01-17-2020, 05:54 AM | #2157 |
Rep 28
01-17-2020, 06:00 AM | #2158 | |
hardware modder
26
Rep 31
also do not unpack the original apk, but open the apk file with 7zip, and drag the new pngs inside and close it again (with saving), this should not modify the signature, but only replace graphics! |
01-17-2020, 06:38 AM | #2159 | |
Rep 1,048
My script does ping the unit first to se if it is in the same network, if this does not work, then there is some other issue before. Which IP and MAC Adress do your unit and your PC get ? Kri |
01-17-2020, 06:45 AM | #2160 | |
Rep 2,369
Drives: E63 645Ci
Edit: I believe smahel managed to successfully modify and install KswPLauncher.apk in the past. Any input would be much appreciated. Also what are the chances of ending up in a boot loop by swapping just a few png files? Last edited by RedErik; 01-17-2020 at 07:08 AM.. |
01-17-2020, 10:30 AM | #2161 | |
Rep 190
I think that 30g terminal stays on for more time. I tried that already but didn`t work. I bridged the cable from CID to the yellow cable of the unit . But i did not cut out the original harness before the bridge from the yellow cable. I thought that if the system cuts power coming from CCC if i give power from the CID also it will keep working. Unfortunately not. Perhaps i must connect the CAN lines from CID to the unit because i think that MCU gives the signal to the system to power on. Am i wrong with that? |
01-17-2020, 11:28 AM | #2162 | |
Rep 2,369
Drives: E63 645Ci
Unless I'm mistaken about this 30min, but I'm pretty sure that's what TIS says. Also you've used yellow cable to bridge power to the unit. I wouldn't go by colours, these can vary car to car. You need to find in TIS which pin on the CID connector provides 12V. |
01-17-2020, 11:45 AM | #2163 |
Rep 80
hello, i finally send my android radio to the seller and he will send me another new. Now, the screen that it is going to send me is with a cic (4pins) connector because i want to update the radio professional and put the cic bussines in to my e87. I want to ask you guys if you know that with this screen will work with my profesional radio before i put the new cic navi bussines. And another question, if it is possible yo use the ccc idrive controller with this cic navi. Thank you!
01-17-2020, 03:01 PM | #2164 | |
Rep 190
I found the correct cable from the CID. i bridged it with the yellow cable from the unit main harness but nothing happend. The unit did not power on when i unlocked the car. You are correct about your concerns. I would like to test it and reverse it if did not like the behaviour in every day use. That for i bridged and not cut or weld the cables. |
01-17-2020, 04:23 PM | #2165 | |
Rep 2,369
Drives: E63 645Ci
01-18-2020, 01:43 AM | #2167 | |
Rep 190
The thing is that i checked the yellow wire on the unit for voltage and has 12v all the time regardless i bridge the cable from CID or not. That tells me that MCU somehow sees if the ignition is on and powers the unit and if the ignition is turned to off it powers down the unit. The can cables come from the M-ASK unit so it must understand that from can cables. M-ASK / CCC units in older E60 before 2004 are connected to MPM ( micro power module ) that provides current all the time. But not the CANBUS system. That is connected to another module. The proof of that is that with ignition off when you press the M-ASK /CCC knob sound comes from radio but the screen does not light on as it should or as it does with the OEM screen installed. So maybe that for the unit does not power on when unlocking doors. The question is why the unit powers on if it is on bench only with power and ground in pins 9-10 of the main harness . Confusing ! They should have an option for how long the unit will stay powered on when terminal R is off. It is not a matter of connection. Well it is possible to fix it by changing connection but it is not the proper way of doing that. |
01-18-2020, 02:30 AM | #2168 |
Rep 11
Hi friends, I have been reading you for several weeks, and now, since I have received my Android 9 screen 4+64 from NAVIODM+fakra C "Y adapter" (for the GPS)+front and rear wireless cameras, I am going to proceed to install it, so thank you for sharing all your knowledgement.
But, before installing all the things, I have some questions: -Where is the best place to locate the provided microphone? -Is it correct to take the +12V cable from the rear light to power the rear camera and wireless transmmitter? -The front camera is going to be located under the plate, so I need to know where the hell do I take the +12V for the camera and the wireless transmitter -Where do I connect the front camera? DVR input? Thank you so much for your help. |
01-18-2020, 03:04 AM | #2169 |
Rep 44
Hi Guys,
it has been a while and i'm trying to wrestle through everything that has been said already. I've installed an aftermarket amp and coded the iDrive from base stereo to Hi-Fi stereo. This results in a balanced low level output from the stereo. Now the issue becomes when we use the idrive side audio and the navigation on android is turned on. By design the android stereo will "inject" the sound to the left speaker (white wires which go from quadlock to android radio and back to quadlock). Since the signal on the cable is now low level and not speaker level, the sound sounds all mangled and very loud since the amplifier is receiving a high level signal. Is there a setting in the android radio to indicate which type of sound output you want? I've tinkered with most of them but no luck so far. I also know of the setting 'car amplifier' which has 2 options I think but makes no difference as far as I can see. I'm still on version 2.8.3 so maybe thats a bug or something. Many thanks, Pro. |
01-18-2020, 03:52 AM | #2170 |
Rep 114
01-18-2020, 04:48 AM | #2172 | |
Rep 2,369
Drives: E63 645Ci
But this would make so much more sense than "primitive" voltage dependency. You could power up or down unit based on CAN messages form CAS (I believe this is how it's done in G series cars - with equivalent of CAS). That would also explain why unit powers up with bench supply and not necessarily when you connect that through CID connector. MCU must have a routine to check for presence of CAN network, if there is one - wait for message and act accordingly, if none detected - power up in "standalone mode". I would need to go through some materials I have and TIS to verify what I just said, but it makes a very compelling argument. However if that is the case... there is nothing we can do now to benefit from that. We would need to pressure our sellers so they can talk to their engineers and these engineers than would have to... unbreakable chain of command. Someone it this thread suggested way back when if we could talk to the right people, do some crowdfunding, we could probably buy the source code for MCU and Android. I for one would throw in few quid for that. |
Pondaire37.00 |
01-18-2020, 05:19 AM | #2173 | |
Rep 399
01-18-2020, 05:28 AM | #2174 | |
Rep 190
I have never tried that in 2004 E60 to confirm if that is happening in my car also. |
01-18-2020, 05:29 AM | #2175 | |
Rep 2,369
Drives: E63 645Ci
01-18-2020, 05:33 AM | #2176 | |
Rep 190
In this case the unit will power up because it will detect can signal and power off when terminal 30g closes the circuit after 30 minutes. But the screen will stay on for that time. The appropriate way is to shut down the screen after you switch ignition off , light up screen when you press the volume knob in iDrive and stay alive for some time after . the appropriate |
01-18-2020, 05:34 AM | #2177 | |
Rep 190
If you unlock your car ,get in and press volume knob sound will come and screen will light up in the OEM system. When android head unit is installed, music will play but screen will not light up and android will not boot when doing the same thing with volume knob. |
01-18-2020, 05:51 AM | #2178 | |
Rep 2,369
Drives: E63 645Ci
I'm just skimming through CAS module and looking what is available to code. There is section PA - Comfort access, funtion PA_MONITOR_ACTIVE with two options aktiv and nicht_acktiv but I'm not entirely sure what that is. I would need to plug in to OBD port as check what option is coded by default in my car. Maybe that is what we all are looking for. |
