12-23-2019, 03:08 AM | #133 | |
Rep 14
EDIT: Forgot to tell, my cars prod. date is 07/2013 |
01-12-2020, 10:46 AM | #134 | |
Rep 25
I retrofitted de LCI dual zone panel to my Pre LCI with single zone panel, someone coded my car but he said it is not possible to make changing the directions of the airflow work. All the other things works (AC - temperature- fanspeed - ) Can you tell me what i can do - changing some wires ? Thanks in advance Last edited by frank.lecock@telenet.be; 01-12-2020 at 10:54 AM.. |
01-12-2020, 11:55 AM | #135 |
Rep 325
I don’t know how it will work on single zone, I changed also climate box, from single zone to double zone. That came with double number of flaps motors and new wires on the box. On sinle zone, maybe you can change airflow direction by only one side, right or left.
Sorry but I can’t help you more. |
01-15-2020, 10:06 AM | #136 | |
Rep 25
01-18-2020, 05:05 PM | #137 |
Rep 14
Has anyone figured out on why the climate control panel can't be turned off after the retrofit? I can go to the lowest fan speed but normaly after pressing it one more time it should turn off. Mine stays on and I can't turn it off. I tried many things but gave up for now. My AC Light is not blinking and it never did actually. My AC gas is empty right now anyways, I still need to refill it as I retrofitted a entire new Air Box too, so I can upgrade from 1 zone to 2 zone climate.
Thanks in advance |
01-18-2020, 06:34 PM | #138 | |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
03-31-2020, 11:48 PM | #140 | |
Rep 3
05-20-2020, 07:22 AM | #141 |
Rep 1
Hello gentlemen, how are you doing?
Been trying to retrofit the IHKA3 to 2012 BMW 328i as well but can't seem to code the IHKA module. So I have changed the wiring from CAN to KCAN2, changed the build date to 02/2015 and updated the istep level to 2019. But it seems that esys nor ista won't recognize the module still. Attached the diagram tree from ISTA showing the IHKA module on red. Any input will be much appreciated. Many thanks! Kevin |
03-14-2021, 07:16 AM | #144 | |
Rep 2,302
Because only then it will be orange. During the daylight it is white. |
Robi Comino0.00 |
03-14-2021, 12:23 PM | #146 |
Rep 2,302
03-14-2021, 01:11 PM | #148 |
Rep 2,302
Ah interesting, i didn't know.
I think then the only solution is to install a climate panel from 2014 or earlier. Or i just found the value "display_farbumschlag_day_ni_chov" which is set to nicht_aktiv for my car. Maybe if you set this to aktiv it will work. |
Robi Comino0.00 |
11-26-2021, 07:38 PM | #150 | |
Rep 17
It took many days for me but eventually i have done this retrofit with luck. Physical labor was easy. The challange for me was 6th step. Somebody should explain dummies like me how to update BTLD, SWFL and CAFD files in a basic way. How do you change that values? Some part of values are written on the control panel but where is the rest? I still don't know how to find them. I have 2-3 friends waiting for me to do this same retrofit to their cars but i have no confidence. Any gentlemen to help me? |
04-03-2022, 08:46 AM | #151 | |
Rep 6
09-23-2022, 09:00 AM | #152 |
Rep 955
welp, going to give this another shot tomorrow evening.
i tried about 3 or 4 months ago but no dice, the module did not pop up in esys. at the time it was quite a while (2+ years) since i played with esys so i didn't bother trying too hard. i just finished flashing many of my modules from a 2015 istep to a 2022.03 istep... everything has been updated, so now i'm officially on a 2022 istep. so looks like i should just be able to wire the ihka3 in, use an fa with a late 2015 production date and the module should show up in the module list in esys. at that point see if it needs to be flashed or not (eg: newer firmware available?), if it does just tal upgrade it... and of course push a cafd to it. if it doesn't show up in esys, a video on youtube shows him vo coding fem_body with the production date set to late 2015... maybe this flips on the kcan2 interface or something. we'll see... will report my progress here. |
09-24-2022, 04:05 PM | #153 |
Rep 955
wow, that was a lot more difficult than i expected.
so, preface: a) my wiring is 100% correct, verified multiple times - make sure, ihka3 won't show up in esys if its not wired to kcan2 properly b) my car is on a very very recent istep, 2022.03 - make sure you are at a fairly recent istep... people say late 2015 is sufficient but who knows so according to the above ihka3 should just 'appear' in read ecu... right... nope. here is what i was able to do to have it show up: a) backup my fem_body fdl... if you don't have any changes in fem_body you can skip this... i have tons of changes as well as retrofit lci led fronts so... b) change my production date to 0716 c) vo code fem_body d) restart esys e) ihka3 shows up f) inject cafd, vo code ihka3 g) change my production date back to my original h) vo code fem_body i) restart esys j) restore my cafd result: fa + fem_body back to original state, ihka3 factory coded and showing up in esys. warning : do all the above at your own risk... i strongly recommend multiple backups of your fa as well as "read svt" and "read ecu"... enjoy! edit : after all of this in hindsight I should have tried to vo code a random module (eg idrive controller) and see if that makes it show up. I think when you vo code a module esys regenerates the vcm and msm even if the check boxes in options are unchecked. this is judging strictly by the log that pops up when u vo code a module. it writes the vcm even if boxes are unchecked in options. Last edited by anom3; 09-25-2022 at 05:05 AM.. |
09-25-2022, 02:43 PM | #154 |
Rep 523
You could write svt manual and vo code IHKA3. One more posibility.
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
