08-16-2017, 09:37 AM | #4 |
Rep 1
I always thought the 330e uses a bespoke muffler because of the battery pack...would love to have a meatier exhaust note on mine though. Subscribed...
Edit: pic from google http://throttlechannel.com/wp-conten...nel.com-13.jpg |
07-30-2018, 01:18 AM | #6 |
Rep 15
06-08-2019, 06:13 AM | #7 |
Rep 3
06-08-2019, 07:51 AM | #8 |
Rep 500
Drives: BMW 330e F30 M-sport
Modifying the original exhaust is probably your best bet. Depending on much sound you want you can remove or replace the rear muffler, and replace the downpipe with a high flow cat or decat. The tailpipes you can replace with whatever you fancy and thinks look good.
This route is typically cheaper than buying something aftermarket as well, and almost nothing aftermarket is confirmed to fit the 330e, so you risk having to modify it anyway.
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
10-20-2019, 10:37 AM | #10 |
Rep 500
Most exhaust shops will be able to help you out with a custom exhaust, but having tips on both sides will require some additional modification (and possibly to your bumper too). I went with dual on just one side (same as original) but with a bigger diameter (2x3"). 2x80mm (3.15") will fit too, but I didn't find one I liked.
Thorbjorn
10-21-2019, 08:27 AM | #11 | |
Rep 41
10-21-2019, 11:04 AM | #12 |
Rep 500
So, here's a bunch of pics. Before/after removing mid-muffler, before/after replacing rear muffler (note that the tail pipes on this pic is not the ones I ended up with, which are slightly bigger). And downpipe (haven't got a pic of that on the car). The final two pictures (in box and on the car) show the tailpipe I currently have. Pretty similar looking than the one in the closeup, but slanted and a bit bigger (3")
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs Last edited by hybris; 10-21-2019 at 11:16 AM.. |
10-21-2019, 02:51 PM | #13 |
Rep 41
That looks really good, but its the symmetric aesthetic im looking for so I'm not sure if i'd go for something like that. How's the sound after removing the mid muffler?
10-22-2019, 01:16 AM | #14 | |
Rep 500
The rear muffler is now a Magnaflow 11376 that has a nice deep sound, reasonably quiet on idle/cruise, and pretty loud on WOT. The downpipe increased the sound an additional 50% or so, but no additional drone and still pretty quiet during cruising. (It's a catted 200cel downpipe, not catless)
Thorbjorn
12-15-2019, 03:20 AM | #16 |
Rep 500
Nice. So the valve controls whether it goes through the left or right pipe? Should be pretty loud even when it goes through the muffler? Any drone?
Thorbjorn
12-15-2019, 03:51 AM | #17 |
Rep 5
Only the left pipe is straight piped when the valve is open, else the flow goes through the muffler to both pipes. Yes, it is pretty loud with very deep sound. Sound is perfect on the front seat but at the back seat there is little drone.
12-19-2019, 05:02 AM | #18 | |
Rep 75
Drives: BMW 330e
12-19-2019, 05:29 AM | #19 | |
Rep 500
That being said, I ran with the downpipe without a tune for two months without any fault codes - but most downpipes will throw a code eventually.
Thorbjorn
12-19-2019, 05:47 AM | #20 | |
Rep 75
Drives: BMW 330e
I run a custom map so that could be an issue for me. Unless i have it remapped again. I heard that the fault code could be avoided if you use a spacer on the lampda to move it away a bit. The BM3 suppresses all fault codes, right? That could be a bit dangerous. |
12-19-2019, 05:50 AM | #21 | |
Rep 500
BM3 only suppress/deactivate the catalytic efficiency sensor, and only if you specifically activate that feature. It does not suppress anything else.
Thorbjorn
12-19-2019, 05:56 AM | #22 | |
Rep 75
Drives: BMW 330e
That sounds good. What kind of power are you making now? |
