09-03-2019, 12:39 PM | #1 |
Rep 22
Rattle/loose/fart noise on acceleration F30
Hi, I've been struggling with a weird noise when I press the acceleration the best I can describe it as a light tin pit is light being banged when I'm pressing the acceleration or cards and being skipped like kids do on a bicycle.
Anyone had this or have it or know what it might be? It's a 328i 2012 |
09-03-2019, 01:50 PM | #4 |
Rep 36
I am thinking you likely are hearing what I've hear recently (here's my thread) : https://f30.bimmerpost.com/forums/sh....php?t=1647106
Does it sound like this? I found that in this thread - https://f30.bimmerpost.com/forums/sh....php?t=1646586 I ordered the parking brake cable retainer clip from ECS as it seems like that may be the cause. I'll replace it this weekend and report back.
2014 328i M Sport Estoril Blue Six Speed - Daily
2003 Corvette 50 AE Six Speed - Track/Fun |
YNoDpstk!3.00 |
09-03-2019, 02:52 PM | #5 | |
Rep 22
09-03-2019, 03:19 PM | #6 |
¯\_(ツ)_/¯
945
Rep 1,762
Look up wastegate rattle and also the exhaust flap rattle. I'm sure it's one of those two
09-03-2019, 08:05 PM | #7 |
Rep 59
Drives: F30 328i RWD
I'm in a similar situation to you too Nyc212
I only get it during light acceleration from a standstill and not while the car is already in motion. It's worse when I'm in moving from standstill on an upward incline. The sound seems to be coming from the rear side. I've looked under the car but nothing seems loose and doesnt seem to be exhaust flap rattle. Keep us posted if you find a solution. |
09-03-2019, 08:06 PM | #8 |
Rep 96
Does it change sounds once car heats up mine has a similar sound if I picture what yours sounds like? Mine sounds completely different depending on map temp ewg open or closed also I got a muffler res delete
09-07-2019, 09:36 AM | #9 | |
Rep 22
I had the car lifted twice and the mechanics can't find anything. Had a mechanic ride with me as well and also says he doesn't know. |
09-07-2019, 09:39 AM | #10 |
Rep 22
I'm just hoping it's not an engine issue, the timing chain on these gets me very afraid.
09-09-2019, 05:32 AM | #11 |
Rep 59
I dont think it's an engine issue (I hope too).
I'm thinking and hoping that a body trim under the car somewhere is loose and just needs to be tightened. |
08-20-2020, 09:28 AM | #13 |
Rep 1,624
I have had two similar rattles - one was the exhaust flap because the pin had fallen off. Quick replacement. The second (and ongoing) one is a slight play in the wastegate probably causing a wastegate rattle as Solidjake said. The exhaust rattle is very obvious once the pin's fallen off so I suspect yours being more subtle might be the wastegate rattle.
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
08-21-2020, 12:51 PM | #14 | |
Rep 106
10-07-2020, 09:13 PM | #16 |
Rep 2
Put the car in the air. Was able to relieve the sound with the help of 5 zip ties! Took all of 5 minutes, no tools needed or anything adjusted. |
10-12-2020, 03:35 PM | #17 | |
Rep 55
03-04-2021, 07:30 PM | #19 |
Rep 3
Drives: 2014 BMW 328i Sportline
This helped me out. I had the same problem with the cables, now the issue is fixed thanks to your pictures!
04-05-2021, 10:34 PM | #20 |
Rep 3
Finally, found the cure for the issue which I also recently started to experience.
Many thanks!!
2009 VW Jetta V MT (380hp Toy)
2011 VW Jetta V AT (All Stock) 2011 MB GLK350 (Hers) 2016 BMW 328iM (His) 2020 Porsche Cayenne Coupe (Hers) |
yl0.00 |
08-23-2021, 12:31 PM | #21 | |
Rep 55
Once the car was on jack stands I could easily see the broken clip. That is a lot of work to replace something that is bound to fail again. Rather have the zip ties fail and then easily replace them. |
