequate, but no visual proof of coverage/brightness.
Overall - reminds me of Audi headlights and, because of that, I would never consider for myself. To each - their own.
Thanks for sharing.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      03-16-2023, 11:32 AM   #4
bigdog34uz
Drives: 2007 e90 335i
I actually like these, because they are really different.
13.01 @ 107.6mph Mods: OETuning........
13.00 @ 108.89 JB4 Times
      03-23-2023, 02:12 AM   #5
TylersF30
TylersF30's Avatar
Thanks for sharing.
You bring up some good points. Interesting though that these aftermarket ones are actually based on the newer 3-Series Facelift (G20 I think); not really an exact replica but the same-ish style. They do definitely remind me of the Audi headlights too. I love angel eyes, but these would match my aggressive build and are unique since I haven't really seen anyone with these yet.
I did end up taking the gamble and buying a pair. So I will update the thread once they get here.
      03-23-2023, 02:13 AM   #6
TylersF30
TylersF30's Avatar
My thoughts exactly, while Audi and the newer G20 facelift sorta follow the same style. These are pretty unique on their own and I haven't seen anyone rocking these.
      03-23-2023, 05:40 PM   #7
Frankly30
Drives: F30
I saw these before too on Ali and expressed a bit of interest. They might look better on the car once you replaced the grill with someting like this: https://aliexpress.com/item/1005004341178260.html
      03-24-2023, 12:18 AM   #8
TylersF30
TylersF30's Avatar
Ah interesting, I have some kidney grills on mine right now. Those grills would match but personally am not a fan of their look.
      05-19-2024, 08:59 AM   #9
catalin.raileanu
Drives: f31 lci
Hi! I change my halogen headlights to Led headlights afermarket! I have this problem at high beam flinkering when is high beam set! And the led drl is close only i locked my car! If don’t locked, the drl stay open permanently!
      05-25-2024, 09:20 PM   #10
speedbirdblack
speedbirdblack's Avatar
Sri Lanka
26
Drives: f30 M-Sport
I changed halogen to depo long ago.
When the headlight switch is on auto, engine is switched off, Angel eyes stays until I open the door. I can fiddle on the idrve how long the DLRs to stay when the car is unlocked. Similarly you can completely switch them off on the idrve.
speedbirdblack
      05-26-2024, 10:19 AM   #11
gameson
Drives: 2015 BMW 320i N20
how bright is the aftermarket LED compare to OEM LED LCI headlight? i m thinking of buying the aftermarket LED LCI to convert my xenon, however if the LED brightness is the same or worse than OEM LED or OEM xenon, there is no point for me to spend $ just on the looks.
Thanks.
f32ftw98.00
      05-26-2024, 01:09 PM   #12
Simbad the Sailor
Drives: BMW F30 320D - 2015, N47T
looking good
      05-29-2024, 04:11 AM   #13
speedbirdblack
Sri Lanka
26
Drives: f30 M-Sport
Thanks.
I have read in this forum that OE LEDs are produce significantly less light output than OE Xenon. Interesting to learn about aftermarket LED output.
speedbirdblack
