02-14-2022, 11:10 AM | #23 |
Rep 3,877
Which vehicles are those illustrations for?
To use BMW's language as above - transferring more than 50% torque to the front is "virtually impossible" with the TCU in our F series! It is simply mechanically not possible to disable the rear axle! The topic has been discussed extensively before as well. Once again: Clutch fully closed: 50:50 Clutch fully open: 0:100 You can limit torque by wheel through the ESP system and the brakes. But the xDrive in most BMWs (newer smaller models excluded) CANNOT send more than 50% to the front axle. I think you are confusing torque and power…
02-14-2022, 11:33 AM | #24 | |
Rep 15,858
Covers E/F series. Both illustrations are in multiple technical documents.
And into the G-series... with the following BMW Technical Training quote for the G12, which is the cross reference for many of the G-series xDrive models. Quote:
02-14-2022, 11:37 AM | #25 |
Rep 3,877
Trusting words (I.e. marketing) is good, trusting mechanics is better
You may as well believe what you read, but please also pay special attention to words like "virtually", "theoretically" and so on… P.s. what I quoted earlier is also from BMW
02-14-2022, 01:43 PM | #26 | ||
Rep 15,858
BTW, I'm not in any way disagreeing in my comments with a 40:60 or 50:50 mechanical bias on a closed clutch. https://www.awdwiki.com/en/torque+split+ratio/ Quote:
02-14-2022, 01:51 PM | #27 | |
Rep 15,858
02-21-2022, 10:50 AM | #28 |
Rep 3,877
xDrive and the snowy slopes
03-05-2022, 07:52 AM | #29 |
Rep 5
This winter was the first in which I could try my F30 in the snow and I can say I am really pleasantly surprised. It was handling without any problems. But then again the snow wasn't that much. Compared to my previous car, so far I am really happy with my F30.
Running with 17inch tires by the way. |
03-05-2022, 02:30 PM | #30 |
Rep 611
I've heard such complaints few times. Usually the guys asked why their BMW drifts all the time, while their wife's SUV does not. In all those cases, the reason was the same - driving on snow in Sport+ mode...
03-10-2022, 03:31 PM | #33 |
Rep 16,086
My OEM Conti RFT weren't bad at all for the first 10,000 miles. With xDrive they were much better than FWD with snows all around. But the tread wear after 10k was pretty bad, so their usefulness in snow deteriorated. I replaced them at 22k, not wanting to run them in winter again.
03-20-2022, 11:23 AM | #36 |
Rep 611
According to all reputable comparisons I've seen, all winter tires from well known brands are very similar in grip in the snow. The only RFT winter tires I had were the Continental's, and they performed perfectly fine in the snow. Indeed, they suffered from all of the usual RFT drawbacks, and the dry and wet performance was pretty poor.
03-20-2022, 11:26 AM | #37 |
Rep 3,877
Strongly disagree. There is MAJOR difference in the performance of reputable winter tires!!
Example: Michelin X-ice are the worst winter tires I have ever driven, on any car. I had to find out that "X-ice" means "Not suitable for ice"!
03-25-2022, 04:57 PM | #38 | |
Rep 15,858
03-27-2022, 07:39 PM | #39 | |
Rep 40
What specifically don't you like? Mine out accelerates my wt, goes straighter than the wt when slipping.
2013 335i xDrive Melbourne Red my first BMW BMW, you might find better but you can't pay more |
03-30-2022, 09:56 AM | #40 |
Rep 562
Drives: 2017 BMW 330i xDrive
It's probably apples and oranges, but I find the xDrive to be very capable in poor traction settings, such as mud. I have yet to find anything that I can't get through with it. Traction isn't what I have to watch out for, just ground clearance.
Never realized just how much offroading kayaking forces you to do sometimes. The looks I get crawling past stuck trucks in my little blue Bimmer are great, though.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
Operator Mo64.50 |
05-02-2022, 10:48 AM | #42 | |
Rep 18
Exchanged them for non run flats, winter approved ones and the handling improved a lot in snow. In my case it was the continental wintercontact ones, really good tires. |
05-11-2022, 06:20 PM | #43 | |
Rep 2
celsdogg324.50 |
08-04-2022, 11:04 AM | #44 |
Rep 46
New F31 owner here. Plan to use it to get to skiing on deep days, and the roads in NM are often slow to get plowed. I am often forced to drive through a foot of snow. I will add snow tires for sure, but what LSD do you recommend?
If I'm honest, I'm not super familiar with the xDrive system. I assumed that it has open front, center, and rear diffs and uses electronically controlled braking to assist with loss of traction. |
