BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Headlight TMS errors, help please
      01-19-2021, 08:51 AM   #1
wings516
Drives: '11 X3 35ix & Turbo M3
I am getting errors 8041F0 and 8041FF
Driver/Right headlight driver module (TMS): Coding error
How do I go about fixing this in E-sys? Or do I need something else?
This was after doing a halogen to xenon retrofit.
My BMW dealer says the modules and wiring is fine as they are communicating, but they cannot do any intializing for the TMS unless they recode, which will then wipe my xenon VO retrofit...
Is there a way to code them properly in e-sys, or do I need something like rheingold/ista+?
      01-19-2021, 09:05 AM   #2
atzebmw
Drives: Tesla Model 3
Start E-Sys and connect the car.
Read VO (Hope you changed VO to Xenon) and read ecu.
Mark the TMS and on the right side „detect caf for swe“ and choose a CAFD you like.
Hit the button „Code“.
That‘s it.
      01-19-2021, 09:13 AM   #3
wings516
That‘s it.
Yes, I coded the VO according to the DIY writeup. Headlights, turn signals, brights etc work just fine. I just do not get the "dance" and the beams are cockeyed. My assumption is because I used "refurbished" TMS modules, those need coded...
Is it really that easy? I will try this first thing tonight! Thank you for responding.
      01-19-2021, 04:07 PM   #4
wings516
That‘s it.
Used a newer IStep and coded the FEM_BODY module
Then coded the LWR out. Still getting the same error...
      01-19-2021, 07:19 PM   #5
wings516
I am also getting this in ISTA+. No initialization happens.
      01-20-2021, 03:37 AM   #6
atzebmw
Did you also code the ICM?
      01-20-2021, 09:11 AM   #7
wings516
I did not... I have not seen any writeups about the ICM. I currently do not have the height/vertical sensors installed, so I have disabled LWR in the FEM module.
Is that in ESYS? Same procedure as FEM Cafd?
Thank you again for your help.
      01-20-2021, 09:31 AM   #8
atzebmw
The ICM can also be found in the ecu tree list in E-Sys.
But you only have to activate the VO, mark the ICM (or ICMQL) and Hit the button „Code“.
Please do not scare. There are many error messages in the car after coding, but they disappear after the ignition is switched off / on.
In the ICM is 1 value which differs between Xenon and Halogen.
      01-20-2021, 09:35 AM   #9
wings516
So if I am understanding correctly, after I added 522 and 524 to the VO, I needed to flash the ICM and FEM module with a newer CAFD, right?
When you say there is 1 value that differs between Xenon and Halogen in the ICM, do I need to FDL code that inside of there? Or will the CAFD flash take care of that?
Thanks
      01-20-2021, 09:58 AM   #10
atzebmw
Flash is the wrong word for that.
Flash would mean an software update.
But you only need to code these 2 ecus.
With the CAFD was a mistake from me, because i thought the TMS is a new ecu and appears in the ecu tree.
But i read that the TMS will be coded together when the FEM will be coded.
So the FEM or ICM don‘t need a new CAFD.
You only have to activate the changed VO and Code (Button „Code“) these 2 ecus.
No need to FDL Code something, because this 1 value will be changed by coding the ICM.
      01-20-2021, 10:00 AM   #11
wings516
No need to FDL Code something, because this 1 value will BE coded changed by coding the ICM.
Gotcha, well I've done all of that already and I am still getting those ISTA issues and warning indicators. Other places online say that the modules need your specific VIN coded into them, which I have no idea how to do.
      01-20-2021, 10:54 AM   #12
atzebmw
Here i found some hints that sometimes a new FEM is needed.
https://f30.bimmerpost.com/forums/sh...808444&page=14
The VIN will be transfered by coding, so i think that‘s no problem.
      01-20-2021, 11:42 AM   #13
wings516
I saw that before as well, but that is strictly if you are not re-wiring it. The wiring changes take care of that. I think I am going to buy brand new TMS modules and see what happens.. I can't seem to find anyone with the knowledge on how to code the TMS modules.
      01-20-2021, 12:07 PM   #14
atzebmw
Do you see the TMS as an own ecu like this guy here?
https://f30.bimmerpost.com/forums/sh....php?t=1679228
      01-20-2021, 12:25 PM   #15
wings516
Interesting. I think after ISTA initializes it, that should show up. Since that guy already had xenons, it was probably already in his tree.
Plenty of people have done this with success, so I must be missing something... ISTA clearly is pissed about the FEM not being encoded, but I have done a new CAFD code on it three times now...
The folder turns rainbow after I do it. I'm wondering if I am missing something there as well...
      01-20-2021, 04:17 PM   #16
atzebmw
No, normally an ECU appears directly in E-Sys after "Reading ECU" if it is connected correctly.
The problem here, however, is that there seem to be cars in which the TMS modules can be seen and coded directly in E-Sys, and with some models these do not exist, even if they have Xenon.
My old F30 (built 2014) also had Xenon, but I don't see any TMS modules when I call up the data from earlier.
That's exactly what I don't understand until now.
In the meantime, however, you can check whether the values have been set correctly.
E.g. in the FEM the value "XENON_OUTPUT_L" and "XENON_OUTPUT_R" should set on "output_channel" after coding.
And in the ICM the value "IcmKod_I_HSS_Connect" should be "05_Xenon_or_IAS".
      01-20-2021, 06:52 PM   #17
wings516
All of those seem to be defaulted to those values.
I am trying to run ISTA P now and I am getting this error... Not sure what to do about this and not much info online. I was going to try and encode the FEM through this, but I'm hitting another wall.
      01-21-2021, 02:29 AM   #18
sdbmwcoding
Drives: BMW M3
Are you sure you installed xenon and not led? From my understanding xenon you won't see tms modules in ecu tree. The only times I've ever seen initialization prompt and tms codes was for led headlights not xenon.
      01-21-2021, 06:29 AM   #19
wings516
Originally Posted by sd********* View Post
Are you sure you installed xenon and not led? From my understanding xenon does not use tms. The only times I've ever seen initialization prompt and tms codes was for led headlights not xenon.
100% xenon. What does it use? FLE?
Do you have to VO code these extra modules or should they automatically appear after VO Coding 522/524?
      01-21-2021, 11:20 AM   #20
wings516
Here are the headlights.
      01-21-2021, 02:28 PM   #21
sdbmwcoding
Drives: BMW M3
Send a photo of the front of the headlights. Whenever I read ecu/vcm from a car with xenon I do not see fle or tms, only FEM. There's no individual headlight modules to code on xenon headlights like there are in led headlights which is why I'm confused you see tms in your ecu tree.
      01-21-2021, 04:27 PM   #22
atzebmw
