BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > F31 335 xdrive oil leak
      06-13-2022, 07:26 PM   #1
B58-
B58-'s Avatar
Drives: M140- 335xdrive
Hi all
I've noticed an oil leak on my F31 whilst fitting an intercooler
It's around the turbo oil feed area any idea where it's coming from ?
Also notice oil around the injectors?
The car is a f31 335d xdrive
86k with full BMW service history
Any help
Is appreciated
      06-15-2022, 09:36 AM   #2
Sanjayo1
Drives: 1 series
hard to tell from the pictures, so I'll let someone else comment.
Curious as to which intercooler you went with though?
      06-15-2022, 03:07 PM   #3
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Oil around injectors pretty much has to be VC or PCV. Check spark plug holes also.
Oil down lower could be leaking from above (also VC), or turbo feed/return, which are less common.
      06-21-2022, 04:28 PM   #4
B58-
B58-'s Avatar
The oil can be seen on all the injectors
      06-21-2022, 04:29 PM   #5
B58-
B58-'s Avatar
Apologies forgot to state the car is a lci 335d xdrive
      06-22-2022, 12:17 PM   #6
thejeremyman9
4364
Ok, but the fact remains that the highest point in the engine is the VC
      03-16-2024, 10:19 AM   #7
B58-
B58-'s Avatar
Update it turned out to be the breather hose on the rocker cover I changed this and all seems fine
It was around £17 delivered from BMW
Genuine BMW Air Intake Breather Pipe Hose Rocker/Cam Cover N47Z/N57S 13717810772
https://www.ebay.co.uk/itm/283812716...mis&media=COPY
