BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > N26 valve cover leaking again--most reliable valve cover?
      11-26-2023, 02:27 PM   #1
colin86325
Drives: 006 30i
Hi forum!
I had the valve cover gasket replaced about a year ago on my 2015 328Xi (N26) and I see it is leaking again on exhaust side, especially towards the back. Oil is dripping on exhaust manifold, and it smells bad.
I should've replaced the actual valve cover + seal instead, but you know what they say about hindsight.
Anyway, I am looking for advice on the most reliable valve cover to get. I'm not impressed with the factory one, which developed a warp or crack with less than 85,000 miles.
Some options I've considered:
  • good quality aftermarket N26 valve cover. Recommendations, especially from those who have put decent mileage on theirs?
  • aluminum valve cover. I've only seen aluminum N20 valve covers. I was thinking about ordering one to see if it can be modified to suit an N26. Does anyone have any experience with adapting N20 to N26 fitment?
Thanks in advance for your advice.
best regards,
Colin
      11-26-2023, 03:58 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I don't know about the fitment but I'd go with a well reviewed aluminum cover. Aluminum sheds heat, plastic doesn't.
      12-01-2023, 04:37 AM   #3
fortythirtyfive
Drives: 435i MS
Originally Posted by colin86325 View Post
Hi forum!
best regards,
Colin
I opted for a Febi one when I did mine, the savings over OEM was a bit of a no brainer.
Some have mixed opinions on Febi but their parts have never let me down, they're part of the Bilstein group and being German made I have always found them to be of good quality. Needless to say mine has been great since fitting.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
      12-06-2023, 04:26 PM   #4
colin86325
Drives: 006 30i
Thanks guys. I opted for the N20 HD aluminum valve cover from Uro. Rock Auto has if for about $200.
Hopefully it works for me!
      03-03-2024, 09:08 PM   #5
xHamfistedx
Drives: 328i / 330Ci
Any luck with the aluminum valve cover on the N26 ?
I think the engine sound proofing and decorative cover do not allow heat to escape the plastic valve cover very easily and contribute to the degradation of the cover sealing. But without that sound proofing the direct injection is pretty loud and sounds like a John Deere tractor at idle. The aluminum is an easy upgrade. Just swap the PCV cover cap to one with the vacuum nipple on it for the N26.
N26 PCV Cap .....
https://www.amazon.com/dp/B0C1SJ2MDB...v_ov_lig_dp_it
Aluminum Valve Cover.....
https://www.amazon.com/dp/B0C7MZYZK1...ding=UTF8&th=1
      03-04-2024, 06:17 AM   #6
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
colin86325 how did the aluminum cover work out for you?
Im due for a replacement myself and on the fence about which to get, would really appreciate your feedback on the URO aluminum unit!
      03-09-2024, 07:53 PM   #7
xHamfistedx
Change the PCV cover on the aluminum valve cover for the N26
The aluminum valve cover will work with the N26 motor, you just have to change the PCV cap to one with a nipple on it to allow for the N26 added vacuum plumbing attachment. Easy swap.
Billfitz8243.00
