01-08-2019, 04:12 PM | #1 |
Rep 1,894
Bimmercode - Error while reading coding data
Evening all,
Anyone had issues reading ECU's using the Bimmercode app (iOS) using the VGate BT OBD Adapter? I've managed to code the DKOMBI but when I try and read HU_NBT_EVO, I get a "Error while reading coding data" message, which is real bummer as it's got most of the options I'd like to code. On the G series the supported ECU's is very limited compared to the F series. I'm hoping this will change as the developer adds more support into later builds. Thanks. |
01-08-2019, 04:21 PM | #2 |
Rep 32,881
Did you do the “press start button 3 times in quick succession for diagnostic mode” that they state needs to be done on G series cars?
I didn’t need to on my G01 X3 to code the NBT EVO, but maybe it’s worth a try on yours. |
01-08-2019, 04:28 PM | #3 | |
Rep 1,894
Are you using the VGate BT or WiFi adapter? |
01-08-2019, 04:30 PM | #4 | ||
Rep 32,881
kitster541.00 |
01-08-2019, 04:35 PM | #5 | |
Rep 1,894
Which one did you get? https://www.amazon.co.uk/Vgate-ELM32...vgate+icar+pro https://www.amazon.co.uk/Vgate-Scann...vgate+icar+pro |
01-08-2019, 04:37 PM | #6 | ||
Rep 32,881
kitster541.00 |
01-09-2019, 06:45 AM | #7 |
Rep 1,894
I got a reply from the developer of Bimmercode. It seems like the USB CarPlay unlock has altered the coding data signature for HU_NBT_EVO, that's why it can't read the ECU correctly.
Trying to reach out to the supplier for a file to back it out......oh man, I should have just paid for CarPlay or reached out to experts the forum. Doh. I might try the £1 for the 1 Month CarPlay trial, see if that does anything. |
07-22-2019, 09:16 AM | #8 | |
Rep 2
Sorry to bring up an old post, but I am having the same problem as you mentioned. I also purchased a USB CarPlay unlock from Ebay. Now I can not get bimmercode to show me the headunit settings to code. Have you resolved your issue? If so, please tell me how you did it.
Thanks! Quote:
07-22-2019, 09:51 AM | #9 | ||
Rep 1,894
I never tried as I just couldn't be bothered!!! Apple refund me for Bimmercode, told them it wasn't working on my car. |
04-13-2020, 11:59 AM | #10 | |
Rep 1,407
Drives: 13' F30 328i 6MT
Were you guys able to resolve this? Im not sure what ( VO code NBT ) means off hand to fix.. Any help would be greatly appreciated.
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
04-13-2020, 06:24 PM | #11 | |
Rep 1,894
04-13-2020, 06:43 PM | #12 | ||
Rep 1,407
so I can code with the Bimmercode app and then reinstall my carplay when done. Any guides or help would be greatly apreciated or if anyone offers remote coding that your aware of id throw them a few bucks via paypal.
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] Last edited by QUiKSR20; 04-14-2020 at 12:29 AM.. |
04-14-2020, 12:31 AM | #13 | |||
Rep 1,407
04-14-2020, 03:26 AM | #14 | |||
Rep 1,894
VO Code the NBT ECU (resetting the NBT to default) Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (HU_NBT) => Select CODE. DO NOT CLICK ON THE CODE DEFAULT VALUES BUTTON. |
04-14-2020, 04:36 AM | #15 |
Rep 2,047
the only time I got an error code was when I didn't leave the engine running. I spent about 30 minutes completing the coding and when it came to updating the Vgate had lost connection. I had a "battery drain" warning after the dash cam had been running a few days, so I tried again with the engine running and it was ok
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
04-14-2020, 08:48 AM | #16 | |
Rep 1,407
06-13-2020, 06:24 AM | #18 |
Rep 138
Are you guys using Ebay Carplay? If yes and with the computer based install, you should have acess to a program that was used to install Carplay. With the same program you can uninstall it. Uninstalling it will ”open up” your NBT for coding again. After you’re done you simply reinstall the Carplay.
I had the same issues on my car with Ebay Carplay (computer method) and trying to code with BimmerCode. However the steps above solved my issues. Just to keep in mind that you have to uninstall Carplay when you want to code NBT and then reinstalling it. |
07-30-2020, 04:04 AM | #19 | |
MICATECH
Rep 7
Hi, I have same issue and have acess to Esys. I have never VO coded before and a little anxious about it. What you wrote seems straigyforward however. So if I do this it will return to exactly as it came from dealer???? Where does it get the info from to return it to as delivered state? Do I need to have made a backup for it to read to be able to do that as I dont have any backups but really want to learn how to make backups of each ECU or the whole car. Thanks guys |
01-05-2021, 12:16 PM | #20 | |
ENGIN33R
17
Rep 54
Thanks, I am having the same issue. I installed CarPlay using computer method and having an issue with HU module. I will try to uninstall and reinstall after I finished coding with BimmerCode. |
01-06-2021, 07:57 AM | #21 |
Coding ECU's remotely
445
Rep 1,176
You can code with esys but esys 3.27.1 is too old now for EVO, you need 3.33 or above but then you run into issues with the launcher.
If you revert to factory settings either using USB restore file (if your activation came with it) or Feature installer )make sure you have the latest version: HERE Or you VO code with esys then use bimmer code and then re-apply carplay. |
01-09-2021, 02:41 AM | #22 | |
Rep 271
I have CarPlay activated with feature installer and would like to remove for dealer software updates. Do I remove CarPlay with original feature installer or use the newer version you have linked?
2017 F36 440 LCI - Smoked Topaz | Auto | M Sport Plus | HUD | ICON Adaptive Headlights
