01-12-2021, 02:58 PM | #1 |
Rep 47
Best iOS app to check system readiness?
Hello,
Not sure if this is the right section so if it isn't I'm sorry. What is the best iOS app (read via obdii bluetooth connector) to check system readiness in terms of inspection emissions? Thanks! |
01-14-2021, 01:36 PM | #3 |
Rep 133
My guess is that bimmercode can probably do that? But I'm not sure. You can download the app for free and use the demo mode to poke around a bit and see if it looks like it has what you need.
01-14-2021, 02:43 PM | #4 |
Rep 66
Bump. I was looking for similar a while back. Found some apps on the App Store but they required a separately purchased adapter. All else fails, try using the BMW Drive Cycle Procedure. https://www.instructables.com/How-to...or-Smog-Check/.
Injen | Horsepower Freaks | Active Autowerke | VRSF
01-14-2021, 05:29 PM | #5 |
Rep 2,808
Drives: F33 430 and F39 M35i
i don't think bimmercode can do diagnostics? bimmerlink does. i have both and they both use the same connector or you can do direct obd2-enet-lightning
01-14-2021, 09:43 PM | #6 |
Rep 631
Drives: 2014 M6 Grand Coupe CP
I think "four stroke" which is a free app, under "emissions readiness" will give the answer.I have used that to check before going for the yearly inspection.
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
01-16-2021, 08:23 AM | #7 |
Rep 7
I don't know if it's the best, but it's free and does show emissions. Works fine with my Veepeak...
Car Scanner ELM OBD2 https://apps.apple.com/us/app/car-sc...2/id1259933623 |
